Hello Mark
I use this css code for reduce the image size :
.topic .posts .content .img-responsive { max-width: 45%; width: auto; padding: 1px; border-radius: 4px; border: 1px solid #c3c3c3; background-color: #F5F5F5; margin-top: 5px; margin-bottom: 5px; }Would it be possible to have a separate max size just for GIFs extension files (.gif) ?
I would like the gifs to be smaller than the imagesThanks in advance @phenomlab
Hello Mark
@DownPW Possible, yes, but it may be a little on the “greedy” side.
Try this - obviously, remove the red border I used for testing and add your own code
img[src$="gif"] { border: 10px solid red !important; }This is also very useful as a reference
@phenomlab said in [NODEBB] Help for my custom CSS:
–> it seem to work with this code:
/* max-width for IMG Files */ .topic .posts .content .img-responsive { max-width: 45%; } /* max-width for GIF Files */ .topic .posts .content .img-responsive[src$="gif"] { max-width: 10% !important; }Thanks @phenomlab for the attribute that I don’t find
It’s possible to add video background (mp4 for example)on nodebb for one theme and not for the other?
@DownPW yes, but you have to be careful with performance. This can impact the loading of the site depending on the size of the MP4 file and where it is being accessed from.
File accessible on the server and 22.6 mo
How can I 'm doing this for testing?
@DownPW Something like this would work
<video autoplay muted loop id="bg-video"> <source src="file.mp4" type="video/mp4"> Your browser does not support HTML5 video. </video>Then some CSS which you’ll need to play with (this is an example)
#bg-video{ position: fixed; right: 0; bottom: 0; min-width: 100%; min-height: 100%; } -
hello @phenomlab
I have a very odd bug that I didn’t have before
I have images and background color defined for each category
when I open a new topic, the fa icon on the bottom left taskbar does not appear like when I reply to a topic
Here a gif too see the problem :
And here is the result I want:
I have tried to play with the color or z-index variable in css but nothing works
I tried disabling the custom CSS on ACP but it’s the same. clear the cache = same
Have you an idea ?
You can test on production forum
hello @phenomlab
Have you an idea ?
hello @phenomlab
Have you an idea ?
I will test without css, js, header and it’s the same
Active plugins:
* @nodebb/nodebb-plugin-reactions@1.0.2 (installed, enabled) * @nodebb/nodebb-plugin-user-level@1.0.4 (installed, enabled) * nodebb-plugin-beep@0.4.7 (installed, enabled) * nodebb-plugin-browsing-users@2.0.4 (installed, enabled) * nodebb-plugin-cards@0.3.1 (installed, enabled) * nodebb-plugin-composer-default@9.1.0 (installed, enabled) * nodebb-plugin-dbsearch@5.1.5 (installed, enabled) * nodebb-plugin-emoji@4.0.4 (installed, enabled) * nodebb-plugin-emoji-apple@3.0.0 (installed, enabled) * nodebb-plugin-extended-markdown@1.6.0 (installed, enabled) * nodebb-plugin-global-chat@2.0.0 (installed, enabled) * nodebb-plugin-iframely@0.7.16 (installed, enabled) * nodebb-plugin-imgur@2.0.5 (installed, enabled) * nodebb-plugin-markdown@10.1.0 (installed, enabled) * nodebb-plugin-mentions@3.0.11 (installed, enabled) * nodebb-plugin-ns-embed@6.0.0 (installed, enabled) * nodebb-plugin-poll@2.0.6 (installed, enabled) * nodebb-plugin-question-and-answer@0.12.25 (installed, enabled) * nodebb-plugin-recent-cards@2.0.22 (installed, enabled) * nodebb-plugin-spam-be-gone@1.0.0 (installed, enabled) * nodebb-plugin-tenor-gif@2.2.0 (installed, enabled) * nodebb-plugin-twitter@0.1.0 (installed, enabled) * nodebb-plugin-ws-dice@2.4.2 (installed, enabled) * nodebb-rewards-essentials@0.2.1 (installed, enabled) * nodebb-theme-persona@12.1.1 (installed, enabled) * nodebb-widget-essentials@6.0.0 (installed, enabled) -
Active plugins:
The last plugins we installed is the dice plugin, Iframely, and twitter, to be tested…
Because the others are quite well known and I never noticed this bug with them, but I could be wrong.
Hmm. You could use a simple jQuery function to replace that icon with the right one. Just seems a bit “overkill” but might be necessary
why not, if you can write this query I’m not saying no, just to test
JS code seems not working but…
I see on ACP, the image of category is uploaded to imgur :
and I see this on dev console :
The url seems to not be encoded correctly, I don’t know why ???
If I change manually the URL in the dev console, it’s OK:
@DownPW said in [NODEBB] Help for my custom CSS:
Yes, that certainly seems the case. I think you need to take this issue up with the plugin developer.
[NODEBB] CSS Style Sheets SelectBox
Locked Solved Customisation -
