speed up my DigitalOcean droplet - Virtualmin
10 2 3.4k 1
    how can i speed up my DigitalOcean droplet - Virtualmin
  • how can i speed up my DigitalOcean droplet - Virtualmin
    @Hari What machine size is the droplet now ?
  • @Hari What machine size is the droplet now ?
    wrote on last edited by Hari
    @phenomlab 1gb ram 1vcpu AMD premium
    and i am also getting flarum errors sometimes, i have observed when i am opening virtualmin this is happening more frequently while switching between webmin and virtualmin
    https://discuss.flarum.org/d/30151-flarum-encountered-a-boot-error
    edit:
    i am aware that MySQL itself takes about 500mb to run, i have noticed this during the setup of Virtualmin
  • @phenomlab 1gb ram 1vcpu AMD premium
    edit:
    @Hari said in speed up my DigitalOcean droplet - Virtualmin:
    This is nowhere near enough to run Webmin / Virtualmin which explains the slowness. You ideally need 2 x CPU and at least 2Gb RAM.
  • @Hari said in speed up my DigitalOcean droplet - Virtualmin:
    @phenomlab 💰 i am already paying around $50 at cloudways the same server will be continued to use for another 6months. I am thinking to move back to cloudways for now and switch back to virtualmin once we are ready to leave.
    so meanwhile I can save 20*6= $120
    4gb 2cpu would be great for virtualmin but running flarum is getting more expensive these days. if it is WordPress it would not cost us money et al. each has its own benefits 😢
  • @phenomlab 💰 i am already paying around $50 at cloudways the same server will be continued to use for another 6months. I am thinking to move back to cloudways for now and switch back to virtualmin once we are ready to leave.
    @Hari Is the preference for Cloudways based on geolocation ? $50 is VERY expensive for what you are getting. Below is my system, also running Webmin / Virtualmin
    This system costs me €29 per month, so $35 🙂
  • @Hari Is the preference for Cloudways based on geolocation ? $50 is VERY expensive for what you are getting. Below is my system, also running Webmin / Virtualmin
    @phenomlab yes, we want the server to be in India, digital ocean or aws has data centres here.
    it is the thing “we will continue to pay CW for the next 6months whey we need to pay for extra for flarum again, it’s $10 that is not a big deal at this moment” once we cancel CW we can spend $24 USD for flarum 4gb 2cpu
    your plan is costing $48 on digital ocean.
  • @phenomlab yes, we want the server to be in India, digital ocean or aws has data centres here.
    @Hari I just remembered that there in fact ways to reduce the footprint of VirtualMin to make it run faster on slower machines.
    https://www.virtualmin.com/documentation/system/low-memory/
  • @Hari I just remembered that there in fact ways to reduce the footprint of VirtualMin to make it run faster on slower machines.
    @phenomlab thanks for sharing, after four or five months I will migrate to DO 2 or 4gb RAM droplet. 👍
  • Hari Hari has marked this topic as solved on
  • Fedora Server + Virtualmin
    @Hari Really? Can you elaborate a bit more here?
  • 6 Votes
    15k Views
    @justoverclock said in Digitalocean step by step guide to nginx configuration: i’m learning And that’s the whole point of this site If you don’t learn anything, you gain nothing.
  • Virtualmin Setup DigitalOcean
    Solved Customisation virtualmin digitalocean
    26
    @Hari said in Virtualmin Setup DigitalOcean: i have felt it is very hard to manage Virtualmin the settings are confusing It’s a bit of a learning curve, admittedly, but very powerful and easy to use provided you understand the implications of what you are doing. For example, moving a VirtualMin server to subserver and then back again without changing underlying components that rely on the correct placement of the server, of course it will no longer work.
  • how to use CF tunnels with Virtualmin?
    Solved Configure cf tunnel cloudflare virtualmin
    @Hari DDoS protection is not just a switch, or one component. It’s a collection of different and often disparate technologies that when grouped together form the basis of a combined toolset that can be used in defence. Typically these consist of IDS (Instrusion Detection System) and IPS (Intrusion Prevention System) components that detect irregularities in network traffic, and will take decisive action based on predefined rulesets, or in the case of more modern systems, AI and ML. Traditional “traffic shaping” technology is also deployed, so if an attack cannot be easily identified as malicious, the bandwidth available to that connection is severely limited to nothing more than a trickle rather than a full flow. Years ago, ISP’s used traffic shaping (also called “policers”) as an effective means of stopping applications such as BearShare, eDonkey, Napster, and other P2P based sharing systems from functioning correctly - essentially reducing the “appeal” of distributing and seeding illegal downloads. This was essentially the ISP’s way of saying “stop what you are doing please” without actually pulling the plug. These days, DDoS attacks are designed to overwhelm - not assume control of - webservers and other public facing components. It’s rare for small entities to be attacked unless there is some form of political agenda driven by your site or product. A classic example is governmental institutions or lawmakers who effectively are classed as “enforcers” and those who disagree are effectively making a statement in the form of Denial of Service. DDoS protection is effectively the responsibility of the hosting provider, but you shouldn’t just assume that they will protect you or your site. Their responsibility stops at their infrastructure, so it’s then up to you too decide how you full the gap in between your host and the website. Typically, you’d leverage something like Imunify360 which you can get for Plesk (and something I’d strongly recommend) but it’s not free, and is a paid (not expensive per month) subscription. If you want to use VirtualMin then there are a variety of tools readily available out of the box such as firewalls and fail2ban.
  • how to configure DNS records virtualmin?
    Solved Linux digitalocean dns
    26
    i think we can mark this discussion as solved learned how to install virtualmin with NGINX We can easily point the DNS by mentioning server IP at CF a name record learned how to install SSL
  • SSl expired on virtualmin
    Solved Configure virtualmin ubun server ssl
    @justoverclock Not necessarily. You only need to use this if it fails from the Virtualmin window
  • SASL LOGIN authentication failed: generic failure
    Moved Solved Linux
    @Ash3T I’m going to mark this post as solved as I’ve not heard from you in a while. Let me know if this isn’t the case and you need more help.
