[NodeBB] Auto assign a label or group title
5 2 2.0k 1
    Hello there 🤞
    I would like to automatically assign a label/or several (group title) for new users with a validated account
    Like this all registered users will have at least one 🙂
    It’s possible to do that ?
    many thanks to the communauty 😉
  • @phenomlab said in [NodeBB] Auto assign a label or group title:
    @DownPW I’m almost positive there used to be a plugin that performed exactly this task, but I can’t seem to locate it within npm. I expect you could (relatively easily) perform this function by listening to the registration hook and leveraging that to add the user to a group programmatically, although this would need some development and testing
    Ok thanks for your answer @phenomlab
    I will rather look for a plugin allowing me to do it because I don’t have time to develop this function.
    I’ll keep you posted on my research 😉
    – >In fact, all my users are already in a group called “all”
    What interests me the most is to automatically assign the group label in the user profile
    @DownPW
    Resolve 🙂
    since all users are in this group by default. I just had to put this group in non-private and check the display of the badge.
    By default, NodeBB displays the user’s default group label unless the user changes it himself
  • Hello there 🤞
  • @DownPW I’m almost positive there used to be a plugin that performed exactly this task, but I can’t seem to locate it within npm. I expect you could (relatively easily) perform this function by listening to the registration hook and leveraging that to add the user to a group programmatically, although this would need some development and testing
    @DownPW
    Resolve 🙂
  • DownPW DownPW marked this topic as a question on
  • DownPW DownPW has marked this topic as solved on
  • @DownPW
    Resolve 🙂
    @DownPW very useful tip. Thanks
  • SEO and Nodebb
    Performance nodebb seo
  • Chevron up before & after
    @crazycells you are right thank you.
  • Title on homepage of nodebb forum
    @eveh Welcome board The code you are referring to is custom written as no such functionality exists under NodeBB. However, adding the functionality is relatively trivial. Below are the required steps Navigate to /admin/appearance/customise#custom-header Add the below code to your header, and save once completed <ol id="mainbanner" class="breadcrumb"><li id="addtext">Your Title Goes Here</li></ol> Navigate to /admin/appearance/customise#custom-js and add the below code, then save $(document).ready(function() { $(window).on('action:ajaxify.end', function(data) { // Initialise mainbanner ID, but hide it from view $('#mainbanner').hide(); var pathname = window.location.pathname; if (pathname === "/") { $("#addtext").text("Your Title"); $('#mainbanner').show(); } else {} // If we want to add a title to a sub page, uncomment the below and adjust accordingly //if (pathname === "/yourpath") { //$("#addtext").text("Your Title"); //$('#mainbanner').show(); //} }); }); Navigate to /admin/appearance/customise#custom-css and add the below CSS block .breadcrumb { right: 0; margin-right: auto; text-align: center; background: #0086c4; color: #ffffff; width: 100vw; position: relative; margin-left: -50vw; left: 50%; top: 50px; position: fixed; z-index: 1020; } Note, that you will need to adjust your CSS code to suit your own site / requirements.
  • NodeBB slow after DB recovery
    Solved Performance performance nodebb
  • [NODEBB] Scroll Button
  • RSS parser script [NodeBB]
    Customisation nodebb rss script
    24k Views
    @phenomlab said in RSS parser script [NodeBB]: @jac Not yet. Sorry. Have some other work commitments I need to prioritise. Hoping to get to this over the weekend. No worries at all mate, thanks
  • unable to upvote on forum
    Solved Performance
    @phenomlab yes, i can understand. it is working now
