v3 & Harmony diary / thoughts / code snippets
55 4 30.4k 1
  • @phenomlab said in v3 / Harmony diary:
    Today’s playground 🙂
    Here’s a video… still needs a bit more work, but… 🙂 Notice the newer scroll and progress bar I was talking about earlier…
    https://sudonix.com/assets/uploads/files/footer-added.webm
    Hello Mark,
    I just tested the functioning of the scroll bar and I saw this bug:
    https://i.imgur.com/VQw5zw5.mp4
    It should be moved to the left so as not to encroach on the collapse button of the custom footer navbar.
    Then, when we play with the collapse button of the custom footer navbar we should:
    • When the custom footer navbar is deactivated: it sticks to the bottom right while not encroaching on the right sidebar. All this taking into account the collapse of the right sidebar (not obvious, I don’t know if I’m clear 🙂 )
    • When the custom footer navbar is activated: it moves just to the left of the floatright block or can be above the floatright block?
    The solution may be less difficult to code would be to make a vertical scrollbar inside the right sidebar like in topics. There might be less to manage
    Keep the good work my friend 😉
    Hello Mark,
    @DownPW fixed in Dev. Have a look. Many improvements and I think you’ll like it. Try it on both desktop and mobile.
    Hello Mark,
    @DownPW said in v3 / Harmony diary:
    Nope. The newest version of Harmony appears to have the same pagination as Flarum and Discourse, so it’s been moved into the content area 😁
  • @DownPW said in v3 / Harmony diary:
    yessss fixed. Love it 😁 😍
    #25
    No javascript ?
    I wanted to inspect the code but I can’t find any JS
    No javascript ?
    @DownPW it’s definitely there. Won’t work without it 😉
  • @DownPW it’s definitely there. Won’t work without it 😉
    I guess, I don’t find it in inspector lol .I will search 🙂
    #28
    Can I test it on my dev env ?
    EDIT: I test it. If you don’t want tell me Mark
    If I have problem, can I ask you @phenomlab ?
    @DownPW no problems.
    #30
    Seems I miss something 😑 @phenomlab but good start 😉
    [- https://i.imgur.com/cN0YeN0.mp4 -]
    EDIT: Maybe find
    EDIT 2: @phenomlab
    Find --> I have forget toAbove and toBottom css directives
    It’s better now, just seems toBottom doesn’t work :
    .toBottom {
      bottom: 0px !important;
      right: 0px!important;
    .toAbove {
      bottom: -5px !important;
      right: 400px !important;
    EDIT: Maybe find
    EDIT 2: @phenomlab
    .toBottom {
    .toAbove {
    @DownPW likely you are missing z-index on that class. As you are using position: absolute the index is needed to bring that specific element forward. By default, it’ll sit behind the progress bar meaning it cannot be clicked, but can be seen.
  • @DownPW likely you are missing z-index on that class. As you are using position: absolute the index is needed to bring that specific element forward. By default, it’ll sit behind the progress bar meaning it cannot be clicked, but can be seen.
    Thanks for your reply my friend 😉
    I will test tomorrow and again, it’s a very great job, I like it a lot.
    #33
    @DownPW no problems. Let me know if you have issues and I can take a look. Can’t release the code formally yet as it’s still beta (and does have very minor bugs).
  • @DownPW no problems. Let me know if you have issues and I can take a look. Can’t release the code formally yet as it’s still beta (and does have very minor bugs).
    #34
    Not sure why, but for a while I’ve been looking at the size of the CSS file that runs the dev site, and I couldn’t understand why it was almost twice the size of what it should be in terms of overall lines.
    This eventually got the better of me and I landed up going through the file and removing what appears to be a large amount of duplicated CSS. I primarily work offline using VSCode (my go-to editor), but periodically “fix” things on the fly. The problem with this is that if you make changes online then copy these from the CSS editor in the ACP back to VSCode, they seem to be copied twice - in other words, appended to the existing file despite all text being selected, which should in fact overwrite, but it doesn’t 😱
    Just something for everyone else to watch out for. I spent a fair amount of time this afternoon purging duplicate classes, and the end result is a much leaner file.
  • Not sure why, but for a while I’ve been looking at the size of the CSS file that runs the dev site, and I couldn’t understand why it was almost twice the size of what it should be in terms of overall lines.
    #35
    Thanks to @cagatay for finding a bug with the CSS in relation to tags in DEV. This has been fixed. I also found another bug whilst addressing this one in the sense that the progress bar on mobile (and desktop, but limited intrusion) shows over the tag div when the composer is active.
    Changed the scrollbar function so that it does not fire if the composer is visible. Here’s the block of code that detects if it’s active or not
                if ($(window).scrollTop() > 0 && (!$('[component="composer"]').is(":visible"))) {
                    bar.addClass('show');
                } else {
                    bar.removeClass('show');
    Above, we now have 2 conditions. The first is to fire only if the top marker is higher than 0 - for example, hide if we are at the top of the screen. The second condition is that we also only fire if the composer isn’t active - detected by is(":visible")
    Keep 'em coming in terms of identified bugs - reporting them is much appreciated.
  • Thanks to @cagatay for finding a bug with the CSS in relation to tags in DEV. This has been fixed. I also found another bug whilst addressing this one in the sense that the progress bar on mobile (and desktop, but limited intrusion) shows over the tag div when the composer is active.
                } else {
    I keep working on my CSS
    On v2, I displayed user groups in topics like this :
    but I can’t seem to get any result. I can’t target the right element
    Ideas ?
    Many thanks
  • Hello @phenomlab
    Ideas ?
    Many thanks
    @DownPW hmm. Haven’t tried this myself (yet) but will have a look later this afternoon.
  • Hello @phenomlab
    Ideas ?
    Many thanks
    @DownPW This should work under v3
    a.badge.rounded-1.text-uppercase.text-truncate.text-decoration-none {
        border-radius: 999px !important;
        margin-left: -10px;
        width: 22px;
        max-width: 22px;
  • @DownPW This should work under v3
        margin-left: -10px;
        width: 22px;
        max-width: 22px;
    #39
    Hi @phenomlab
    Thanks my friend. 👍
    I have this result with code you provided :
    It’s better but not perfect.
    But it allowed me to target the right element
    –> Here is a code improvement for those who are interested :
    /* Desktop */
        margin-right: -10px;
        padding-left: 6px;
        padding-top: 5px;
        width: 20px;
        max-width: 20px !important;
    .d-flex.gap-1.hidden-xs.align-items-center {
        margin-left: 15px;
    i.fa.fa-edit.text-muted.pointer.edit-icon {
        margin-left: 8px;
    /* Smartphone */
    @media (max-width: 767px) {
        padding-left: 4px;
    Better result :
    cya 🙂
  • Hi @phenomlab
    Thanks my friend. 👍
    /* Desktop */
        padding-left: 6px;
        padding-top: 5px;
        width: 20px;
        margin-left: 15px;
        margin-left: 8px;
    /* Smartphone */
        padding-left: 4px;
    Better result :
    cya 🙂
    @DownPW yeah, the CSS I provided was based on my forum, so a little tweaking is necessary. Looks great !
  • MogoDB v6 to v7 upgrade
  • Threaded post support for NodeBB
    Let's Build It threading nodebb
    146
    50 Votes
    116k Views
    Updated git for above change https://github.com/phenomlab/nodebb-harmony-threading/commit/14a4e277521d83d219065ffb14154fd5f5cfac69
  • Nodebb design
    Solved General nodebb
  • NodeBB v3
    Announcements nodebb v3 nodebb
    @cagatay JS will work fine - no changes there, and there are no plans to drop support for jQuery. More of an issue is the CSS - for which there are quite a few breaking changes. Keep an eye on sudonix.dev (my development site) where you can see progress in relation to how I am tackling the compatibility issues.
  • NodeBB inline videoplayer
    Panda
  • Bootstrap Version
    Solved Customisation nodebb bootstrap
    @phenomlab That will be nice once they have completed that. It will be interesting to see how long that takes. So for now I will use custom css to make it look the way I want. Frameworks just make things a little faster. Thanks @phenomlab
  • [NODEBB] Wallpapers BUG on Firefox Mobile ?
    Solved Customisation nodebb wallpaper firefox mobile
    @downpw I’m inclined to agree with this. There isn’t much else you can do, and provided it works with no odd looking artefacts in other browsers, then ok. The :before and :after are pseudo classes and very well supported across all browsers (except perhaps Internet Exploder, but who uses that these days ?)
  • Platform development diary
    Announcements technology platform new
    It’s been a while since I checked in here. Plenty going on - mostly around rectifying small pockets of resistance between light and dark modes, plus the addition of new features such as an enhanced reputation system and the ability to create polls. Plus, there are several changes going on under the hood which are completely transparent to users or the operation of the platform. However, some changes mean that the platform does need to be restarted for code changes to stick and function correctly. I tend to do this during non busy periods, but sometimes, it’s unfortunately inevitable. The good news is that in most cases, a full restart takes only 20 seconds. More to come
