Upload Problem
17 2 4.5k 1
  • Custom Page - nodebb
    I’m happy to see this
  • External Links - New Window
    Solved Customisation nodebb links settings
  • Please help me, I can't install nodebb
    Locked Solved Customisation nodebb
    Installation completed, verified, and tested. Correct installation methodology is below https://docs.nodebb.org/installing/os/ubuntu/
  • Fancybox zoom
    Unsolved Customisation fancybox zoom image
    @DownPW Technically, it should be possible with the addition of the below Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, Meaning your code block becomes function fancybox() { if (top.location.pathname !== '/login') { $(document).ready(function() { $('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() { $('a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]').addClass("noanimate"); }); }); Fancybox.bind( 'a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]', { Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, } ); } } Note, that you just need to add/remove the elements in the toolbar you do not need. Obviously, zoomIn and zoomOut are the ones you are specifically interested in. However, if Fancybox detects that the image has already been zoomed as far as possible, then this will not work. You’d need an external library such as zoom.js to add this functionality, or perhaps simpler https://www.jacklmoore.com/zoom/ A good example of how you’d make these two independent libraries work together is below https://codepen.io/ezra_siton/pen/VgrjKw It’s worth nothing that this specific code is based on Fancybox 3, so may need to be refactored to work with the latest version 5.
    258
    173k Views
  • [NODEBB] Welcome Message
