Forum Statistics Box
5 2 2.2k 1
    HI All,
    How yours looks 🙂
    Best way that I am able to change that ? Change font size.
    Thank you 🙂
  • HI All,
    How yours looks 🙂
    Thank you 🙂
    @Sampo2910 Try this
    .row.forum-stats {
        padding: 10px;
        margin-top: -25px;
        margin-bottom: -25px;
        margin-left: auto;
        margin-right: auto;
    .row.forum-stats small {
        font-size: 50%;
  • @Sampo2910 Try this
    .row.forum-stats {
        padding: 10px;
        margin-top: -25px;
        margin-left: auto;
        margin-right: auto;
        font-size: 50%;
    As you can see a new forum 🙂
    I am wondering about this custom CSS though. Noob Question coming up 🙂 ss2.png
    As you see I put your code in and all good. What happens when i want to put more in? Goes underneath in new thread. ? Say i wanted new theme for example or again something like this?
    Thx as always.
  • Sampo2910 Sampo2910 has marked this topic as solved on
    Thx as always.
    @Sampo2910 said in Forum Statistics Box:
    Yes, exactly that
    Thx as always.
    Yes, exactly the same process.
  • Forum customisation
  • Heading text on NodeBB forum
    @mventures I’ve not done anything here.
  • Tips for custom colors for forum categories
    Resources colours customization
    @phenomlab much better [image: Screen Shot 2023-02-04 at 19.37.50.png] [image: read]
  • Forum Icons NodeBB
    Solved Customisation icons forum nodebb
    @cagatay That matches what I see [image: 4f0f858d-9812-42b1-9f61-ffb13d31dccd-image.png]
  • Title on homepage of nodebb forum
    @eveh Welcome board The code you are referring to is custom written as no such functionality exists under NodeBB. However, adding the functionality is relatively trivial. Below are the required steps Navigate to /admin/appearance/customise#custom-header Add the below code to your header, and save once completed <ol id="mainbanner" class="breadcrumb"><li id="addtext">Your Title Goes Here</li></ol> Navigate to /admin/appearance/customise#custom-js and add the below code, then save $(document).ready(function() { $(window).on('action:ajaxify.end', function(data) { // Initialise mainbanner ID, but hide it from view $('#mainbanner').hide(); var pathname = window.location.pathname; if (pathname === "/") { $("#addtext").text("Your Title"); $('#mainbanner').show(); } else {} // If we want to add a title to a sub page, uncomment the below and adjust accordingly //if (pathname === "/yourpath") { //$("#addtext").text("Your Title"); //$('#mainbanner').show(); //} }); }); Navigate to /admin/appearance/customise#custom-css and add the below CSS block .breadcrumb { right: 0; margin-right: auto; text-align: center; background: #0086c4; color: #ffffff; width: 100vw; position: relative; margin-left: -50vw; left: 50%; top: 50px; position: fixed; z-index: 1020; } Note, that you will need to adjust your CSS code to suit your own site / requirements.
  • Link vs Refresh
    Solved Customisation nodebb blog customization
    is there any way to see whose reputation is changed by this plugin?
  • Adjusting the size of boxes in posts-list class
    @phenomlab thanks a lot, this combination works best .posts-list .posts-list-item .content { overflow: auto; max-height: 600px; }
