v3 & Harmony diary / thoughts / code snippets
55 4 30.4k 1
    #41
    Been a bit quiet lately, so thought I’d share some new things I’m going to be adding into Sudonix for the v3 release (based on Harmony). As you probably know by now, Sudonix allows you to set the best answer for any questions you ask. I wanted to extend this capability graphically, and came up with these ideas.
    First and foremost - say you’re reading a post where someone was able to get the response they needed, and it solved their issue. The next person comes along, and gets the same experience. Wouldn’t it be nice to show your appreciation? Now you can !
    Just below the “Accepted Answer” is a newly inserted div which in fact is just a widget, but leverages the power of the NodeBB API to make decisions around which div should be presented.
    https://docs.nodebb.org/api/read/#section/Overview
    For example
    And then, if you are the original poster, have received responses, but are yet to choose the best answer
    And, what if you were the original poster, but had no responses? We’ve got that covered too 🙂
    The code for all of this is relatively simple - an example is shown below
    First things first: This additional code will not work properly if you do not have nodebb-plugin-question-and-answer installed. It relies on various values being exposed which are not there if the plugin is not installed.
    The first element of code to be added needs to be in ACP->Custom Content (HTML/JS/CSS)->Custom Javascript
    $(window).on('action:ajaxify.end', function (data) {
        function updateUsername() {
            $('.getUsername .username').text(app.user.username);
            $('.topicUsername').text(app.user.username);
        if (document.readyState === 'loading') {
            document.addEventListener('DOMContentLoaded', updateUsername);
        } else {
            updateUsername();
    Save.
    Then, add the below to ACP->Extend-Widgets->Topic.tpl, and use the HTML Widget (which you’ll need to drag into the place where you want it to appear - the optimum is the Topic Footer.
    <head>
      <style>
        span.topicUsername {
          text-transform: capitalize;
      </style>
    </head>
      {{{ if isSolved }}}
      <div id="resolved">
        <div class="resolved-wrapper">
          <h5 class="resolved-header">Did this solution help you?</h5>
          <div class="resolved-body">
            <div class="resolved-message">Did you find the suggested solution useful? Why not <a href="https://www.buymeacoffee.com/phenomlab" target=_blank>buy me a coffee<a />? It's a nice gesture, and there's <a href="https://sudonix.com/donate">other ways to donate</a> if you wish <span class="heart">💗</span></div>
          </div>
        </div>
      </div>
      <br>
      <script>
        if (!window.jQuery) {
          window.addEventListener('load', function() {
              $("#resolved").insertAfter('.isSolved');
            console.log("Total posts = " + ajaxify.data.postcount)
        } else {
      </script>
      {{{ end }}}
      {{{ if (uid == loggedInUser.uid) }}}
      {{{ if isQuestion }}}
      {{{ if !isSolved }}}
      {{{ if !unreplied }}}
      <div id="unresolved">
        <div class="unresolved-wrapper">
          <h5 class="unresolved-header">Did you get the answer you needed?</h5>
          <div class="unresolved-body">
            <div class="unresolved-message">Hey <span class="topicUsername"><span class="username"></span></span>. It looks as though there have been one or more replies to your original post. <br>If a provided answer resolved an issue for you, Could you please take a moment, and select "Mark this post as the correct answer" in the corresponding response? <br><br>By doing this, it means that original posters help the rest of the community find answers to previously asked questions by identifying the correct answer. </div>
          </div>
        </div>
      </div>
      <br>
      <script>
              $("#unresolved").insertBefore('[component="topic/quickreply/container"]');
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ if unreplied }}}
      <div id="unreplied">
        <div class="unreplied-wrapper">
          <h5 class="unreplied-header">No response yet</h5>
          <div class="unreplied-body">
            <div class="unreplied-message">Hey <span class="topicUsername"><span class="username"></span></span>. It looks as though there are no responses yet. Don't panic though, as one will be provided as soon as possible.<br>Please do not "bump" posts. </div>
          </div>
        </div>
      </div>
      <br>
      <script>
              $("#unreplied").insertBefore('[component="topic/quickreply/container"]');
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
    Save.
    You’ll notice some interesting features here courtesy of jQuery (and vanilla js where if the page is loaded externally, and jQuery is not loaded, it will fallback to plain, which is this part if (!window.jQuery) )
    There’s also a function that will position the newly inserted div into the right place - essentially, this command .insertBefore('[component="topic/quickreply/container"]'); . The purpose of this is to place the div message in where you’d expect to see it - for example, if the post is solved, then it should appear directly underneath the resolution, but if no replies, or if you’re the original poster and you’ve yet to choose an accepted answer, it’ll be at the bottom.
    Essentially, we are not only defining a div structure, but using logic to determine placement to ensure it gets the most attention.
    And finally, the CSS used below
    div#resolved {
        border-radius: 0.375rem;
        border: 2px solid var(--bs-resolved-bg) !important;
        margin-left: 24px;
    h5.resolved-header {
        color: var(--bs-body-color);
        background: var(--bs-resolved-bg);
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
    h5.resolved-header:before {
        content: "\f648";
        font-family: "Font Awesome 6 Pro";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        vertical-align: bottom;
        margin-right: 10px;
        margin-left: -35px;
    .resolved-body {
        padding: 20px;
        background: var(--bs-resolved-bg-rgba);
        margin-top: -10px;
    div#unresolved {
        border: 2px solid var(--bs-unresolved-bg) !important;
        margin-left: 24px;
        margin-top: 20px;
    h5.unresolved-header {
        background: var(--bs-unresolved-bg);
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
    h5.unresolved-header:before {
        content: "\f06a";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        margin-right: 10px;
        margin-left: -35px;
    .unresolved-body {
        padding: 20px;
        background: var(--bs-unresolved-bg-rgba);
        margin-top: -10px;
    div#unreplied {
        border: 2px solid var(--bs-unreplied-bg) !important;
        margin-left: 24px;
        margin-top: 20px;
    h5.unreplied-header {
        background: var(--bs-unreplied-bg);
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
    h5.unreplied-header:before {
        content: "\e36d";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        margin-right: 10px;
        margin-left: -35px;
    .unreplied-body {
        padding: 20px;
        background: var(--bs-unreplied-bg-rgba);
        margin-top: -10px;
    Save.
    Note that I’m using LESS variables here, so you’ll need to define your own colours if you do not use this standard. I also have a Font Awesome 6 Pro license, so you’ll need to replace that as necessary.
  • Been a bit quiet lately, so thought I’d share some new things I’m going to be adding into Sudonix for the v3 release (based on Harmony). As you probably know by now, Sudonix allows you to set the best answer for any questions you ask. I wanted to extend this capability graphically, and came up with these ideas.
    For example
        } else {
            updateUsername();
    Save.
    <head>
      <style>
      </style>
    </head>
      {{{ if isSolved }}}
      <div id="resolved">
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
    Save.
    div#resolved {
        margin-left: 24px;
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
        content: "\f648";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        margin-right: 10px;
        margin-left: -35px;
    .resolved-body {
        padding: 20px;
        margin-top: -10px;
    div#unresolved {
        margin-left: 24px;
        margin-top: 20px;
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
        content: "\f06a";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        margin-right: 10px;
        margin-left: -35px;
    .unresolved-body {
        padding: 20px;
        margin-top: -10px;
    div#unreplied {
        margin-left: 24px;
        margin-top: 20px;
        padding: 6px 8px;
        padding-left: 50px;
        font-weight: 600;
        height: 40px;
        line-height: 1.8;
        z-index: 1;
        position: relative;
        content: "\e36d";
        font-size: 1.5rem;
        font-weight: 300;
        line-height: 1.2;
        margin-right: 10px;
        margin-left: -35px;
    .unreplied-body {
        padding: 20px;
        margin-top: -10px;
    Save.
    Very good job…
    I must just thinking to where put your first part code on nodeBB ACP but I want to test it!
    Very good job…
    @DownPW The first part of the code I supplied will be placed into a widget. In my case, it’s in the below
    #44
    I have tested it seems to work but I seem to be unable to display the username in the replies and I don’t know why for this moment 😞
    <span class=“topicUsername”> doesn’t seem to work
    #45
    Other things I have find when I test the code.
    This is a very rare case but if the topic is set to solved and there is no answer in it, we get this kind of thing:
    We can imagine that this happens when the user himself would have found a solution and that him or another user did not post answers in the topic and that this one is put in solved
    @DownPW From memory, you should be using a function that looks like this in PROD
        } else {
            updateUsername();
        var thehours = new Date().getHours();
    	var themessage;
    	var morning = ('Good morning');
    	var afternoon = ('Good afternoon');
    	var evening = ('Good evening');
        var matched = false;
        $('#getConsent').attr("href", "/user/" + app.user.username + "/consent");
    	if (thehours >= 0 && thehours < 12) {
    		themessage = morning;
    	} else if (thehours >= 12 && thehours < 17) {
    		themessage = afternoon;
    	} else if (thehours >= 17 && thehours < 24) {
    		themessage = evening;
            $('.getUsername').prepend(themessage);
    You’ll need the same function in your development environment if you don’t have it already, and will need to add
    Right after line 3, so
        } else {
            updateUsername();
        var themessage;
        if (window.location.href.indexOf("topic") > -1) {
            //console.log("This is a topic, so hide the user welcome message");
            $('#mainbanner').hide();
        } else {
        //	$('.getUsername').prepend(themessage);
    Note that your function might look different as I recall you modifying the code I supplied to meet your own needs.
  • Other things I have find when I test the code.
    #47
    @DownPW Ah yes, I can see a case where that would indeed fire, and I’m able to replicate it here
    Let me adjust the code and get back to you.
    EDIT: Revised widget code here
    <head>
      <style>
      </style>
    </head>
      {{{ if isSolved }}}
      <div id="resolved">
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
  • @DownPW From memory, you should be using a function that looks like this in PROD
        } else {
            updateUsername();
    	var themessage;
        } else {
            updateUsername();
        var themessage;
        } else {
    #48
    @phenomlab said in v3 & Harmony diary / thoughts / code snippets:
    Ha yes exactly, seems to be forget this lol. 🤣
    With $('.topicUsername').text(app.user.username); it’s perfect 🙂
    yes perfect, definitively better ^^
    Just play with CSS for me but it’s a very good job Mark !
    I love this functionnality a lot, who play which works together with the nodebb-plugin-question-and-answer plugin
  • @phenomlab said in v3 & Harmony diary / thoughts / code snippets:
    @DownPW said in v3 & Harmony diary / thoughts / code snippets:
    With $(‘.topicUsername’).text(app.user.username); it’s perfect
    Yes, I need to add that to the documentation above, plus the “missing” function (which I will cut down as the average user won’t need all of it)
    Good news
    Great ! It was designed primary to work with nodebb-plugin-question-and-answer and in fact won’t work very well without it, so it’s actually a core dependency.
    #50
    I’m a beta tester @phenomlab 😉
    I see other bugs my friends :
    • 1- A user who has not created the topic sees the message intended for the initiator of the topic :
    • 2- Same things with solved Post :
    –> If the message is only addressed to the initiator of the topic, it’s a bit problematic, isn’t it?
  • I’m a beta tester @phenomlab 😉
    Ugh. Sorry. Use this widget code (original post updated)
    <head>
      <style>
      </style>
    </head>
      {{{ if isSolved }}}
      <div id="resolved">
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
          </div>
        </div>
      </div>
      <br>
      <script>
        } else {
      </script>
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
      {{{ end }}}
    No, not really 🙂 It’s designed to work this way so that anyone else visiting looking for the same answer and finds it has the opportunity to reward you - it’s why it mentions no names 🙂
    #52
    Perfect thats Work on 3;X 😉
    I am testing this code in version 2.X but it seems it is not working properly
    Only the resolution message seems to work in 2.X
    Do you think it is possible to adapt it for 2.X ?
  • Perfect thats Work on 3;X 😉
    Hmm - I never wrote it to be compatible with v2, but I can’t think of any reason as wo why this would not work. Is there somewhere I can see it ?
  • @DownPW said in v3 & Harmony diary / thoughts / code snippets:
    #54
    @phenomlab I pm you
  • @phenomlab I pm you
    @DownPW I see why. The code relies on the existence of
    However, this by definition means that the below has to be enabled
    It will then work
    For some unknown reason, this is hidden in Harmony, and only shows if you select it. In v2, it seems that the <section> is deleted altogether in Persona if “Quick Reply” is disabled, meaning it won’t fire as it can’t locate that specific component.
    The downside is that you might not want the quick reply function, but I think it’s a PITA to scroll up to the top of the post just to reply, so I have it on 🙂
  • NODEBB: Nginx error performance & High CPU
    Solved Performance performance nodebb nginx
    69
    14 Votes
    63k Views
  • NodeBB v3
    Announcements nodebb v3 nodebb
    @cagatay JS will work fine - no changes there, and there are no plans to drop support for jQuery. More of an issue is the CSS - for which there are quite a few breaking changes. Keep an eye on sudonix.dev (my development site) where you can see progress in relation to how I am tackling the compatibility issues.
  • ineffecient use of space on mobile
    @phenomlab Thanks
  • Easier to read code and pre blocks
    Announcements code pre
  • Customising NodeBB
    Locked Customisation nodebb
  • [NodeBB] Creating new user to auto post content
    @phenomlab many thanks Mark .
  • WordPress & NodeBB
    Solved WordPress
    @jac That won’t matter. You just redirect at nginx or apache level and it’ll work. The generally accepted standard though is to use a subdomain.
  • Platform development diary
    Announcements technology platform new
    It’s been a while since I checked in here. Plenty going on - mostly around rectifying small pockets of resistance between light and dark modes, plus the addition of new features such as an enhanced reputation system and the ability to create polls. Plus, there are several changes going on under the hood which are completely transparent to users or the operation of the platform. However, some changes mean that the platform does need to be restarted for code changes to stick and function correctly. I tend to do this during non busy periods, but sometimes, it’s unfortunately inevitable. The good news is that in most cases, a full restart takes only 20 seconds. More to come
