MailGun Not Working NodeBB
Hi
I setted mail server as mailgun.
But forum not sending registered email .@cagatay said in MailGun Not Working NodeBB:
Hi
But forum not sending registered email .022-11-04T13:07:20.734Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:08:50.302Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:08:50.302Z [4568/172189] - [31merror[39m: admin.user.sendValidationEmail Error: Email sending failed for the following uids, check server logs for more info: 5 at User.sendValidationEmail (/home/nojor/nodebb/src/socket.io/admin/user.js:91:9) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at async onMessage (/home/nojor/nodebb/src/socket.io/index.js:160:19) 2022-11-04T13:12:42.634Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:12:42.634Z [4568/172189] - [31merror[39m: admin.user.sendValidationEmail Error: Email sending failed for the following uids, check server logs for more info: 5 at User.sendValidationEmail (/home/nojor/nodebb/src/socket.io/admin/user.js:91:9) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at async onMessage (/home/nojor/nodebb/src/socket.io/index.js:160:19) -
Hi
But forum not sending registered email .022-11-04T13:07:20.734Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:08:50.302Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:08:50.302Z [4568/172189] - [31merror[39m: admin.user.sendValidationEmail Error: Email sending failed for the following uids, check server logs for more info: 5 at User.sendValidationEmail (/home/nojor/nodebb/src/socket.io/admin/user.js:91:9) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at async onMessage (/home/nojor/nodebb/src/socket.io/index.js:160:19) 2022-11-04T13:12:42.634Z [4568/172189] - [31merror[39m: [user.create] Validation email failed to send [emailer.send] Error: Invalid login: 535 Authentication failed at SMTPConnection._formatError (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._actionAUTHComplete (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:1536:34) at SMTPConnection.<anonymous> (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:540:26) at SMTPConnection._processResponse (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:947:20) at SMTPConnection._onData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:749:14) at TLSSocket.SMTPConnection._onSocketData (/home/nojor/nodebb/node_modules/nodemailer/lib/smtp-connection/index.js:189:44) at TLSSocket.emit (events.js:400:28) at addChunk (internal/streams/readable.js:293:12) at readableAddChunk (internal/streams/readable.js:267:9) at TLSSocket.Readable.push (internal/streams/readable.js:206:10) 2022-11-04T13:12:42.634Z [4568/172189] - [31merror[39m: admin.user.sendValidationEmail Error: Email sending failed for the following uids, check server logs for more info: 5 at User.sendValidationEmail (/home/nojor/nodebb/src/socket.io/admin/user.js:91:9) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at async onMessage (/home/nojor/nodebb/src/socket.io/index.js:160:19)@cagatay said in MailGun Not Working NodeBB:
The clue is in the error message
Error: Invalid login: 535 Authentication failedYou should check the username and password.
@phenomlab it should be created by mailgun or my mail is also working yandex.
that user and pass yandex mail but service mailgun how can i fix it i do not know.
@phenomlab did it
i did not create smtp user on mailgun. everything is working now.
cagatay has marked this topic as solved on
NodeBB: Creating pages
Solved Configure -
Gettin Erors NodeBB
Solved Configure -
Podcast Share NodeBB
Solved Configure -
