Recent Cards - fix for slider on mobile not working
Customisation
23 3 10.3k 1
  • @phenomlab I changed the code to this:
    window.addEventListener("load", () => {
        // CHROME
        if (navigator.userAgent.indexOf("Chrome") != -1) {
            console.log("Google Chrome");
                $('.carousel-mode').bxSlider({
                    auto: true,
                    autoControls: true,
                    stopAutoOnClick: true,
                    pager: false,
                    keyboardEnabled: true,
                    touchEnabled: false
        } else {
            console.log("Others");
                    auto: true,
                    autoControls: true,
                    pager: false,
                    touchEnabled: true
    with “auto: false” edit…
    and it is still working with firefox and safari; but not with google chrome.
    @crazycells That’s correct. Because of the bug in Chrome, we have to disable touchEnabled
    great topic, I will test than soon as possible 😉
  • great topic, I will test than soon as possible 😉
    @DownPW No issues. Thanks to the Google Chrome “bug”, it does have some restrictions, but works fine other than that. I have an odd issue where it doesn’t work on Firefox mobile, but works fine on Firefox desktop.
    Very great
  • NodeBB recent cards customisation
    Solved Customisation nodebb recent cards
    @phenomlab thank you very much for the assistance Mark, massively appreciated as always. The great thing about this is it’s all documented for other NodeBB users that come looking for solutions . Looks far better .
  • navigation menu panel on mobile
    Solved Customisation nodebb css
    @crazycells hmm. That’s odd. I haven’t made any changes from recollection but I could be wrong. I’ll need to check. EDIT - very strange. I honestly don’t recall adding the below CSS block to alter the bottom bar, but you’re right… .bottombar-nav { padding: 0px !important; } I’ve removed this so it reflects stock Harmony.
  • Whitespace fixes in Nodebb
  • Link Not Working
    Solved Customisation link
    @cagatay Good question, but one that’s likely best answered by the devs themselves. Could easily be done with a simple jQuery regex but that would really just be painting over rotten wood.
  • How to fix size of photos & videos NodeBB
    Solved Customisation nodebb nodebb size
    @crazycells pleasure. Using percentages makes much more sense in this case. It’s the same argument with px vs pt vs em with fonts, margins, padding, etc., in the sense that em is generally preferred over px and pt https://stackoverflow.com/questions/609517/why-em-instead-of-px
  • [NodeBB] username cards
    @phenomlab Aha…nice to know. As always thank you for the reply and information.
  • Which mobile internet app and browser do you use?
    General browser mobile
    @Sala Yes, I personally use Edge. Hated Internet Exploder (misspell intentional) but seeing as Edge is Chromium and Webkit backed, it works for me.
