the trick is to know which plugin is in question!!
hmmm I don’t thinks so because I have the same problem on NO PRODUCTION VM and I have this bug too without nodebb-imgur-plugin.
I have test with a local url in public nodebb folder and it’s the same too
I test to desactivate all plugin one by one for see at the moment
I think it’s a nodebb issue, because with only one plugin and one theme activate :
- nodebb-plugin-composer-default@9.1.0 (installed, enabled)
- nodebb-theme-persona@12.1.1 (installed, enabled)
Custom CSS, custom JS, custom Header and all custom widgets are disable…
Result it’s the same, I have this bug.
On your dev system, can you test to add a logo for a catégorie, delete the icon and test a new topic in this category ?
I think you will have the same result.
Let me know if you test too !
yes off course I delete it
because if Idon’t delete the icon, she appears on bubble
Open issue here:
https://github.com/NodeBB/NodeBB/issues/10896
If I not delete icon, she’s appear but not the image :
The issue is closed @phenomlab
It’s a nodebb bug. Fixed in 2.5.3 milestone
JS code seems not working but…
I see on ACP, the image of category is uploaded to imgur :
and I see this on dev console :
The url seems to not be encoded correctly, I don’t know why ???
If I change manually the URL in the dev console, it’s OK:
@DownPW said in [NODEBB] Help for my custom CSS:
Sorry, that should have been something like this (obviously modify the source and replacement)
$(document).ready(function() { $(window).on('action:ajaxify.end', function(data) { $(".row").find($(".fa")).removeClass('fa-fw fa-comments-o').addClass('fa-check-to-slot'); }); }); -
hi @phenomlab
on v2.x , I have user online widget in my home page and I can center the widget like this :
because we have a div by default on the widget
I can’t do the same on v3.x
Any idea how to get the same result ?
Thanks Dude
hi @phenomlab
Thanks Dude
Yep, it’s a good idea thanks to you but I’d like to display it without div card-header and body like the first screen
Hello mark
I wanted for test purposes, to put the welcome message in the Brand menu in the header widget.
I commented in the footer widget the corresponding code then I added it in my brand header widget:
<span id="thisuser" class="getUsername">, <a href="/me"><span class="username">DownPW</span></a></span>I commented out the old CSS to add the new:
/* Welcome Message Username on Header */ span#thisuser { margin-top: 0.7rem; margin-left: 2px; margin-right:-2px; font-size: .875rem; line-height: 1.4rem; font-weight: 500; }So far everything is fine, the result is correct :
But as soon as I select links in the left sidebar (home, recent, etc …), the message is added and displayed as many times as I select a link .
Did I miss something or do you have an idea to solve this bug?
Thanks my friend
Hello mark
Thanks my friend
@DownPW sorry for the delay. That is being caused by
ajaxwhich is adding another element each time data is being called. I’d need to see the entire code block where you are adding this to confirm, but from the video you provided, that’s typically caused by the above.You only need that specific function to run once at page load - it’s running each time data is being requested which explains the additions.
it’s just the brand HTML header widget, just add this code to him
<span id="thisuser" class="getUsername">, <a href="/me"><span class="username">DownPW</span></a></span>]What do you want ? The HTML header widget on welcome message JS code ?
EDIT : All code in PM
@DownPW thanks. Can you try a theory for me and change that code so it looks like the below
<span id="thisuserbrand" class="getUsername">, <a href="/me"><span class="username">DownPW</span></a></span>I expect this to return nothing, which will prove my theory around the Ajax calls.
Please help me, I can't install nodebb
Locked Solved Customisation -
[NODEBB] CSS Style Sheets SelectBox
