258 5 187.3k 3
  • @downpw this one
    https://sudonix.com/topic/207/nodebb-help-for-my-custom-css/7?_=1642791291710
    I’ll have a look at this tomorrow but ideally need the code applied beforehand.
    Ok done at the end of the file
    @downpw thanks
    @downpw Are these lines still there ? I don’t see them at the bottom of the file ?
    #25
    @downpw Thanks for the confirmation. This is indeed quite odd, as the classes, despite being at the bottom of the file, do not appear in the DOM. If I apply them manually
    Everything works as I expected
    Looking at your CSS, I can see why
    Note that you are missing a closing curly brace on what should be line 2716 🙂 so this explains why the remaining CSS is not being loaded !
    This block also has a stray asterisk
    .message-body, .btn-xs.btn-link {
        margin-left: -2px !important;
        margin-right: 1px !important;
    Should be
    Oh my god.
    I’m a noob.
    as a reminder, the problem on the chat is not with mouse hover (I see you have a hand on the button) 😉
    Oh my god.
    I’m a noob.
    @downpw Yes, I know. I’m just rectifying the issues
    @DownPW After spending a lot of time on the theme switcher (see referenced post above), I re-wrote some of it as found that there were caching issues with CSS as it always calls the same version number. The new function below resolves that issue.
    I also removed the website prefix, as with relative paths, this is not required 🙂
    // Theme Switcher
    // On choisit une chaine de caractère aléatoire pour affecter un numéro de version au fichier CSS.
    // The function below creates a random string which we use for CSS versioning to prevent cache conflicts
    function generateRandomString(length) {
        var text="";
        var possible="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789";
        for (var i=0;
        i < length;
        i++) {
            text+=possible.charAt(Math.floor(Math.random() * possible.length));
        return text;
    $(document).ready(function () {
        var string=generateRandomString(10);
        $("#random_string").text(string);
        // This variable gets the theme ID
        // Cette variable obtient l'ID du thème
        var whichTheme=localStorage.getItem("theme");
        // This variable gets the active theme's actual URL
        //Cette variable obtient l'URL réelle du thème actif
        var activeTheme=localStorage.getItem("activeTheme");
        // This variable appends the dropdown list to the existing panel
        // Cette variable ajoute la liste déroulante au panneau existant
        var panel=$('<li id="switcher" class="dropdown text-center"> \
    <label for="theme-control-list-check" class="dropdown-toggle" data-toggle="dropdown" id="theme_dropdown" title="" role="button" data-original-title="Theme" aria-expanded="false"> \
    <a class="btn-link" title="Theme Switcher" href="#"><i id="ticon" class="fa fa-fw fa-lightbulb-o"></i><span class="visible-xs-inline">Theme Switcher</span></a> \
    </label> \
    <ul id="theme" class="dropdown-menu"> \
    <li><a id="default" href="#" rel="/assets/client.css?v=e02phpkima0">Default</a></li> \
    <li><a id="default dark" href="#" rel="/assets/customcss/default_dark.css">Default Dark</a></li> \
    <li><a id="Light Flat" href="#" rel="/assets/customcss/testflat.css">Light Flat</a></li> \
    <li><a id="Dark Flat" href="#" rel="/assets/customcss/testflat.css">Dark Flat</a></li> \
    <li><a id="Dark Neon Aqua" href="#" rel="/assets/customcss/dark_neon_aqua.css">Dark Neon Aqua</a></li> \
    <li><a id="Dark Neon Blue" href="#" rel="assets/customcss/dark_neon_blue.css">Dark Neon Blue</a></li> \
    <li><a id="Dark Neon Green" href="#" rel="/assets/customcss/dark_neon_green.css">Dark Neon Green</a></li> \
    <li><a id="Dark Neon Solary" href="#" rel="/assets/customcss/dark_neon_solary.css">Dark Neon Solary</a></li> \
    <li><a id="Dark Neon White" href="#" rel="/assets/customcss/dark_neon_white.css"">Dark Neon White</a></li> \
    <li><a id="Eva 00" href="#" rel="/assets/customcss/eva_00.css">Eva.00</a></li> \
    <li><a id="Eva 01" href="#" rel="/assets/customcss/eva_01.css">Eva.01</a></li> \
    <li><a id="Eva 01 Purple Green"href="#" rel="/assets/customcss/eva_01_purple_green.css">Eva.01: Purple-Green</a></li> \
    <li><a id="Eva 02" href="#" rel="/assets/customcss/eva_02.css">Eva.02: Red-Orange</a></li> \
    </ul> \
    </div> ');
        // See if there is an active theme selected in localStorage. If none selected, use the default. If there is a theme in localStorage, use that and apply it
        // Regarde s'il y a un thème actif sélectionné dans "localStorage". Si aucun n'est sélectionné, utilise la valeur par défaut.
        // S'il y a un thème dans localStorage, on l'utilise et on l'applique.
        if (whichTheme) {
            $("head").append("<link href='" + activeTheme + '?version=' + string + "' type=\"text/css\" rel=\'stylesheet\' />");
        else {
            // No need to include anything here as there's no CSS to add.
            // Pas besoin d'inclure quoi que ce soit ici car il n'y a pas de CSS à ajouter.
        $('ul#logged-in-menu').prepend(panel);
        $('ul#logged-out-menu').prepend(panel);
        if (utils.findBootstrapEnvironment()==='xs') {
            $('#menu').prepend(panel);
            // Listen to the NAV dropdown for any changes
            // Écoute la liste déroulante NAV pour tout changement de thème
            $("#theme li a").on("click change", function () {
                // If we detect a change, append the selected CSS file into the DOM
                // Si un changement est détecté, on ajoute le fichier CSS sélectionné dans le DOM (Document Object Model)
                var thishref=$(this).attr('rel');
                $("link[rel=stylesheet]").attr('href', thishref + "?version=" + string + "");
                //location.reload();
                //$("head").append("<link href='" + $(this).attr("rel") + $(this).attr("id") + " type=\'text/css\' rel=\'stylesheet\' />");
                location.reload();
                // This variable stores the selected theme ID
                // Cette variable stocke l'ID du thème sélectionné
                var selected=$(this).attr("id");
                // This variable stores the selected theme link
                // Cette variable stocke le lien du thème sélectionné
                var theTheme=$(this).attr("rel");
                // This variable updates the selected theme ID
                // See if "default" has been selected. If it has, then...
                // Cette variable met à jour l'ID du thème sélectionné
                // Regarde si "default" a été sélectionné. Si c'est le cas, alors...
                if (selected==='default') {
                    localStorage.setItem("theme", "");
                    // This variable will strip the current appeneded theme ID
                    // Cette variable supprimera l'ID du thème actuellement ajouté
                    localStorage.setItem("activeTheme", "");
                    // This variable will strip the current appeneded theme URL (HREF)
                    // Finally, we have to reload the page to effect the changes
                    // Cette variable supprimera l'URL actuelle du thème ajouté (HREF)
                    // Enfin, on recharge la page pour effectuer les modifications
                    location.reload();
                // If any other theme is selected, carry on as normnal, and update localStorage
                // Si un autre thème est sélectionné, continuez normalement et mettez à jour localStorage
                else {
                    localStorage.setItem("theme", selected);
                    // This variable updates the actual href of the CSS file
                    // Cette variable met à jour le href réel du fichier CSS
                    localStorage.setItem("activeTheme", theTheme);
                    //window.location.href = window.location.href
                // We use return false to prevent the browser from reloading or following any HREF links
                // On utilise la fonction "return false" pour empêcher le navigateur de recharger ou de suivre les liens HREF
                //return false;
    // When hovering over the #switcher element, target the i class and add 'themeoff'
    // Lorsque du  survol de l'élément #switcher, on cible la classe CSS "i" et on ajoute le CSS "themeoff"
    $(document).on('mouseenter', '#switcher', function() {
        $('#switcher i').addClass("themeoff");
    // When leaving the however state, target the i class and remove 'themeoff'
    // Lorsque l'on quitte l'état, on cible la classe CSS "i" et on supprime le CSS "themeoff"
    $(document).on('mouseleave', '#switcher', function() {
        $('#switcher i').removeClass("themeoff");
    #29
    – The modification for resolve cache problem/CSS number version is very great 🙂
    – I have just change the CSS class for change icon on JS Script here :
    var panel = $('<li id="switcher" class="dropdown text-center"> \
    <a class="btn-link" title="Theme Switcher" href="#"><i id="ticon" class="fa fa-fw fa-toogle-o"></i><span class="visible-xs-inline">Theme Switcher</span></a> \
    – I have light and dark theme, so I prefer a universal button like toogle ON/OFF
    • Toogle Off icon on Default Theme :
    • Toogle On icon on each other theme :
    – ACP/CSS :
    /*Switch toogle Off (Off:204 - On:205*/
    .fa.fa-toogle-o:before {
        content: "\f204";
        font-size: 16px;
    – Each theme CSS :
        content: "\f205";
        font-size: 16px;
    I have trad comment line too !!
    I put the topic on solved status but it’s not excluded that I return here to ask questions about CSS that I will have trouble finding for future themes if it does not bother ! 😉
  • DownPW DownPW has marked this topic as solved on
  • – The modification for resolve cache problem/CSS number version is very great 🙂
    – ACP/CSS :
        content: "\f204";
        font-size: 16px;
    – Each theme CSS :
        content: "\f205";
        font-size: 16px;
    @downpw some really nice enhancements there !
    #31
    I forgot this.
    – On position text and icon of theme switcher, I have added padding-top to ventilate the surrounding area and align all icon :
    /*Smartphone*/
    @media all and (max-width: 1024px)
    /*VIOLENCE: BUGFIX: Placement du "Theme Switcher" */
        #switcher {
        list-style: none;
        margin-left: -80px;
        padding-top: 15px;
    – And I also improved the space between the icon and the text :
    #switcher .fa-fw {
        text-align: center;
        width: 1.25em;
        padding-right: 25px;
    – Result:
  • I forgot this.
    /*Smartphone*/
        #switcher {
        list-style: none;
        margin-left: -80px;
        padding-top: 15px;
    #switcher .fa-fw {
        text-align: center;
        width: 1.25em;
    – Result:
    #32
    @downpw another great addition 👏
  • @downpw another great addition 👏
    #33
    An idea for CSS code for that button (Abandon) after click ?
    @downpw Can you expand on that ?
    #35
    color, background color and after a click on the abandon button
  • color, background color and after a click on the abandon button
    @downpw Ok. Do you have a mock-up in terms of what you’d be looking for ? I think I understand, but it will require jQuery
  • @downpw Ok. Do you have a mock-up in terms of what you’d be looking for ? I think I understand, but it will require jQuery
    #37
    I don’t think so JQuery are necessary becausei hav not that on other themes. Maybe a focus button ?
    I want to fix this color background after a click on “Discard” Button when I reply to a topic.
    For example you don’t have this on sudonix.com
    Just to find the correct CSS code i guess
    I have the same problem on login button
    @downpw Something like this ?
    button.btn.btn-default.composer-discard:focus {
        background: red;
    #39
    Very odd @phenomlab
    alt text
  • Very odd @phenomlab
    alt text
    @downpw Expected, because the CSS class is :focus so on mouseout event, the focus is lost and the CSS will no longer apply. This is why you (probably) need jQuery
  • Upgrade issues
    Use this code git fetch # Grab the latest code from the NodeBB repository git checkout v3.x git reset --hard origin/v3.x And you will have the latest version without specifying it https://docs.nodebb.org/configuring/upgrade/
  • Forum Icons NodeBB
    Solved Customisation icons forum nodebb
    @cagatay That matches what I see [image: 4f0f858d-9812-42b1-9f61-ffb13d31dccd-image.png]
  • Adding fileWrite to nodebb code
  • [NodeBB] Custom fields plugin
    Unsolved Customisation nodebb plugins javascript custom
    @DownPW done
  • [NodeBB] Import custom Font
    Solved Customisation custom fonts nodebb css
    @cagatay you’ll need to define this in the body tag (or another element if you want greater or more granular targets) - for example body { font-family: "Poppins"; font-size: 16px; } Essentially, you use the font-size CSS directive.
  • NodeBB Discord Plugins
  • CSS Help on my Flarum
    @mike-jones Yes, you’ll typically see this type of behaviour if there is another style that has higher priority in the sense that yours will be overridden. Using !important will override the higher preference, but should be used sparingly rather than everywhere.
