258 5 187.3k 3
    #41
    Nope, I don’t think so because I haven’t got the problem on an another themes and here too
  • Nope, I don’t think so because I haven’t got the problem on an another themes and here too
    @downpw Can you provide the same example with another theme ?
  • @downpw Can you provide the same example with another theme ?
    @downpw So (for example) do you want the Discard button to turn red if you you click Confirm, or am I off track here ? Not entirely sure what you’re after 🙂
  • @downpw So (for example) do you want the Discard button to turn red if you you click Confirm, or am I off track here ? Not entirely sure what you’re after 🙂
    @phenomlab Never mind already found the right CSS property would be nice 🙂
  • @phenomlab Never mind already found the right CSS property would be nice 🙂
    @downpw Do you mean this one
    button.btn.btn-default.composer-discard:focus {
        background: red;
    Or another ?
  • @downpw Do you mean this one
        background: red;
    Or another ?
    @phenomlab Another I think
    It seem to be a btn-default problem
  • It seem to be a btn-default problem
    #49
    @downpw
    yes it’s that
    alt text
    But if you have the same for Login button, I take 🙂
  • @downpw
    yes it’s that
    alt text
    #50
    @downpw Think I might have it
    .composer-discard:disabled {
        background: red !important;
  • @downpw
    yes it’s that
    alt text
    @downpw said in [NODEBB] Help for my custom CSS:
    Use this
    button#login {
        background: green;
        border: 1px solid green;
  • @downpw Think I might have it
    @phenomlab said in [NODEBB] Help for my custom CSS:
    That’s works too
    Other things, I would like to change progress bar color of Windows alert like welcome message, palcement user banner etc…:
    https://i.imgur.com/DgYHHZc.gif
    @phenomlab No idea ?
  • @phenomlab No idea ?
    @downpw yes, I’ve done the same on sudonix but not in front of a pc presently. If you switch to dark mode on this platform, you’ll see the changes i made to the alert message.
    #56
    I see how to change background color, text color, border color but not the progress bar with transition value.
    It’s too fast to see the code on console
    I see this in “element style” :
    transition: width 5450ms linear 0s, background-color 5450ms ease-in 0s;
    But I don’t no what to do with this
    #57
    @downpw Seems like it’s contained in this block
    <div id="alert_button_1643376464937" class="alert alert-dismissable alert-success clearfix animate" component="toaster/toast" timeoutid="172" style="transition: width 5450ms linear 0s, background-color 5450ms ease-in 0s;">
    	<button type="button" class="close" data-dismiss="alert" aria-hidden="true">×</button>
    	<strong>Welcome Back  phenomlab!</strong>
    	<p>You have successfully logged in</p>
    </div>
    For info, you can actually pause the execution of Javascript as follows
    1. Open Developer tools, Go to Sources tab and keep it ready
    2. Now, go back and perform the actions on the App to get it to the state where it needs to be frozen.
    3. Click on the ‘Pause Script Execution’ button (first button in the list of buttons on the right corner of Sources tab) to pause the page.
    This will force the debugger to pause the execution, meaning you’ll see the below
    This will then allow you to expose the elements you need 🙂
  • @downpw Seems like it’s contained in this block
    </div>
    #58
    Yeah I test that and I find and modify these code :
    .alert-window .alert {
        background-color: black;
        color: aqua;
    .alert-window .alert.alert-success {
        color: aqua;
        border-color: aqua;
    .alert-window .alert.animate.alert-success::before {
        background-color: red !important;
    .alert-window .alert.animate::before {
        width: calc(100% + 50px);
    For example, what i want here are just have animate progress bar on red but doesn’t work, she’s black.
    I close the topic on nodebb communauty. no one respond
        color: aqua;
        color: aqua;
        border-color: aqua;
    #59
    no one respond
    Only me 😄
    I’ll have a look this weekend to see if I can identify the js class but I do think this is based off another CSS value and an alpha rgba used as an overlay.
    #60
    I have test with white background and It seems to work.
    But the red come at the middle/end (maybe a settings CSS transition) :
    alt text
    But with black background, the red is here (we see it at the end) we see nothing at all.
    Seems the background overall the animate effect :
    alt text
