Rendering issues post migration to Sudonix theme/code
Solved Bugs
49 4 18.4k 1
  • @phenomlab lol 🤣 Is there a way to calculate this based on sun rise/set…
    @crazycells anything is possible, but this would of course vary by location… Unless you use a weather api
  • Hi Mark
    I can not find true CSS on my web site which to make change the background color from white to other color for post as below photo?
    want to change as your post background color
  • Hi Mark
    @cagatay You should be able to use the below CSS to accomodate that
    li.pt-4.self-post {
        background: red !important;
    Obviously, change “red” to the colour you require.
  • not working this code, i think mine is different for hat changes.
  • seems to work when I add it to your site :
    The code should work, maybe you have another code in conflict after ?
    If you open console develloper on your browser, you see this :
    maybe change your --bs-post-category-wrapper color. If I do it that’s work too.
  • yeap --bs-post-category-wrapper i changed and its done 🙂
    @DownPW said in Rendering issues post migration to Sudonix theme/code:
    Yep - good point. @cagatay uses CSS from Sudonix, so that makes sense.
  • Mark hi hope doing well.
    i want to delete social media icons but i cant find them
    @cagatay Those are in /admin/extend/widgets/brand header. Look inside the HTML widget that is there, and you’ll find
           <div class="socialicons">
            <a class="btn-ghost p-2" href="https://github.com/phenomlab" rel="noreferrer noopener"><i style="color: #333;background: #ffffff; width: 26px" class="fa fa-2x fa-github-square"></i></a>
            <a class="btn-ghost p-2" href="https://linkedin.com/in/phenomlab" rel="noreferrer noopener"><i style="color: #0077B5;background: #ffffff; width: 26px" class="fa fa-2x fa-brands fa-linkedin-square"></i></a>
            <a class="btn-ghost p-2" href="https://twitter.com/phenomlab" rel="noreferrer noopener"><i style="color: #1DA1F2;background: #ffffff; width: 26px" class="fa fa-2x fa-twitter-square"></i></a>
            <!-- <a class="btn-ghost p-2" href="https://www.facebook.com/sudonixtech" rel="noreferrer noopener"><i style="color: #4268B2;background: #ffffff; width: 26px" class="fa fa-2x fa-facebook-square"></i></a> -->
           </div>
    Remove that block and save.
  • CTA banner for visitors
    Solved Bugs bug
  • Layout Issues/Transparency
    Solved Bugs bug
  • Loading Image Problem
    Bugs hata bug
    Thank you Mark.
  • Is NTFY working properly on iOS?
    Bugs
    @phenomlab thx, the same for us. It sees 1.7.3 as the last version although it is updated to 1.7.4… i will report this to @barisusakli
  • Nodebb 3.2.2
    Bugs nodebb 3.2.2
    @crazycells yes, I’ve just seen that and modified the post. It seems to only happen if you have a space between the “greater than” symbol and the actual text. Clearly a markdown thing.
    @DownPW looks good to me.
  • Nav Drop-down [Sudonix]
    Moved Bugs
    @phenomlab said in Nav Drop-down [Sudonix]: @jac Fixed [image: 1638187996641-d2e5410b-fa82-4fc9-a861-7913d3c560ab-image.png] Thanks for reporting. Thanks mate, not a problem .
