Rendering issues post migration to Sudonix theme/code
Solved Bugs
49 4 16.1k 1
  • CTA banner for visitors
    Solved Bugs bug
    Solved Bugs bug
  • nodebb error logs
    I just wanted to ask because I don’t have much knowledge about the new installation. Thank you for the explanatory answer.
  • Is NTFY working properly on iOS?
    Bugs
    @phenomlab thx, the same for us. It sees 1.7.3 as the last version although it is updated to 1.7.4… i will report this to @barisusakli
  • Bug Report
    Solved Bugs nodebb bugs
    15k Views
    @crazycells Good points, thanks. I completely forgot that classes are added - makes life much simpler! EDIT - seems this is pretty straightforward, and only needs the below CSS .upvoted i { color: var(--bs-user-level) !important; } This then yields [image: 1718028529465-3f072f8a-ebfa-4910-8723-73c493b8e4eb-image.png] However, the caveat here is that the .upvoted class will only show for your upvotes, and nobody else’s. However, this does satisfy the original request however I would love to see my upvoted posts more clearly, because currently, when I upvote, nothing on the post tool is changing, it would be nicer if there is an indication that I have upvoted (like a filled or colored triangle?)
  • Permission issues
    Solved Bugs
    @Panda I forked this topic out of the previous thread as it’s an issue in it’s own right. Having checked, I see the reason why [image: 1688552291277-06d082f0-6c7d-443b-98bc-94db5f3e5d0e-image.png] As you can see from the screenshot, category “Announcements” does not permit editing. This specific category was originally read only, which I then changed to members could reply. Looks like I forgot to add the right to edit Should be fixed now [image: 1688552421019-a533d8ff-23f1-432e-a4a6-3d10cb05a46d-image.png]
  • Difficult to move posts now, on mobile.
    @DownPW Yes, it is. It’s set far too low meaning other elements with a higher preference will sit over the top of it.
    @DownPW looks good to me.
