258 5 187.2k 3
    Nope @phenomlab
    Same things, same problem
  • Nope @phenomlab
    @DownPW then the problem isn’t the existing function. That ID I provided doesn’t exist anywhere and isn’t tied to any elements so should never trigger.
    oups don’t know why I have used this code, replace by :
    <div class="getUsername">, <a href="/me"><span class="username"></span></a></div>
    But same problem
  • oups don’t know why I have used this code, replace by :
    But same problem
    @DownPW did you remove the original line from the footer before placing it in the brand header?
    remove no, but commented like this
    <!-- <span id="thisuser" class="getUsername">,  <a href="/me"><span class="username">DownPW</span></a></span> -->
    EDIT: test with remove = same
  • remove no, but commented like this
    @DownPW can you send me the footer function your are using. I’m 100% certain this is being caused by the ajax call.
    @DownPW can you change the top line of this function from
    $(window).on('action:ajaxify.end', function (data) {
    To
    $(document).ready() {
    Save and let me know if this changes anything. The theory here is that the Ajax call in the top line causes the prepend to be executed multiple times
    the code doesn’t work with this
  • the code doesn’t work with this
    @DownPW it should work once at least on site reload, no? Or does it crash?
    no, doesn’t work and break theme and swatch applet
  • no, doesn’t work and break theme and swatch applet
    @DownPW that shouldn’t cause the error you are seeing there. It looks like that is from the previous function.
    the previous function is just fancybox and nothing more :
    // Fancybox Media Reader
    if (top.location.pathname !== '/login') {
        $(window).on('action:posts.loaded', function(data) {
            console.log("Polling DOM for lazyLoaded images to apply Fancybox");
                $('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() {
                    $('a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"]').addClass("noanimate");
                this.$('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() {
                    data.preventDefault()
                    // Strip out the images contained inside blockquotes as this looks nasty :)
                    $('blockquote img').remove();
                Fancybox.bind(
                    'a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"]', {
                        groupAll: true,
    // Chat fancybox - fires when chat module loaded and AJAX calls new chat
        $(window).on('action:chat.loaded', function(data) {
                this.$('img').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() {
                    var newHref = $(this).attr("src");
                    $(this).wrap("<a class='fancybox' href='" + newHref + "'/>");
                    data.preventDefault();
                Fancybox.bind(
                        groupAll: true,
    the error above just appear wit hthe change of $(document).ready() {, no error with $(window).on('action:ajaxify.end', function (data) {
  • the previous function is just fancybox and nothing more :
                Fancybox.bind(
                        groupAll: true,
                Fancybox.bind(
                        groupAll: true,
    @DownPW very odd. I’ll have a look at this directly on your dev site tomorrow morning to see why this is.
    EDIT - this is now fixed. I looked at the code, and I was right that it should work, and only execute once 🙂 - not sure what happened there.
    EDIT2 - I absolutely love this design, and am stealing it 🙂 Such a clever way of depicting colour in the theme, and I’m going to make it dynamic also so that the colours change if the theme css does.
  • @DownPW very odd. I’ll have a look at this directly on your dev site tomorrow morning to see why this is.
    @phenomlab said in [NODEBB] Help for my custom CSS:
    EDIT - this is now fixed. I looked at the code, and I was right that it should work, and only execute once - not sure what happened there.
    ⚠️ hmmm not, almost fixed @phenomlab !
    It’s ok for duplicate ajax problem but not fixed for the the footer image : It’s appear one time and if you go to another section (like recent or unread for example), the image on footer don’t appear
    Same in incognito mode.
    EDIT2 - I absolutely love this design, and am stealing it Such a clever way of depicting colour in the theme, and I’m going to make it dynamic also so that the colours change if the theme css does.
    Thank you !
    –> I already told you, my code is your code 😉
    Thinking about it, I found this idea elsewhere but I don’t really know where 🙂
    I just added a rotation effect on it and adapted it to the dropdown of the brand menu widget.
    You talk about making it dynamic but I don’t really see what you mean since the theme colors represented do not change.
    Unless you want to automate it. Genre detects the 2 main color types of the theme according to 2 values/declarations present in the css file.
  • @phenomlab said in [NODEBB] Help for my custom CSS:
    Thank you !
    @DownPW said in [NODEBB] Help for my custom CSS:
    I kind of expected that because the footer image relies on an ajax reload to determine the time, then work out which image to display based on that. The real problem here is that the prepend is being called on each request, and because it’s an prepend, you are seeing multiple copies.
    One way to fix this is to delete the element and recreate it, but that is horribly inefficient 😕
    I’ve modified the function to include a check to see if the containing div is empty or not - if it is, we add the icon and message - if it’s already there, we skip it
        // Test to see if the DIV containing the icon and message is empty. If it is, insert icon and message
        if ($('#busername').length === 0) {
            $('.getUsername').prepend("<div id='busername'><i id='thisicon' class='" + theicon + "'></i></div>" + themessage);
        } else {
            // nothing to do here :)
    (Note that this has been added to the existing function)
    And some minor css which allows us to float the new div so that it displays inline
    // Inline display fix for Welcome DIV
    div#busername {
        display: inline;
    Thank you !
    Simple enough -you just reference the variables, but admittedly, you’d need to refactor some code to make this work transiently, so it’s probably not a very good idea. I suppose it really depends on how often you decide to revamp your themes - in which case, it would make sense.
    I just don’t like static variables 🙂
  • @DownPW said in [NODEBB] Help for my custom CSS:
    It doesn’t bother me too much personally because I’m not ready to modify the themes in depth, especially the main colors, but what you say makes sense.
    It’s always better to automate when you can.
    I’ll see what you can do ha ha 🙂
    In any case, I’m happy to bring my stone to the building 🙂
    I have a dropdown menu with manu different left icons and I want to align vertically the <a> text
    I don’t know why I can’t do it. Fatigue maybe? 🙂
    Here the code of my menu :
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i id="menubrand" class="fa-solid fa-lg fa-scroll text-primary"></i>&nbsp; Règlements</a></li>
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i id="menubrand" class="fa-solid fa-lg fa-newspaper"></i>&nbsp; Annonces</a></li>
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i id="menubrand" class="fa-solid fa-lg fa-people text-primary"></i> &nbsp; Team</a></li>
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx""><i id="menubrand" class="fa-solid fa-lg fa-database text-primary"></i> &nbsp; Tutoriels</a></li>
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i id="menubrand" class="fa-solid fa-lg fa-bug text-primary"></i> &nbsp; Bug Report</a></li>
    <li><a id="menubrand" class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i id="menubrand" class="fa-solid fa-lg fa-brands fa-wikipedia-w text-primary"></i> &nbsp; Wiki</a></li>
    Resut :
    Many thanks 😉
  • Hello @phenomlab
    Resut :
    Many thanks 😉
    @DownPW You’ll need to restructure the HTML first - don’t use nbsp; - you should always use margin or padding 🙂 Also, you are using the same ID multiple times which will cause you problems with markup as it is not unique.
    Try this
    <li><a class="menubrand dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i class="fa-solid fa-lg fa-scroll text-primary menubrand"></i>Règlements</a></li>
    <li><a class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i class="fa-solid fa-lg fa-newspaper menubrand"></i>Annonces</a></li>
    <li><a class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i class="fa-solid fa-lg fa-people text-primary menubrand"></i>Team</a></li>
    <li><a class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx""><i class="fa-solid fa-lg fa-database text-primary menubrand"></i>Tutoriels</a></li>
    <li><a class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i class="fa-solid fa-lg fa-bug text-primary menubrand"></i>Bug Report</a></li>
    <li><a class="dropdown-item rounded-1" href="https://xxxxxxxxxxxxxxxx"><i class="fa-solid fa-lg fa-brands fa-wikipedia-w text-primary menubrand"></i>Wiki</a></li>
    Then use this CSS
    i.menubrand {
        max-width: 25px;
        width: 25px;
        margin-right: 10px;
        text-align: center;
        vertical-align: middle;
    Should give you this
    hmmm ok I will test asap thanks 😉
    Why have you the second icon with no colors : odd no ?
