is "night mode" shifting the forum several pixels up?
8 2 2.6k 1
    I was observing this in our forum for a very long time. Since nodebb community forum does not have night mode installed, I was not able to check there. However, if I click the night mode here, it looks like everything (including boxes, writings, bars, avatars, icons etc) is shifted a little bit up… It is only several pixels I guess, but definitely I can feel a difference before/after…
    Do you observe this or am I hallucinating? 😵 🤔
  • @phenomlab good to hear that I am not alone… 😄
    I do not know the reason for sure yet, but I will report here if I can find a clue…
    @crazycells Should be fixed now. Was being caused by some missing margins (left and right) and an odd border: none; setting which should not have been there. If you alternate between the two now, it should look correct.
  • I was observing this in our forum for a very long time. Since nodebb community forum does not have night mode installed, I was not able to check there. However, if I click the night mode here, it looks like everything (including boxes, writings, bars, avatars, icons etc) is shifted a little bit up… It is only several pixels I guess, but definitely I can feel a difference before/after…
    @crazycells no, you’re not hallucinating. I’ve noticed this myself and need to fix it. I’m suspecting rogue padding or margin somewhere.
  • @crazycells no, you’re not hallucinating. I’ve noticed this myself and need to fix it. I’m suspecting rogue padding or margin somewhere.
  • @crazycells Should be fixed now. Was being caused by some missing margins (left and right) and an odd border: none; setting which should not have been there. If you alternate between the two now, it should look correct.
    @phenomlab yes, it is fixed. is this the code I should use?
    body.lights-out {
    border: none;
  • @phenomlab yes, it is fixed. is this the code I should use?
    body.lights-out {
    border: none;
    @crazycells You should actually remove the border: none;
  • @crazycells You should actually remove the border: none;
    @phenomlab said in is "night mode" shifting the forum several pixels up?:
    how can I remove it?
    Should I edit the plugin and install the modified one?
  • @phenomlab said in is "night mode" shifting the forum several pixels up?:
    @crazycells hmm. Good point. I actually use my own version of the dark mode plugin, so not entirely sure. However, I think the CSS is probably the same. I’m not at my PC currently but can check and advise later.
  • What plugins are being used here on Sudonix?
    Solved General nodebb plugins development
    @Roki-Antic Welcome! This site isn’t running Persona, but Harmony - a very heavily customised version at that. Do you have a URL where your site is currently located that is publicly accessible? Feel free to PM this info if you do not want to disclose here. Happy to help with any customisation needs.
  • Bug in Nodebb route when clicking title
    Moved Configure nodebb
    Panda
    Ah silly me, thanks for finding that!
  • Nodebb design
  • Nodebb 3.2.0
    Bugs nodebb nodebb 3.2.0
    @crazycells yes, I’m aware of that. Need to fix EDIT- fixed. Caused by the same CSS that is used to absolutely position the “verified” group badge in the posts view. Amended this CSS so that is specifically targets the post stream as below li[component="post"] a[href*="/groups/verified"] { position: absolute !important; left: 8px; z-index: 2; margin-top: 1px; border-radius: 999px !important; line-height: 14px; display: block; height: 22px; margin-left: 0px !important; }
  • Upgrade Problem from 2.8.3 to 2.8.4
    @cagatay No, you can ignore that.
  • who is read NodeBB
  • background color of the footer area
    @phenomlab thank you very much
