nodebb-plugin-reactions not working @v1.0.2 with Harmony theme
47 3 15.8k 1
  • @phenomlab I gave up on this yesterday
    @dave1904 Ok. I’ll login again later and take a look at this. I still think it’s related to dependencies.
  • @dave1904 I’ve managed to resolve this issue - see below
    It seems that there is a conflicting plugin somewhere that causes reactions to not fire. Not sure which one it is, but below are the steps I took to resolve
    1. Issue ./nodebb reset -t - this essentially resets everything back to default - be warned, as it will strip literally all customisations also
    2. Reactivate only the essential plugins (typically those that come with the stock installation)
    3. Install and activate nodebb-plugin-emoji, nodebb-plugin-emoji-android and @nodebb/nodebb-plugin-reactions@latest
    4. Rebuild and restart
    Obviously, these steps are quite dramatic and would mean some downtime for your forum. You’d also need to put everything back the way it was in terms of CSS, Widgets, etc, so quite invasive. My suggestion would be to try a minimal approach on prod to see if we can get that to work without having to use the somewhat “sledgehammer” approach above.
  • phenomlabundefined phenomlab has marked this topic as solved on
  • Again, thank you very much for taking your time. Very happy that you could fix it. 🙂 I guess the minimal approach would be to deactivate plugins one after another, rebuild and restart and see if the reactions plugin works?
    @dave1904 yes, that’s the route I would take.
  • @dave1904 yes, that’s the route I would take.
    I will try this later and keep you updated.
    @dave1904 any update? More to the point, so you need any help?
  • @dave1904 any update? More to the point, so you need any help?
    At the moment I try it the other way around so avoid downtime on prod: Activating plugins on dev to see if reactions stops working. Will keep you updated!
    @dave1904 ok but I think you might need the steps I provided in previous posts in this thread.
  • @phenomlab A complete reset feels a bit like an overkill for one plugin not working which, as julian I think mentioned, could be re-developed soon. But the plugin keeps active on dev, even after activating many plugins again.
    @dave1904 said in nodebb-plugin-reactions not working @v1.0.2 with Harmony theme:
    Yes, I agree, but I didn’t mean that - sorry.
    What I meant was using
    npm config set legacy-peer-deps true
    On prod and running the /nodebb upgrade to see if that helps.
  • @dave1904 said in nodebb-plugin-reactions not working @v1.0.2 with Harmony theme:
    @phenomlab Thanks for reminding me on this one. I just tried that but still no success.
  • @phenomlab Thanks for reminding me on this one. I just tried that but still no success.
    @dave1904 what was the output of the upgrade? Did it complain about any missing dependencies?
  • @dave1904 what was the output of the upgrade? Did it complain about any missing dependencies?
    I couldn’t see that:
    Updating NodeBB...
    1. Updating package.json file with defaults...  OK
    2. Bringing base dependencies up to date...  started
    up to date, audited 1113 packages in 7s
    131 packages are looking for funding
      run `npm fund` for details
    13 vulnerabilities (7 moderate, 6 high)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    3. Checking installed plugins for updates...Checking installed plugins and themes for updates...   OK
    A total of 1 package(s) can be upgraded:
      * nodebb-plugin-question-and-answer (1.0.17 -> 1.0.18)
    Proceed with upgrade (y|n)? y
    Upgrading packages...
    4. Updating NodeBB data store schema...
    Parsing upgrade scripts...
    OK | 0 script(s) found, 125 skipped
    Schema update complete!
    5. Rebuilding assets...  started
    2023-05-01T21:02:24.095Z [4567/261222] - info: [build] Building in series mode
    2023-05-01T21:02:24.096Z [4567/261222] - info: [build]         plugin static dirs  build started
    2023-05-01T21:02:24.105Z [4567/261222] - info: [build]         plugin static dirs  build completed in 0.009sec
    2023-05-01T21:02:24.106Z [4567/261222] - info: [build]          requirejs modules  build started
    2023-05-01T21:02:24.254Z [4567/261222] - info: [build]          requirejs modules  build completed in 0.148sec
    2023-05-01T21:02:24.254Z [4567/261222] - info: [build]           client js bundle  build started
    2023-05-01T21:02:24.259Z [4567/261222] - info: [build]           client js bundle  build completed in 0.005sec
    2023-05-01T21:02:24.260Z [4567/261222] - info: [build]            admin js bundle  build started
    2023-05-01T21:02:24.261Z [4567/261222] - info: [build]            admin js bundle  build completed in 0.001sec
    2023-05-01T21:02:24.261Z [4567/261222] - info: [build]         client side styles  build started
    Deprecation Warning on line 68, column 52 of node_modules/bootswatch/dist/flatly/_variables.scss:
    !default should only be written once for each variable.
    This will be an error in Dart Sass 2.0.0.
    68 │ $nav-link-padding-y:                .5rem !default !default;
    Deprecation Warning on line 70, column 56 of node_modules/bootswatch/dist/flatly/_variables.scss:
    70 │ $nav-link-disabled-color:           $gray-600 !default !default;
    2023-05-01T21:02:30.523Z [4567/261222] - info: [build]         client side styles  build completed in 6.262sec
    2023-05-01T21:02:30.524Z [4567/261222] - info: [build] admin control panel styles  build started
    2023-05-01T21:02:35.223Z [4567/261222] - info: [build] admin control panel styles  build completed in 4.698sec
    2023-05-01T21:02:35.226Z [4567/261222] - info: [build]                  templates  build started
    2023-05-01T21:02:36.223Z [4567/261222] - info: [build]                  templates  build completed in 0.997sec
    2023-05-01T21:02:36.223Z [4567/261222] - info: [build]                  languages  build started
    2023-05-01T21:02:39.308Z [4567/261222] - info: [build]                  languages  build completed in 3.085sec
    2023-05-01T21:02:39.309Z [4567/261222] - info: [build] Bundling with Webpack.
    2023-05-01T21:03:07.379Z [4567/261222] - info: [build] Bundling took 23607 ms
    2023-05-01T21:03:07.394Z [4567/261222] - info: [build] Asset compilation successful. Completed in 43.284sec.
                                                NodeBB Upgrade Complete!
    Updating NodeBB...
      npm audit fix
    @dave1904 yes, that looks clean. On prod, could you provide the output of
    ./nodebb plugins
    I’m specifically interested in the version numbers of the emoji and reactions plugins. However, as dev is a replica of prod, I suspect the same “fix” (as heavy handed as it is) is needed for prod.
    However, I do agree that this approach isn’t desirable for obvious reasons.
  • Yes, I also have that bad feeling only reset would help. Anyway here is the output:
    Active plugins:
            * @nodebb/nodebb-plugin-reactions@1.0.2 (installed, enabled)
            * nodebb-plugin-2factor@7.0.5 (installed, disabled)
            * nodebb-plugin-beep@0.4.7 (installed, disabled)
            * nodebb-plugin-composer-default@10.0.48 (installed, enabled)
            * nodebb-plugin-contact-page@1.3.0 (installed, disabled)
            * nodebb-plugin-custom-pages@2.0.3 (installed, enabled)
            * nodebb-plugin-customize@3.0.0 (installed, disabled)
            * nodebb-plugin-dbsearch@6.0.0 (installed, enabled)
            * nodebb-plugin-email-blacklist@2.0.0 (installed, disabled)
            * nodebb-plugin-emoji@5.0.6 (installed, enabled)
            * nodebb-plugin-emoji-android@4.0.0 (installed, disabled)
            * nodebb-plugin-emoji-one@4.0.0 (installed, enabled)
            * nodebb-plugin-emoji-vital@4.0.0 (installed, disabled)
            * nodebb-plugin-markdown@12.0.2 (installed, enabled)
            * nodebb-plugin-mentions@4.1.0 (installed, enabled)
            * nodebb-plugin-newsletter@0.10.2 (installed, disabled)
            * nodebb-plugin-night-mode@1.0.7 (installed, disabled)
            * nodebb-plugin-ns-likes@3.0.0 (installed, disabled)
            * nodebb-plugin-ntfy@1.0.15 (installed, disabled)
            * nodebb-plugin-poll@3.0.4 (installed, enabled)
            * nodebb-plugin-question-and-answer@1.0.18 (installed, enabled)
            * nodebb-plugin-recent-cards@3.1.11 (installed, enabled)
            * nodebb-plugin-shoutbox@2.0.4 (installed, disabled)
            * nodebb-plugin-spam-be-gone@2.0.6 (installed, enabled)
            * nodebb-plugin-tenor-gif@3.0.0 (installed, enabled)
            * nodebb-plugin-youtube-embed@0.6.9 (installed, enabled)
            * nodebb-rewards-essentials@0.2.3 (installed, enabled)
            * nodebb-theme-harmony@1.0.1 (installed, enabled)
            * nodebb-theme-lavender@7.0.9 (installed, disabled)
            * nodebb-theme-peace@2.0.19 (installed, disabled)
            * nodebb-theme-persona@13.0.56 (installed, disabled)
            * nodebb-theme-slick@2.0.2 (installed, disabled)
            * nodebb-theme-vanilla@12.1.19 (installed, disabled)
            * nodebb-widget-essentials@7.0.9 (installed, enabled)
            * nodebb-widget-ns-stats@3.0.0 (installed, disabled)
  • Instead of a complete reset, would you be open to disabling all plugins apart from the stock ones, plus emoji, emoji android, and reactions?
    Obviously you’ll need to perform a rebuild and restart.
  • Do you know if I would have to reconfigure all the disabled plugins?
    @dave1904 no, that won’t be necessary. Disabling them means that they won’t be loaded, but will keep their settings.
  • @dave1904 no, that won’t be necessary. Disabling them means that they won’t be loaded, but will keep their settings.
    @phenomlab Yes I just thought I could have checked that myself on dev 😄 Yes I would try that but is there a list of the stock plugins?
  • @phenomlab Yes I just thought I could have checked that myself on dev 😄 Yes I would try that but is there a list of the stock plugins?
    @dave1904 umm. That’s a good question. I’m not sure there is. Let’s start with the below
    nodebb-plugin-emoji
    If reactions starts playing ball, then we enable the other extensions.
