Tips for custom colors for forum categories
Hi @phenomlab , as I can see, you are expanding the color selection on this forum… and additionally, more are coming as I can tell from here https://sudonix.dev
However, I see that you do not use color tones that are compatible with each other. Some are way more vibrant than others. I recommend using this website below for color picking:
https://www.materialpalette.com/colors
You can pick any color, but it would look way better if colors belong to the same tone range… for example, if you pick 300 for green, use 300 for other colors too… Overall, using the same tone for different colors will create more aesthetically pleasant pages…
@crazycells not sure I understand. The colour schemes on sudonix.dev are part of the NodeBB harmony theme (they are actually taken directly from bootswatch) and aren’t created by me.
The Swatch colours in use in this site are my creation - is that what you are referring to ?
@phenomlab said in Tips for custom colors for forum categories:
Yes, unfortunately, NodeBB picks colors arbitrarily, but they are easily editable at ACP. I can see your category colors from “recent cards”…
Here on this website, I can see that on the main page, you go with the same color. On dev, it is more colorful.
I suggest you pick the colors according to their tones.
@crazycells said in Tips for custom colors for forum categories:
I suggest you pick the colors according to their tones.That’s because the swatches here are based on the appearance of established themes in use by Facebook, YouTube, etc - the categories are supposed to be one colour.
Yes
I am not arguing why you did that. I am just telling that the colors that are being used currently for categories are not compatible with each other, so they do not look in harmony…Please see the colors of various categories here:
So, if you pick colors according to their “tones” , the page will look much better
Yes
@crazycells I agree, but with a (large) caveat
As my site uses a swatch changer, this alters the colour scheme. Given that the colours for categories are set in the ACP, this doesn’t lend itself very well to changing the colours dynamically when the theme changes.
Admittedly, I could use wildcard targets I suppose…
Yes
@crazycells Actually, this has piqued my interest. I think this deserves a bit more thought, time, and ultimately, should be included in the themes I am developing.
Thanks !
Thanks !
@crazycells
I’ll change that
Edit - done. -
@crazycells
I’ll change that
Edit - done.
Rank icons
Moved Resources -
