help me to get rid of my old CDN
Moved Customisation
13 2 3.8k 1
    i have decided to stop using stackpathCDN and removed it from my CW subscription. i have checked all the WordPress settings but for some reason, i could not able to get rid of stackpathCDN
    pages are trying for old stack path JS but failing to load, any suggestions?
    searched MySQL DB now replacing stack path URLs with my domain name
  • searched MySQL DB now replacing stack path URLs with my domain name
    @Hari you should also check and temporarily disable any caching - particularly cloudflare.
  • @Hari you should also check and temporarily disable any caching - particularly cloudflare.
    wrote on last edited by Hari
    @phenomlab i have cleared it and for now it is in dev mode
    now manually editing few PHP files
  • @phenomlab i have cleared it and for now it is in dev mode
    @Hari I don’t see any need to manually edit PHP files. Are to sure there is no plugin making changes ?
  • @Hari I don’t see any need to manually edit PHP files. Are to sure there is no plugin making changes ?
    @phenomlab we have built a few custom PHP files and embedded iframes … so we need to update them manually 🙂
    happiness is fixing things 🙂
  • @phenomlab we have built a few custom PHP files and embedded iframes … so we need to update them manually 🙂
    @Hari that makes sense. Not something I’d generally recommend, but ok.
  • @Hari that makes sense. Not something I’d generally recommend, but ok.
    @phenomlab CW support agent is helping, he is running some commands to replace 00252.stackpateh.com domain with mine.
    enjoying CW support
  • @phenomlab CW support agent is helping, he is running some commands to replace 00252.stackpateh.com domain with mine.
    enjoying CW support
    @Hari if this in WordPress, or other custom PHP files ?
  • @Hari if this in WordPress, or other custom PHP files ?
    @phenomlab few pages are PHP.
    what is the command line to find and replace a text from all files?
    i want to find 00-00-raikfcquaxqncofqfm.stackpathdns.com and replace with www.mydomain.com
    he has done the major part and said it is taking time since the directory has many files, then he opened a ticket and said he will esclate it soon.
  • @phenomlab few pages are PHP.
    @Hari what you need here is awk, sed, and probably grep but the two former listed are extremely powerful and can be very dangerous if used incorrectly. Not sure I understand why it’s taking so long for the support technician to complete as these commands - gratuitous in nature - are usually very quick - even when traversing a large directory tree.
  • @Hari what you need here is awk, sed, and probably grep but the two former listed are extremely powerful and can be very dangerous if used incorrectly. Not sure I understand why it’s taking so long for the support technician to complete as these commands - gratuitous in nature - are usually very quick - even when traversing a large directory tree.
    @phenomlab they have done the necessary changes. now everything is working fine. 👍
  • @phenomlab they have done the necessary changes. now everything is working fine. 👍
    @Hari Ok. Good. Thanks
  • phenomlab phenomlab moved this topic from Guides on
  • External Links - New Window
    Solved Customisation nodebb links settings
  • Forum customisation
  • Fancybox zoom
    Unsolved Customisation fancybox zoom image
    @DownPW Technically, it should be possible with the addition of the below Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, Meaning your code block becomes function fancybox() { if (top.location.pathname !== '/login') { $(document).ready(function() { $('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() { $('a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]').addClass("noanimate"); }); }); Fancybox.bind( 'a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]', { Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, } ); } } Note, that you just need to add/remove the elements in the toolbar you do not need. Obviously, zoomIn and zoomOut are the ones you are specifically interested in. However, if Fancybox detects that the image has already been zoomed as far as possible, then this will not work. You’d need an external library such as zoom.js to add this functionality, or perhaps simpler https://www.jacklmoore.com/zoom/ A good example of how you’d make these two independent libraries work together is below https://codepen.io/ezra_siton/pen/VgrjKw It’s worth nothing that this specific code is based on Fancybox 3, so may need to be refactored to work with the latest version 5.
    258
    173k Views
  • [NODEBB] Welcome Message
  • NodeBB Design help
  • CSS Help on my Flarum
    @mike-jones Yes, you’ll typically see this type of behaviour if there is another style that has higher priority in the sense that yours will be overridden. Using !important will override the higher preference, but should be used sparingly rather than everywhere.
