Post Style View
67 3 35.2k 2
  • @cagatay in case you’re still following this thread, I found a far more efficient way of adding the classes using jQuery. To this end, you can change this block above with this code
    // Target those elements already loaded in the DOM
            $('li[component="post"]').each(function(i, obj) {
                if (!$(this).hasClass('self-post') || (!$(this).hasClass('self-post'))) {
                    console.log("Adding required classes for messenger type view");
                    $(this).addClass('topic-response-post');
    // Target elements dynamically added to the DOM on post load
        $(window).on('action:ajaxify.loaded', function(data) {
    @phenomlab said in Post Style View:
    $(window).on(‘action:ajaxify.end’, function(data) {
    $(‘li[component=“post”]’).each(function(i, obj) {
    if (!$(this).hasClass(‘self-post’) || (!$(this).hasClass(‘self-post’))) {
    console.log(“Adding required classes for messenger type view”);
    $(this).addClass(‘topic-response-post’);
    $(window).on(‘action:ajaxify.loaded’, function(data) {
    thank you Mark.
    changed it.
    @phenomlab there is small problem after revised codes which you shared.
    problem is shown below; answered nick and labels nested.
  • @phenomlab there is small problem after revised codes which you shared.
    @cagatay that’s just a margin missing. The code I provided won’t be causing that. If you look for the element in the developers console and add a margin-left value to it, that should resolve it.
  • @cagatay that’s just a margin missing. The code I provided won’t be causing that. If you look for the element in the developers console and add a margin-left value to it, that should resolve it.
    @phenomlab may i use this code?
    .topic-owner-post [itemprop="author"] {
        float: left;
    // Add these to (or edit) the existing classes you have
    .user-level-topic {
        float: none;
    .group-label {
        margin-top: -1px;
    .topic-owner-post [itemprop="author"]:after {
        margin-top: 1px;
        height: 18px;
  • @phenomlab may i use this code?
        float: left;
    .user-level-topic {
        float: none;
    .group-label {
        margin-top: -1px;
        margin-top: 1px;
        height: 18px;
    @cagatay from the screenshot you provided, it looks like you’ve used them. They are fine to use, but you are missing a couple of styles.
    I’ll have a look at this tomorrow and give you the remainder of the code you need.
  • @cagatay from the screenshot you provided, it looks like you’ve used them. They are fine to use, but you are missing a couple of styles.
    @phenomlab i cant fix it 😞
  • @phenomlab i cant fix it 😞
    #67
    @cagatay
    Just add margin-left on the element like @phenomlab said to you :
    topic [component="post/parent"] {
        margin-left: 10px;
    Maybe @phenomlab have a better way
  • Custom badges
    60k Views
    Perfect
  • Q&A Plugin Changes NodeBB
    Solved Customisation nodebb q&a plugin
    @phenomlab said in Q&A Plugin Changes NodeBB: float: right; left: 10px; } worked thank you
  • Bootstrap Version
    Solved Customisation nodebb bootstrap
    @phenomlab That will be nice once they have completed that. It will be interesting to see how long that takes. So for now I will use custom css to make it look the way I want. Frameworks just make things a little faster. Thanks @phenomlab
  • [NodeBB] First post customization
    @phenomlab thanks
  • NodeBB - Created pages not found?
    @jac Exactly. Hard point to argue.
  • nodebb dropdown menu
  • NodeBB Design help
