Issue with platform stability
1 1 765
    I’m pleased to report that the issues with stability have been resolved. For no apparent reason, the platform’s underlying technologies suddenly refused to start and restart on demand, so a temporary fix was needed to provide a “band-aid” for this issue until we could find the root cause.
    After significant research, and with the assistance of NodeBB themselves (special thanks to @gotwf), instead of ./nodebb start we are now using a systemd service.
    This has resolved the issue. We continue to monitor site stability and will advise if any further action is required.
  • Ch..ch..ch..ch..changes!
    Announcements themes layout
  • ANNOUNCEMENT: Social Login Changes
    Announcements openid oauth
    @DownPW Always looking for ways to improve the overall experience.
  • ANNOUCEMENT: New NTFY Server
    Announcements ntfy push alerts
    @crazycells that’s as good a test as any
  • Theme retirement
    Announcements themes switcher
  • Clustering for NodeBB enabled
    Announcements cluster
    @Madchatthew True. I think this is the reason as to why most Open Source projects are abandoned because they are not sustainable in the long-term.
  • Testing out Webdock.io
    Moved Announcements webdock recovery speed
    Just coming back to this thread for review (as I often do), and it looks like Webdock have increased their available offerings - some are extremely powerful, yet very competitive from the pricing perspective. [image: image.png] 10 CPU cores, plus 20Gb RAM? Well worth a look (and the asking price) - there’s also a fixed IP which is hugely beneficial. Clearly, this is well beyond what most people will want to spend - it’s more of an example (but interestingly, Sudonix runs on something not too different from the above). However, not all that glitters is gold - just have a walk through the benchmark report I found below and you’ll see a huge difference between Heztner and Webdock https://www.vpsbenchmarks.com/compare/hetzner_vs_webdock That being said, the amount of HTTP requests that Webdock handles in relation to Hetzner is superior - @DownPW you might want to have a look at this - there’s a free 24 hour trial… [image: 5203639b-2f62-47e6-b87b-37580ce5deae-image.png]
  • PWA support for Sudonix Platform
    Announcements pwa
    @crazycells Yes, you should install the app that is offered when you access the site. I’ve had mixed experiences with this though. It seems to work fine with Chrome and Firefox, but it’s a bit hit and miss with Apple devices because of their closed ecosystem, and the inability to access the push service directly. Android is completely different in the sense that the service is open for usage, meaning hooking into the pusher is simple. For Apple, it is closed source, so probably won’t work.
