Skins
4 2 1.6k 1
    Thanks for letting me join! Would you be able to share your variables to customize/create a skin? I really like how you have the swatches on the topp right, instead of having to go through settings.
  • OT OT
    @phenomlab said in Skins:
    @OT Welcome! I’m actually composing that specific post now, so stay tuned 😄
    Awesome! We swtiched to 3.2.2 and the skins are different from earlier versions. The color scheme, especially in darkly, are quite hideous now.
    @OT Yes, I know. Here’s the article. I just finished it
    https://sudonix.org/topic/542/swatch-theme-changer
    Please try this in test first before you deploy to live.
  • OT OT
  • @OT Welcome! I’m actually composing that specific post now, so stay tuned 😄
  • OT OT
  • Custom Page - nodebb
    I’m happy to see this
  • External Links - New Window
    Solved Customisation nodebb links settings
  • Please help me, I can't install nodebb
    Locked Solved Customisation nodebb
    Installation completed, verified, and tested. Correct installation methodology is below https://docs.nodebb.org/installing/os/ubuntu/
  • Forum customisation
  • Fancybox zoom
    Unsolved Customisation fancybox zoom image
    @DownPW Technically, it should be possible with the addition of the below Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, Meaning your code block becomes function fancybox() { if (top.location.pathname !== '/login') { $(document).ready(function() { $('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() { $('a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]').addClass("noanimate"); }); }); Fancybox.bind( 'a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]', { Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, } ); } } Note, that you just need to add/remove the elements in the toolbar you do not need. Obviously, zoomIn and zoomOut are the ones you are specifically interested in. However, if Fancybox detects that the image has already been zoomed as far as possible, then this will not work. You’d need an external library such as zoom.js to add this functionality, or perhaps simpler https://www.jacklmoore.com/zoom/ A good example of how you’d make these two independent libraries work together is below https://codepen.io/ezra_siton/pen/VgrjKw It’s worth nothing that this specific code is based on Fancybox 3, so may need to be refactored to work with the latest version 5.
  • NodeBB Theme/Skin Switcher
    18k Views
    @Teemberland great spot ! You should create a PR for that so they can include it in the official repository. Just be aware that any subsequent releases will overwrite your fix without the PR.
    258
    175k Views
