Add "author" badge to NodeBB posts using either CSS or jQuery
Customisation
1 1 1.7k 1
    I thought I had already created a dedicated thread for this elsewhere, but clearly not - it was probably bundled in with another topic.
    If you want to create an “Author” badge on each post that looks like the below, you can do this using pure CSS
    Required CSS
    .topic-owner-post [itemprop=name]:after {
        border: 2px solid var(--bs-border-color);
        border-radius: 0.25rem !important;
        color: var(--bs-body-color);
        content: "Author";
        margin-left: 5px;
        padding: 2px 10px;
        display: inline-block;
    However, things get slightly more complicated if you want to add an icon in the same element, like the below
    As the above example makes use of the :after pseudo element, it’s not possible to have two font-family statements when using content: ""
    To facilitate this, you’d need a jQuery function that looks like the below
            $(".topic-owner-post [itemprop=name]").append("<span class='author'><span class='author-icon'><i class='fa-light fa-bullhorn'></i>Author</span>");
    Here, you use span tags to insert both the icon, and text 🙂
    Obviously, you need to ensure that the css for .author and .author-icon exist.
    Here’s an example
    span.author {
        content: "Author";
        margin-left: 5px;
        padding: 2px 10px;
    span.author-icon i {
        margin-right: 5px;
  • Custom Page - nodebb
    I’m happy to see this
  • Please help me, I can't install nodebb
    Locked Solved Customisation nodebb
    Installation completed, verified, and tested. Correct installation methodology is below https://docs.nodebb.org/installing/os/ubuntu/
  • Fancybox zoom
    Unsolved Customisation fancybox zoom image
    @DownPW Technically, it should be possible with the addition of the below Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, Meaning your code block becomes function fancybox() { if (top.location.pathname !== '/login') { $(document).ready(function() { $('a').not('.forum-logo').not(".avatar").not(".emoji").not(".bmac-noanimate").each(function() { $('a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]').addClass("noanimate"); }); }); Fancybox.bind( 'a[href*=".jpg"], a[href*=".jpeg"], a[href*=".png"], a[href*=".gif"], a[href*=".webp"], a[href*=".svg"]', { Toolbar: { display: { left: ["infobar"], middle: [ "zoomIn", "zoomOut", "toggle1to1", "rotateCCW", "rotateCW", "flipX", "flipY", ], right: ["slideshow", "thumbs", "close"], }, }, } ); } } Note, that you just need to add/remove the elements in the toolbar you do not need. Obviously, zoomIn and zoomOut are the ones you are specifically interested in. However, if Fancybox detects that the image has already been zoomed as far as possible, then this will not work. You’d need an external library such as zoom.js to add this functionality, or perhaps simpler https://www.jacklmoore.com/zoom/ A good example of how you’d make these two independent libraries work together is below https://codepen.io/ezra_siton/pen/VgrjKw It’s worth nothing that this specific code is based on Fancybox 3, so may need to be refactored to work with the latest version 5.
    Very great
  • 11 Votes
    @DownPW No issues. Thanks to the Google Chrome “bug”, it does have some restrictions, but works fine other than that. I have an odd issue where it doesn’t work on Firefox mobile, but works fine on Firefox desktop.
    258
    173k Views
  • [NODEBB] Welcome Message
