258 5 187.2k 3
  • Hello @phenomlab
    I come back here with a little problem.
    I created a donation button in the custom footbar that works well.
    It looks like this with the following code:
    <div id="floatright">
    <div class="d-flex justify-content-center mt-2 mb-2">
        <a href="https://ko-fi.com/K3K519RHI6"
           class="btn btn-primary d-flex align-items-center btn-donation"
           target="_blank">
            <img src="https://storage.ko-fi.com/cdn/logomarkLogo.png"
                 alt="Icône café" class="me-2">
            Faire un don
        </a>
    </div>
    <a class="feedback-menu-far-right" target="_blank" href="/politique">Politique&nbsp;</a>
    However, as soon as I go to a profile page, the users page, the group page, it is broken like this :
    possible to see it on production server
    Any idea to resolve this ?
    @DownPW Looking at the code, it seems to come down to this
    <img src="https://storage.ko-fi.com/cdn/logomarkLogo.png" alt="Icône café" class="me-2 img-fluid">
    If you remove the img-fluid class, it works as intended
    The question is where the img-fluid class is being added.
  • @DownPW Looking at the code, it seems to come down to this
    @phenomlab said in [NODEBB] Help for my custom CSS:
    I don’t know
    Not in the code…
    I don’t explain why this class is added in these pages
    I use this CSS code for control the button in the custom bar :
    .btn-donation {
        font-size: 12px; /* Taille du texte */
        padding: 2px 5px 2px 5px; /* Marges internes pour agrandir le bouton */
        border-radius: 8px; /* Coins arrondis */
        margin-top: -8.8px !important;
        color: #ffffff !important;
    .btn-donation img {
        width: 18px; /* Taille de l’icône */
        height: 16px;
    Find him :
    But I use this code for control image on topics and Shoutbox 😞
    EDIT: I disabled this code and it seems to be OK
    Thanks @phenomlab
    Love your new Glass effect on tittle site.
    Possible to adapt it to my site/share the code ?
  • Hello @phenomlab
    @DownPW Possible, yes, although this particular effect uses CSS only for both the text itself, and the shine rollover. It’s actually quite complex in setup and takes several adjustments to get it to look right.
    It’s also important to understand if you are using this on a logo, or just text?
  • @DownPW Possible, yes, although this particular effect uses CSS only for both the text itself, and the shine rollover. It’s actually quite complex in setup and takes several adjustments to get it to look right.
    just text; logo on the left is separate
  • @phenomlab said in [NODEBB] Help for my custom CSS:
    @DownPW And the hue animation? Or just the glass effect?
    I’d like to try it without HUE to start.
    But I’m always keen to try lots of things 🙂
    You could always explain both to me, so I can apply them separately.
  • I’d like to try it without HUE to start.
    @DownPW Ok. No problems. Let me get back to you. In real life calling presently.
    OK 🙂
    Wait News
    Yeah I also like the looks and effect of the Sudonix logo at the top. Looks very awesome!
    @DownPW coming soon…
  • @DownPW coming soon…
    No problem, I like to annoy you, you know that 🙂
    French expression: He who loves well, chastises well !
    @DownPW I made some final alterations to the master code for this effect, and will release very soon.
    Ohh super ^^
    Thank you Mark
    Hi Mark
    My Homepage did not shown on top.
  • Hi Mark
    @cagatay That looks like you didn’t define a label for the icon. Have a look at /admin/settings/navigation, and you’ll see what I mean
  • Plugin reaction Bug
    Solved Customisation plugin nodebb reaction
    @DownPW That was going to be my next suggestion
  • Bootstrap Version
    Solved Customisation nodebb bootstrap
    @phenomlab That will be nice once they have completed that. It will be interesting to see how long that takes. So for now I will use custom css to make it look the way I want. Frameworks just make things a little faster. Thanks @phenomlab
  • Multiple link on one ico non Navbar
    Solved Customisation links css navbar
    yeah you’re right @phenomlab. Problem of NodeBB Version
  • nodebb-plugin-customize error
    18k Views
    RiekMedia
    @phenomlab it work, thanks
  • NodeBB Design help
  • CSS Help on my Flarum
    @mike-jones Yes, you’ll typically see this type of behaviour if there is another style that has higher priority in the sense that yours will be overridden. Using !important will override the higher preference, but should be used sparingly rather than everywhere.
