Post Style View
67 3 35.2k 2
  • @cagatay Good. Keep an eye on that though - as I said, it may produce unexpected results as it’s quite “greedy”
    @phenomlab If the post is new one created by me, there is also shown 🙂
    @phenomlab said in Post Style View:
    Yes i know dear, it is a no problem for me, i m learning with you thats cool.
  • @phenomlab If the post is new one created by me, there is also shown 🙂
    #22
    @cagatay This is a bit experimental currently, but the below jQuery should detect correctly when the HTML being targeted has no class.
    Can you please try replacing the below you previously inserted
    $(window).on('action:ajaxify.loaded', function(data) {
            if (!$('li[component="post"]').hasClass('.topic-owner-post') || (!$('li[component="post"]').hasClass('.self-post'))) {
                console.log("Adding required classes for messenger type view");
                $('li[component="post"]').addClass('topic-response-post');
    with
    // Target those elements already loaded in the DOM
            if ($('li[component="post"]').hasClass("")) {
    // Target elements dynamically added to the DOM on post load
    Try it and let me know.
  • @cagatay This is a bit experimental currently, but the below jQuery should detect correctly when the HTML being targeted has no class.
    with
    @phenomlab nothing changed for first owner post;
  • @phenomlab nothing changed for first owner post;
    @cagatay Is that with or without the new functions I provided, or with both ?
  • @cagatay Is that with or without the new functions I provided, or with both ?
    @phenomlab css side;
    @media (min-width: 1200px) {
    li.topic-owner-post .content, li.topic-response-post .content {
        background: PowderBlue;
        padding: 30px;
        border-radius: 6px;
    .topic .posts.timeline .timeline-event>div:not(.content), .topic .posts.timeline>[component=post]>div:not(.content) {
        margin-left: 2.5rem;
    [data-index="0"] .content[component="post/content"]:before, .topic-owner-post:before, .topic-response-post:before {
        border-left: 20px solid transparent;
        border-top: 20px solid PowderBlue;
        top: 66px;
        content: "";
        position: absolute;
        left: 70px;
    li.self-post .content:not(.isSolved [component="post/content"])[itemprop="text"] {
        background: CadetBlue;
        padding: 30px;
        border-radius: 6px;
        margin-right: 8.5rem !important;
    li.self-post .content:not(.isSolved [component="post/content"]):after, li.self-post.topic-owner-post:first-child:after {
        border-right: 20px solid transparent;
        border-top: 20px solid var(--self-post);
        top: 66px;
        content: "";
        position: absolute;
        right: 90px;
        left: unset !important;
        border-bottom: none !important;
        bottom: unset !important;
    li.self-post.topic-response-post .pull-left {
        float: right !important;
        border-top: 20px solid CadetBlue;
        top: 58px;
        content: "";
        position: absolute;
        right: 95px;
    li.self-post.topic-response-post:before {
        display: none;
    JS side;
  • @phenomlab css side;
        padding: 30px;
        border-radius: 6px;
        top: 66px;
        content: "";
        position: absolute;
        left: 70px;
        padding: 30px;
        border-radius: 6px;
        top: 66px;
        content: "";
        position: absolute;
        right: 90px;
        top: 58px;
        content: "";
        position: absolute;
        right: 95px;
        display: none;
    JS side;
    #26
    @cagatay Let me have a look
    EDIT - I see it. Find class
    change it to
    So basically, just remove
    That should do it
  • @cagatay Let me have a look
    change it to
    That should do it
    [data-index=“0”] .content[component=“post/content”]:before, .topic-owner-post:before, .topic-response-post:before
    I did, everything looks like well 🙂 thank you.
    See you again when i see minor problem 🙂
  • @phenomlab said in Post Style View:
    @cagatay said in Post Style View:
    🙂 Looking forward !
  • @cagatay said in Post Style View:
    🙂 Looking forward !
    #29
    @phenomlab When I post something to the thread, my avatar can be seen on the left side of the post. However, when I refresh the page, avatar goes to the right side.
    before f5;
    after f5;
    That’s odd. It looks like the specific class that controls they isn’t being loaded until you perform a hard refresh. I’ll need to have a look at your site to determine why that is.
  • That’s odd. It looks like the specific class that controls they isn’t being loaded until you perform a hard refresh. I’ll need to have a look at your site to determine why that is.
    @phenomlab the problem still persist, did you have a look?
  • @phenomlab the problem still persist, did you have a look?
    @cagatay Not yet 🙂 Will do so today
  • @cagatay Not yet 🙂 Will do so today
    @phenomlab Sorry for waste one’s your time.
    #34
    @phenomlab new miror problem is when i created new topic the codes are figure out not working. After F5 also…
    Maybe we can change the codes just for different color for user not right side avatar etc.
  • cagatay cagatay has marked this topic as unsolved on
  • @phenomlab new miror problem is when i created new topic the codes are figure out not working. After F5 also…
    @cagatay I’ll have a look at this tomorrow. However, this is the reason why I said to do this in a DEV environment 👍
  • @cagatay I’ll have a look at this tomorrow. However, this is the reason why I said to do this in a DEV environment 👍
    @phenomlab users dont feel anything hope so 🙂 but i think this way which i m saying easy then current one which you are using in sudonix.
    my suggest that; just change color type without changing side metod mean right side…
  • @phenomlab users dont feel anything hope so 🙂 but i think this way which i m saying easy then current one which you are using in sudonix.
    @cagatay yep, I’ll take a look at this tomorrow and we’ll get it resolved.
  • @cagatay yep, I’ll take a look at this tomorrow and we’ll get it resolved.
    @phenomlab thank you waiting your free time 😊 👍
  • @phenomlab thank you waiting your free time 😊 👍
    @cagatay Should look a bit better now - just finishing up the jQuery code as that is not firing properly. Let me know
  • @cagatay Should look a bit better now - just finishing up the jQuery code as that is not firing properly. Let me know
    @phenomlab yes i entered new topic and new post, seems everything is working great. thanks Mark…
