258 5 187.2k 3
    Hello,
    because I use nsembed plugin now, I see the frame are a bit little compared to this forum which uses the same plugin.
    How did you handle that Mark?
  • Hello,
    @DownPW sorry, I’m not entirely sure what you mean?
    Sorry the player is small compared to here. I would like to enlarge them ^^ 😉
    – Mine :
    – Here on sudonix :
  • Sorry the player is small compared to here. I would like to enlarge them ^^ 😉
    – Mine :
    – Here on sudonix :
    @DownPW Try this
    .embed-container iframe {
        width: 600px;
        height: 300px;
    Obviously, adjust width and height as required
    Hmm I have this problem with hover background color on close button on modal chat on my dev instance.
    The background color is black :
    And it seems my code doesn’t work :
    I confess that I do not fully understand why I have black and that my code is not interpreted correctly.
    Thanks in advance for your help my friends 😉
  • Hmm I have this problem with hover background color on close button on modal chat on my dev instance.
    @DownPW It’s caused by this css
    .btn-close {
        filter: var(--bs-node-btn-close-color) !important;
    If you remove that filter, the issue will be resolved.
    Thanks. It’s an error.
    Why I have used filter lol
  • Thanks. It’s an error.
    @DownPW I figured 😁
    So actually after research I was using as this was used in old core code.
    By removing the “Filter” directive it works for the black background on the hover of the close button: cool !!
    But for the color of the cross icon itself (In fact it is not an icon but an image) it is black for light themes, no problem but it remains black for dark themes so it becomes invisible !!!
    So here is my solution :
    .btn-close {
      background: var(--bs-node-btn-close-bg) !important;
    • for light theme:
    --bs-node-btn-close-bg: transparent url("data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 16 16' fill='%23000'%3e%3cpath d='M.293.293a1 1 0 0 1 1.414 0L8 6.586 14.293.293a1 1 0 1 1 1.414 1.414L9.414 8l6.293 6.293a1 1 0 0 1-1.414 1.414L8 9.414l-6.293 6.293a1 1 0 0 1-1.414-1.414L6.586 8 .293 1.707a1 1 0 0 1 0-1.414z'/%3e%3c/svg%3e") center/1em auto no-repeat;
    • for dark themes :
    --bs-node-btn-close-bg: transparent url("data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 16 16' fill='%23fff'%3e%3cpath d='M.293.293a1 1 0 0 1 1.414 0L8 6.586 14.293.293a1 1 0 1 1 1.414 1.414L9.414 8l6.293 6.293a1 1 0 0 1-1.414 1.414L8 9.414l-6.293 6.293a1 1 0 0 1-1.414-1.414L6.586 8 .293 1.707a1 1 0 0 1 0-1.414z'/%3e%3c/svg%3e") center/1em auto no-repeat;
    I see you have the same problem here on sudonix, test that 😉
    .btn-close {
    • for light theme:
    • for dark themes :
    @DownPW thanks. I’ll check this.
    no problem. Always @phenomlab
    I want to test your author badge (fa) :
    Can you provide CSS for this please ?
    Thank you
    edit:
    tetsing this but i don’t think i’m on the good road
    .topic-owner-post [itemprop=author]:before{
        font-family: "Font Awesome 6 pro";
        font-style: normal;
        content: "\e1e4";
        left: 100px !important;
        text-align: left !important;
        position: absolute;
  • no problem. Always @phenomlab
    Thank you
    edit:
        font-style: normal;
        content: "\e1e4";
        position: absolute;
    @DownPW heh, that also needs some js to make that work.
    Edit - add this js block
    function addAuthorBadge() {
      $(".topic-owner-post").each(function() {
        var $authorElement = $(this).find(".text-nowrap:first");
        // Check if the author badge already exists
        if (!$authorElement.find(".author").length) {
          // Prepend the author element
          $authorElement.append("<span class='author' data-toggle='tooltip' data-placement='left' title='Topic Author'><span class='author-icon'><i class='fa-regular fa-message-quote'></i></span>");
          // Add tooltip on hover
          $authorElement.find(".author").tooltip({
            content: "Topic Author",
            track: true // This enables the tooltip to track the mouse movement
      $(window).on('action:posts.loaded', function(data) {
          addAuthorBadge();
          addAuthorBadge();
    OMG make sense
    Thanks dude 🙂
    Hello,
    I just changed my smartphone (OnePlus 12R) and I see this which I cannot resolve.
    the central body is offset and is not centered on the smartphone. (production server)
    Any idea to solve this??
  • Hello,
    @DownPW yes, I too see this on your production site. Typically, this is because of one element that is oversized and causing the entire body to shift.
    Unfortunately, it’s a slow process in terms of finding the culprit, but I’ll have a more detailed look later.
  • @DownPW yes, I too see this on your production site. Typically, this is because of one element that is oversized and causing the entire body to shift.
    @phenomlab said in [NODEBB] Help for my custom CSS:
    OK Thank you. Logo I guess
    I also noticed that the "answer "button on my DEV platform following the new update is quite large but I can’t find the right CSS target to correct it.
    Can you help me with that too?
  • @phenomlab said in [NODEBB] Help for my custom CSS:
    @DownPW said in [NODEBB] Help for my custom CSS:
    Sort of.
    You can stop most of the overflow with the below CSS
    body {
        overflow-x: hidden;
        max-width: 100%;
    Add the above to the existing body class you have.
    For the remainder, it’s much easier to see where elements burst outside of their boundaries by using the global CSS below, which will draw a border around every single element - effectively, making it much easier to see
    outline: 1px solid red;
    This then yields the below
    As you can clearly see, the additional navigation buttons you have are flowing outside of their allowed space, which causes the body to expand to accommodate the new size. This produces the undesired effect of scrolling on the entire body.
    Then, look at the class of
    [data-widget-area=brand-header] {
        justify-content: end;
        display: flex;
    If you remove display: flex; from this class, the icons are then stacked vertically, and the problem resolves itself. However, this looks ugly. A better way of getting closer to the result you want is to resize the logo
    [component="brand/logo"] {
        max-height: 100px;
        width: auto;
        height: 75px;
        margin-top: -1px;
        height: 45px;
    Here, we’ve dropped the image size from 75px to 45px, which in turn pulls the expanded DIV back into line
    The problem we then have is the site title, but can easily fix that with the below CSS
    @media (max-width: 768px) {
        a.text-truncate.align-self-stretch.align-items-center.d-flex h1 {
            height: 55px;
    This then yields
    Everything now aligns correctly, and more importantly, the scrolling body is no more.
    Yes, of course. You can target the component directly for that
    [component="topic/quickreply/button"] {
       height 45px;
    I will test ASAP
    Many thanks my friend
    I come back here with a little problem.
    I created a donation button in the custom footbar that works well.
    It looks like this with the following code:
    <div id="floatright">
    <div class="d-flex justify-content-center mt-2 mb-2">
        <a href="https://ko-fi.com/K3K519RHI6"
           class="btn btn-primary d-flex align-items-center btn-donation"
           target="_blank">
            <img src="https://storage.ko-fi.com/cdn/logomarkLogo.png"
                 alt="Icône café" class="me-2">
            Faire un don
        </a>
    </div>
    <a class="feedback-menu-far-right" target="_blank" href="/politique">Politique&nbsp;</a>
    However, as soon as I go to a profile page, the users page, the group page, it is broken like this :
    possible to see it on production server
    Any idea to resolve this ?
  • Please help me, I can't install nodebb
    Locked Solved Customisation nodebb
    Installation completed, verified, and tested. Correct installation methodology is below https://docs.nodebb.org/installing/os/ubuntu/
  • Bug Report
    Solved Bugs nodebb bugs
    22k Views
  • Chevron up before & after
    @crazycells you are right thank you.
  • Custom badges
    67k Views
    Perfect
  • [NodeBB] Import custom Font
    Solved Customisation custom fonts nodebb css
    @cagatay you’ll need to define this in the body tag (or another element if you want greater or more granular targets) - for example body { font-family: "Poppins"; font-size: 16px; } Essentially, you use the font-size CSS directive.
  • CSS Help on my Flarum
    @mike-jones Yes, you’ll typically see this type of behaviour if there is another style that has higher priority in the sense that yours will be overridden. Using !important will override the higher preference, but should be used sparingly rather than everywhere.
  • [NodeBB] custom Gravatar image not showing
    @jac said in [NodeBB] custom Gravatar image not showing: @phenomlab said in [NodeBB] custom Gravatar image not showing: @jac are you using Custom ? Sure am mate Confirmed Fixed
