NodeBB v3 Android Problem
4 2 1.8k 1
    Hi Mark
    There is a problem with android phones when use nodebb.
    Espically chat is very slow and send button is left side not side.
    How we can fix it?
  • Hi Mark
    How we can fix it?
    @cagatay Add this to your custom CSS
    .input-group {
        flex-wrap: inherit;
  • Hi Mark
    How we can fix it?
    @cagatay you should empty the cache on your phone. I’ve just tested on your site and it works fine.
    The send button position I’ll fix this morning and provide the css.
  • Hi Mark
    How we can fix it?
    .input-group {
        flex-wrap: inherit;
    thank you fixed.
  • Nodebb to Xenforo
  • Threaded post support for NodeBB
    Let's Build It threading nodebb
    146
    50 Votes
    119k Views
    Updated git for above change https://github.com/phenomlab/nodebb-harmony-threading/commit/14a4e277521d83d219065ffb14154fd5f5cfac69
  • Composer options on nodebb
  • Can you adjust Admin settings on your NodeBB?
    @Panda as, yes, now I understand and that makes 100% sense. It means those who get down voted can still have an opinion and use common services. And yes, you’re right. Rather than down vote, just ignore if you don’t agree.
  • NodeBB: hCaptcha
    Solved Configure hcaptcha
    @mventures none that I know of. I don’t recall selecting these either for mine.
  • NodeBB: Consent page
    Solved Configure nodebb consent
    @DownPW I still do not see any issues.
  • CSS codes for fa-info icon
    I have just figured it out… it can be targeted with text-decoration-color: I was mistakenly using color
  • NodeBB metadata
    @phenomlab said in NodeBB metadata: @jac Are you sure ? https://www.google.co.uk/search?q=site%3Astockportcounty.fans&sxsrf=AOaemvLwnaZL-PliU_2dBOg_Eo1pMVhBjg%3A1638982328139&source=hp&ei=uOKwYeatBcOsad3yp7AE&iflsig=ALs-wAMAAAAAYbDwyLBSDcG5XYoFCKwQFhgz94wTxOcV&ved=0ahUKEwjm6dX71NT0AhVDVhoKHV35CUYQ4dUDCAk&uact=5&oq=site%3Astockportcounty.fans&gs_lcp=Cgdnd3Mtd2l6EAM6BAgjECc6CwgAEIAEELEDEIMBOg4ILhCABBCxAxDHARCjAjoRCC4QgAQQsQMQgwEQxwEQowI6BQguEIAEOggIABCABBCxAzoFCAAQgAQ6CAguELEDEIMBOgsILhCABBDHARCvAToICC4QgAQQsQM6BQgAELEDOgsILhCABBDHARDRAzoLCAAQgAQQsQMQyQM6BQgAEJIDUABYySZg0CdoAHAAeACAAW2IAa0NkgEEMjMuMpgBAKABAQ&sclient=gws-wiz Fair enough 🤪🤪.
