OGProxy - a replacement for iFramely
46 5 19.6k 1
  • Don’t hesitate to tell me what you think of this modified code.
    Until next time.
    @DownPW Looks ok for the most part, but this looks like it’s truncated?
      return {
        ...ogsResult,
        metaProperties: metadata,
        faviconUrl: faviconB64,
  • @DownPW Looks ok for the most part, but this looks like it’s truncated?
      return {
        ...ogsResult,
      return {
        ...ogsResult,
    exactly, i must see the code, i tell you soon
  • I was experiencing 500 (Internal Server Error) responses from the proxy, visible in the browser console:
    GET https://proxy.xxx-xxx.net/ogproxy?url=https%3A%2F%2Fzupimages.net%2Fup%2F26%2F16%2Fld8h.jpg 500 (Internal Server Error)
    After investigation, I found two root causes:
    1. Direct image URLs being sent to the proxy
    The custom JavaScript responsible for detecting links and sending them to the proxy was using the following regex to exclude direct image links:
    var fileExtensionPattern = /\.(png|jpeg|gif|pdf|docx?|xlsx?|pptx?|zip|rar|svg)$/i;
    Note that .jpg and .webp were missing from the pattern. As a result, links ending in .jpg were not recognized as direct image URLs and were forwarded to the OGProxy, which then tried to scrape them as web pages using open-graph-scraper — causing a 500 error.
    The fix was to add the missing extensions:
    var fileExtensionPattern = /\.(jpg|png|jpeg|gif|pdf|docx?|xlsx?|pptx?|zip|rar|svg|webp)$/i;
    2. The proxy not following HTTP redirects
    Some image hosting services (e.g. zupimages.net) return a 301 redirect from the bare domain to www. When curl follows the redirect manually the image loads fine:
    curl -IL https://zupimages.net/up/26/16/ld8h.jpg
    HTTP/2 301 → https://www.zupimages.net/up/26/16/ld8h.jpg
    HTTP/2 200
    However, the proxy’s axios.get() call does not handle this gracefully when open-graph-scraper is involved, resulting in a 500 error being returned to the client.
    My questions are:
    1. Is there a known best practice for handling redirect chains in open-graph-scraper?
    2. Would passing maxRedirects or followRedirect options explicitly to axios or ogs fix this reliably?
    3. Is there a cleaner way to pre-filter direct image/file URLs before they reach the proxy, ideally at the NodeBB plugin level rather than in custom JS?
    Thanks in advance.
  • Hello @phenomlab
    My VPS (NodeBB + MongoDB + Redis + nginx + Webmin, single Hetzner box) had repeated multi-minute interruptions: RAM and swap both at 100%, disk I/O spiking, CPU pinned, swap thrashing, not hardware. Kernel logs showed the OOM killer firing repeatedly, always against the ogproxy.service cgroup. The OGProxy Node process ballooned to ~5 GB RSS within minutes before being killed, dragging the whole box into thrashing. MongoDB was fine (~650 MB). Application-level problem in OGProxy, no hosting ticket warranted.
    Root causes
    1. No download limit or timeout on ogs({ url }), a single link could pull gigabytes into memory.
    2. Unbounded, never-expiring cache, cache.put(url, results) stored the full ogs object including the entire page HTML (results.html) forever. The main leak.
    3. Dead code, favicon/MetaParser/cheerio block gated on if (results.data && ...), but ogs v6’s root key is result, not data, so it never ran. Removed with its unused imports.
    4. Client-side hammering, the ACP script re-runs previewLinks() on every ajaxify/posts/chat/composer event; failing links were never removed or cached, so the same URL was re-scraped ~50×/min.
    Fixes applied
    systemd guard rails:
    • MemoryMax=512M / MemoryHigh=400M, if it ever leaks again, only OGProxy is killed (auto-restarts), not the whole box.
    • Network egress guard (IPAddressAllow/IPAddressDeny), blocks OGProxy from reaching private ranges and cloud metadata at the kernel level, even via a redirect. Loopback 127.0.0.1 stays allowed because nginx reverse-proxies to 127.0.0.1:2000, and 127.0.0.53/54 stays allowed for the systemd-resolved DNS stub. Verified: legitimate fetches work, 169.254.169.254 is blocked.
    Server (server.js😞
    • timeout: 15s + downloadLimit: 5 MB, caps memory per request.
    • redirect: 'follow' with follow: 3, many sites 301/302; without following them they failed with a misleading “Connect Timeout Error”. Hop count bounded to limit SSRF surface.
    • Browser-like User-Agent + Accept headers.
    • Success cache 1 h, negative cache 10 min (kills hammering server-side too), 1000-entry cap.
    • Full error logging (error.result.error + HTTP status; ogs rejects with an object, not an Error).
    • App-level SSRF guard: static host check + DNS-resolution check (blocks hostnames resolving to private IPs, IPv4 + IPv6).
    • API key via process.env.OGPROXY_API_KEY with inline fallback.
    Client (NodeBB ACP):
    • :not(.og-processed) on every selector; og-processed class set before the AJAX call so a link is never re-scraped whether it succeeds or fails (root-cause fix for hammering); the generated card’s <a> carries it too.
    • ignoredHosts now uses bare hostnames and shouldIgnoreDomain compares against the browser-resolved hostname (reliable for relative and absolute hrefs), reliably excludes forum-internal links and the proxy’s own subdomain (no more self-scraping).
    • isFileUrl strips query string / fragment before testing the extension, so image.png?ssl=1 is detected as a file and not sent for preview.
    Result
    ~5 GB spikes → stable ~25 MB. Hammering gone (each URL appears at most once). Redirect/timeout failures dropped sharply. SSRF closed at both app and kernel level.
    Client ↔ server contract (unchanged, do not modify ACP response handling)
    Server returns the native ogs object on success → data.result / data.html reach the client intact. Failures return HTTP ≥ 400 → handled by the client’s error: callback. The internal __ogproxyFail negative-cache marker never reaches the client. Preview card images (og:image) are unaffected, the isFileUrl change only affects direct-image links, not the images shown inside cards.
    Expected remaining failures (not bugs)
    Some sites return 400/500 no matter what: Facebook, Reddit (blocks unauthenticated scraping), press sites with cookie/WAF walls, fb.watch (redirect chains > 3), and direct image links with no extension in the path (ogs correctly rejects non-HTML). These degrade gracefully, link stays clickable, negative-cached, never re-scraped. Decision: leave as-is; chasing each anti-bot site isn’t worth fragile workarounds or extra load.
    Optional follow-ups (no urgency)
    • Move the API key fully to the env var (it’s already browser-exposed client-side, so not a real secret, but avoids duplicating it in source).
    • Run OGProxy under a dedicated non-root user (independent security gain; already heavily mitigated by the kernel network guard).
    Files changed
    • /home/xxxxxxxx/domains/proxy.xxxxxx.xxx/ogproxy/server.js
    • /etc/systemd/system/ogproxy.service
    • NodeBB ACP custom JS (link-preview script)
    server.js
    const express = require('express');
    const ogs = require('open-graph-scraper');
    const cors = require('cors');
    const { URL } = require('url');
    const cache = require('memory-cache');
    const dns = require('dns').promises;
    const net = require('net');
    const app = express();
    const port = 2000;
    // API key from environment, fallback to inline value for compatibility
    const apiKey = process.env.OGPROXY_API_KEY || 'YOUR_API_KEY';
    // --- Limits / safeguards ---
    const REQUEST_TIMEOUT = 15000;                // 15s max per fetch
    const MAX_CONTENT_BYTES = 5 * 1024 * 1024;    // 5 MB max downloaded page
    const CACHE_TTL_MS = 60 * 60 * 1000;          // success cache: 1h
    const FAIL_CACHE_TTL_MS = 10 * 60 * 1000;     // negative cache: 10 min
    const CACHE_MAX_ENTRIES = 1000;               // max cached entries
    const MAX_REDIRECTS = 3;                       // cap redirect hops
    // Returns true if an IP string is private / loopback / link-local / reserved
    function isBlockedIp(ip) {
      if (!ip) return true;
      if (net.isIPv4(ip)) {
        const p = ip.split('.').map(Number);
        if (p[0] === 10) return true;
        if (p[0] === 127) return true;
        if (p[0] === 0) return true;
        if (p[0] === 169 && p[1] === 254) return true;   // link-local / cloud metadata
        if (p[0] === 192 && p[1] === 168) return true;
        if (p[0] === 172 && p[1] >= 16 && p[1] <= 31) return true;
        if (p[0] === 100 && p[1] >= 64 && p[1] <= 127) return true; // CGNAT
        return false;
      if (net.isIPv6(ip)) {
        const v = ip.toLowerCase();
        if (v === '::1') return true;
        if (v.startsWith('fc') || v.startsWith('fd')) return true;  // unique local
        if (v.startsWith('fe80')) return true;                       // link-local
        if (v.startsWith('::ffff:')) return isBlockedIp(v.split(':').pop()); // IPv4-mapped
        return false;
      return true; // not a valid IP -> block by default
    // Static hostname guard (fast reject before any DNS work)
    function isBlockedHost(hostname) {
      if (!hostname) return true;
      const h = hostname.toLowerCase();
      return (
        h === 'localhost' ||
        h.endsWith('.localhost') ||
        h.endsWith('.internal') ||
        h.endsWith('.local') ||
        (net.isIP(h) && isBlockedIp(h))   // literal IP in URL
    // Resolve hostname and ensure no resolved IP is private (anti-SSRF via DNS)
    async function resolvesToPublicIp(hostname) {
      try {
        const records = await dns.lookup(hostname, { all: true });
        if (!records || records.length === 0) return false;
        return records.every(r => !isBlockedIp(r.address));
      } catch (e) {
        return false; // DNS failure -> treat as unsafe
    app.use(cors({ origin: 'https://YOURDOMAIN.EXT' }));
    app.get('/ogproxy', async (req, res) => {
      let { url } = req.query;
      const requestApiKey = req.headers['x-api-key'];
      if (requestApiKey !== apiKey) {
        return res.status(401).send('Unauthorized');
      if (!url || typeof url !== 'string') {
        return res.status(400).send('Missing URL parameter');
      if (!url.startsWith('http')) {
        try {
          url = new URL(url, `${req.protocol}://${req.get('host')}`).href;
        } catch (e) {
          return res.status(400).send('Invalid URL');
      // Parse + protocol check
      let parsedUrl;
      try {
        parsedUrl = new URL(url);
      } catch (e) {
        console.warn(`OGProxy reject [${url}]: invalid URL`);
      if (!['http:', 'https:'].includes(parsedUrl.protocol)) {
        console.warn(`OGProxy reject [${url}]: invalid protocol`);
        return res.status(400).send('Invalid protocol');
      // Static host guard
      if (isBlockedHost(parsedUrl.hostname)) {
        console.warn(`OGProxy reject [${url}]: forbidden host (static guard)`);
        return res.status(403).send('Forbidden host');
      // Cache hit (success OR negative) — checked before DNS to stay fast
      const cachedResult = cache.get(url);
      if (cachedResult) {
        if (cachedResult.__ogproxyFail === true) {
          return res.status(500).send('Error scraping Open Graph data (cached)');
        return res.json(cachedResult);
      // DNS-based SSRF guard: make sure the hostname doesn't resolve to a private IP
      if (!(await resolvesToPublicIp(parsedUrl.hostname))) {
        console.warn(`OGProxy reject [${url}]: resolves to private IP or DNS fail (SSRF guard)`);
        cache.put(url, { __ogproxyFail: true }, FAIL_CACHE_TTL_MS);
      // ogs options: timeout + download limit + bounded redirects
      const options = {
        url,
        timeout: REQUEST_TIMEOUT,
        downloadLimit: MAX_CONTENT_BYTES,
        fetchOptions: {
          redirect: 'follow',
          follow: MAX_REDIRECTS,
          headers: {
            'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36',
            'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8',
            'Accept-Language': 'fr-FR,fr;q=0.9,en;q=0.8',
      // Enforce cache cap before inserting a new entry
      if (cache.keys().length >= CACHE_MAX_ENTRIES) {
        cache.clear();
      try {
        const results = await ogs(options);
        cache.put(url, results, CACHE_TTL_MS);
        return res.json(results);
      } catch (error) {
        const reason =
          (error && error.result && error.result.error) ||
          (error && error.message) ||
          'unknown';
        const status =
          (error && error.response && error.response.status) || 'n/a';
        console.error(`OGProxy fail [${url}]: ${reason} (HTTP ${status})`);
        return res.status(500).send('Error scraping Open Graph data');
    app.listen(port, () => {
      console.log(`OGProxy server listening on port ${port}`);
    NodeBB ACP client script
    // OGPROXY
    /// Function to preview links
    function previewLinks() {
    		// Set this flag to true to enable debug logging
    		var debug = false;
    		// Get all the links within the content class (posts) and chat, excluding mentions plugin links AND already-processed links
    		var links = $(".content a:not(.plugin-mentions-a):not(.plugin-mentions-user):not(.og-processed), [component=\"chat/message/body\"] a:not(.plugin-mentions-a):not(.plugin-mentions-user):not(.og-processed), .preview-container a:not(.plugin-mentions-a):not(.plugin-mentions-user):not(.og-processed), .resolved-message a:not(.og-processed), .adhoc a:not(.og-processed)");
    		// List of bare hostnames to ignore (forum itself + the OGProxy subdomain, to avoid self-scraping)
    		var ignoredHosts = [
    			window.location.hostname,
    			"proxy.YOURDOMAIN.EXT"
    		// List of paths to ignore
    		var ignoredPaths = ['/post'];
    		if (debug) {
    			// Log the ignored hosts and paths
    			console.log("OGProxy: Hosts in the ignore list and will not be parsed: " + ignoredHosts.join(", "));
    			console.log("OGProxy: Paths containing " + ignoredPaths[0] + " are in the ignore list and will not be parsed.");
    			console.log("OGProxy: Parsing DOM for any URLs that should be converted to previews.");
    		// Iterate over each link
    		links.each(function() {
    			var link = $(this);
    			var url = link.attr("href");
    			var hostname = link.prop("hostname");
    			var text = $(this).text();
    			// Helper function to check if the URL is a file URL.
    			// Strip query string and fragment first so e.g. "image.png?ssl=1" is still detected.
    			function isFileUrl(url) {
    				if (!url) {
    					return false;
    				var cleanUrl = url.split('?')[0].split('#')[0];
    				return fileExtensionPattern.test(cleanUrl);
    			function isFullPath(url) {
    				// Regular expression to match a full path URL
    				var fullPathRegex = /^(?:[a-z]+:)?\/\//i;
    				// Check if the URL matches the full path pattern
    				return fullPathRegex.test(url);
    			// Helper function to check if the domain should be ignored
    			// Uses the browser-resolved hostname (reliable even for relative hrefs)
    			function shouldIgnoreDomain(linkHostname, url, ignoredHosts) {
    				if (!linkHostname) {
    					return false;
    				// Ignore if it points to an ignored host AND hits an ignored path
    				if (ignoredPaths.some(function(path) { return url && url.includes(path); }) && ignoredHosts.includes(linkHostname)) {
    					return true;
    				// Ignore any link pointing to an ignored host (forum itself, proxy subdomain)
    				return ignoredHosts.includes(linkHostname);
    			// Helper function to extract the bare hostname from the URL (kept for compatibility)
    			function extractDomain(url) {
    				if (url) {
    					var domain = url.split('/')[2]?.split(':')[0];
    					return domain;
    				return null;
    			// Process the link if it's not a file URL, not in the ignored domain list, and it's the only content within its parent element
    			if (!isFileUrl(url) && !shouldIgnoreDomain(hostname, url, ignoredHosts) && link.parent().contents().length === 1) {
    				var host = window.location.protocol + "//" + hostname;
    				var faviconApi = "https://t0.gstatic.com/faviconV2?client=SOCIAL&type=FAVICON&fallback_opts=TYPE,SIZE,URL&url=" + host + "&size=32";
    				if (debug) {
    					console.log("OGProxy: Getting favicon for URL: " + url);
    				var website = link.prop("hostname");
    				var altSite = website.replace(/^www\./, "").replace(/\..+$/, "");
                    var proxy = "https://proxy.YOURDOMAIN.EXT";
                    var apiKey = "YOUR_API_KEY";
    				// Mark this link as processed BEFORE the request, so it is never re-scraped
    				// on subsequent ajaxify/posts.loaded/composer.preview events, whether the
    				// request succeeds or fails. This stops the request-hammering loop.
    				link.addClass('og-processed');
    				// Send an AJAX request to the proxy server to fetch OpenGraph data for the URL
    				$.ajax({
    					url: proxy + "/ogproxy?url=" + encodeURIComponent(url),
    					method: "GET",
    					headers: {
    						'X-Api-Key': apiKey
    					success: function(data) {
    						var result = data.result;
    						// Extract relevant data from the OpenGraph result or use fallback values
    						var rawTitle = $(data.html).filter('title').text();
    						var altTitle = $(result).filter('meta[property="og:title"]').attr('content');
    						var altDescription = $(result).filter('meta[property="og:description"]').attr('content');
    						var tempDescription = "This website did not return any description. It might be behind a login or paywall.";
    						var altImageUrl = $(result).filter('meta[property="og:image"]').attr('content');
    						//var tempImage = proxy + "/images/404_3.webp";
                            var tempImage = proxy + "/images/404.png";
    						var url = result.requestUrl || url;
    						var title = rawTitle || result.ogTitle || altTitle;
    						var description = result.ogDescription || altDescription || tempDescription;
    						var favicon = faviconApi || result.favicon || data.faviconUrl;
    						var imageUrl = result.ogImage && result.ogImage[0].url || altImageUrl || tempImage;
    						// Some websites return a relative path for the image URL, which isn't much use, so we need to change this to full
    						var fullImagePath = host + imageUrl;
    						var site = result.ogSiteName || altSite;
    						if (isFullPath(imageUrl) === false) {
    							imageUrl = fullImagePath;
    						// Test to see if image is broken in the preview card. This might be the result of hotlinking protection, so the image isn't
    						// rendered as a result. If this is the case, we replace it with the tempImage to keep things looking nice.
    							$('#card-image img').on('error', function() {
    								// Image failed to load
    								// Add logic here to handle the broken image
    								if (debug) {
    									console.log("OGProxy: Broken image URL: " + imageUrl + " detected. Replacing with " + tempImage);
    								$(this).attr('src', tempImage); // Replace with a placeholder image
    						if (debug) {
    							console.log("OGProxy: Getting data from URL: " + url);
    							console.log("OGProxy: Getting image URL: " + imageUrl);
    						// Create the HTML for the link preview card
    						var cardHtml = '<div class="card card-wrapper og-processed">' +
    						    '<a href="' + url + '" class="og-processed">' +
    							'<div class="card card-preview">' +
    							'<div class="card-image-container">' +
    							'<div id="card-image"><img src="' + imageUrl + '"></div>' +
    							'</div>' +
    							'<div class="card-body">' +
    							'<h4 id="sitetitle" class="card-site-title"><img id="favicon" class="card-favicon" src="' + favicon + '">' + site + '</h4>' +
    							'<h6 class="card-title">' + title + '</h6>' +
    							'<p class="card-text">' + truncateDescription(description, 150) + '</p>' +
    							'</div>' +
    							'</div>' +
    							'</div>' +
    							'</a>';
    						// Replace the original link with the link preview card
    						link.replaceWith(cardHtml);
    					error: function() {
    						if (debug) {
    							console.log("OGProxy: Error fetching OpenGraph data for URL: " + url);
    						// Link stays in the DOM but is already marked .og-processed,
    						// so it will not be retried on subsequent events.
    // Helper function to truncate the description with ellipsis if it exceeds the specified limit
    function truncateDescription(description, limit) {
    	if (description.length > limit) {
    		return description.substring(0, limit) + '...';
    	return description;
    		previewLinks()
    $(window).on('action:posts.loaded', function(data) {
    		previewLinks()
    $(window).on('action:posts.edited', function(data) {
    		previewLinks()
    /* TEST BUG */
    $(window).on('action:chat.loaded', function(data) {
    		previewLinks()
    $(window).on('action:chat.received', function(data) {
    		previewLinks()
    $(window).on('action:composer.preview', function(data) {
    		previewLinks()
    systemd unit (/etc/systemd/system/ogproxy.service)
    [Unit]
    Description=OGProxy Server
    After=network.target
    [Service]
    ExecStart=/usr/bin/node /home/XXXXXXXXXXXXXXXX/domains/proxy.XXXXXXXXX.XXX/ogproxy/server.js
    WorkingDirectory=/home/XXXXXXXXXXXXXXXX/domains/proxy.XXXXXXXXX.XXX/ogproxy
    Restart=always
    RestartSec=3
    RuntimeMaxSec=86400
    # --- Memory safeguards ---
    MemoryMax=512M
    MemoryHigh=400M
    # --- Network egress guard (anti-SSRF at kernel level) ---
    # Allow loopback (nginx reverse-proxies here on 127.0.0.1:2000) + DNS stub resolver.
    # Block all private ranges and cloud metadata so a redirect can't reach them.
    # The app-level isBlockedHost() guard still rejects 127.0.0.1 on the initial URL.
    IPAddressAllow=127.0.0.1 127.0.0.53 127.0.0.54
    IPAddressDeny=10.0.0.0/8 172.16.0.0/12 192.168.0.0/16 169.254.0.0/16 100.64.0.0/10 fc00::/7 fe80::/10
    [Install]
    WantedBy=multi-user.target
  • OGProxy : follow-up: second memory leak found & fixed
    Context
    After this morning’s fixes (download limit, cache TTL, systemd MemoryMax), the server stayed up, but during the afternoon OGProxy slowly climbed to 464 MB RSS with all 4 GB of swap consumed. The systemd MemoryMax=512M guard rail did its job (it capped OGProxy instead of letting it take the whole box down like before), which bought time to diagnose calmly. This was a second, separate leak, slower than the first.
    Root cause
    The logs showed the smoking gun:
    MaxListenersExceededWarning: Possible EventEmitter memory leak detected.
    22 terminated listeners added to [Fetch]. MaxListeners is 21.
    Stack: ogs 6.1.0 → undici 5.22.1 on Node 24. ogs v6 implements its timeout option via an AbortSignal passed to undici. With this version combo, when a request is aborted by that internal timeout, the abort listener attached to the Fetch object is not removed. Every timed-out request leaks one listener, and they accumulate in memory.
    Trigger: a 10-day-old forum post listing ~10 store.ubisoft.com links. Opening that topic fires ~10 previews in parallel, all hitting the timeout, each leaking a listener. Repeated views over the day pushed it to 464 MB + full swap.
    There was also a vicious circle: as the process bloated, its own outbound fetches got slow enough to time out, which created more timeouts, which leaked more listeners. That explains the flood of Connect Timeout Error in the afternoon logs, hey were a symptom of the leak, not an external block. Once restarted fresh, those same Ubisoft URLs returned success: true in ~2.4 s.
    Fix
    Stop using ogs’s internal timeout option (the leaking path). Instead, manage the timeout with our own AbortController + setTimeout, pass the signal via fetchOptions, and always clearTimeout() in a finally block, which detaches the abort listener on every exit path (success, failure, or timeout). Also raised EventEmitter.defaultMaxListeners to 50 as a safety net for legitimate concurrency bursts (like that 10-link post).
    Verified: with our own signal aborting at 3 s, a Ubisoft URL completed in 2.4 s (signal is respected by ogs 6.1). After deploy, no more MaxListenersExceededWarning, no more cascade timeouts, and memory now oscillates (217 MB under load → back down to 91 MB at rest) instead of climbing and staying climbed.
    Note on RuntimeMaxSec
    The existing RuntimeMaxSec=86400 (forced daily restart) was almost certainly an earlier band-aid masking exactly this leak. Now that the cause is fixed, it can be removed once stability is confirmed over 24–48 h, but it’s harmless to keep for now.
    Only server.js changed (client ACP + systemd unit unchanged)
    // Raise the listener ceiling as a safety net against transient concurrency spikes
    require('events').EventEmitter.defaultMaxListeners = 50;
    const port = 2000;
    const apiKey = process.env.OGPROXY_API_KEY || 'YOUR_API_KEY_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx';
        return false;
        return false;
      return (
      try {
      } catch (e) {
    app.use(cors({ origin: 'https://YOUR_DOMAINE.EXT' }));
        try {
        } catch (e) {
      let parsedUrl;
      try {
      } catch (e) {
      if (cachedResult) {
        cache.clear();
      // Manage the timeout ourselves with an AbortController we clean up explicitly.
      // This avoids the listener leak from ogs/undici's internal `timeout` option
      // (ogs 6.x + undici 5.x on Node 24 leaks an abort listener per timed-out request,
      // which slowly fills RAM/swap). clearTimeout() in finally detaches the listener.
      const controller = new AbortController();
      const timer = setTimeout(() => controller.abort(), REQUEST_TIMEOUT);
      const options = {
        url,
        fetchOptions: {
          signal: controller.signal,
          redirect: 'follow',
          headers: {
      try {
      } catch (error) {
        const reason =
          'unknown';
        const status =
      } finally {
        // Always clear the timer — detaches the abort listener and stops the leak
        clearTimeout(timer);
    Possible upstream-clean alternative (optional)
    Upgrading open-graph-scraper to its latest 6.x (which bundles a newer undici) may fix the listener cleanup at the source, letting you go back to the simpler built-in timeout option. Worth checking when convenient, but the AbortController approach above is robust regardless of the undici version, so there’s no rush.
  • OGProxy : Other Memory Saturation Root Cause & Fix
    OGProxy was periodically saturating server RAM and swap (up to ~4 GB of
    arrayBuffers, swap fully consumed), causing multi-minute service degradation.
    After tracing through several misleading leads, the root cause was identified:
    OGProxy was downloading entire file-host link bodies into memory when trying
    to generate previews.
    On a file-sharing forum, links to file hosts (1fichier, etc.) are everywhere.
    When OGProxy received a URL like https://1fichier.com/?xxxx, it attempted to
    “preview” it, but that URL is a direct file download
    (Content-Type: application/octet-stream, Content-Length: 20.6 GB). OGProxy
    pulled the file into memory. Critically, neither open-graph-scraper’s
    downloadLimit nor an AbortController stopped this
    , verified by
    reproduction: arrayBuffers climbed ~120 MB/s past 4 GB while the abort
    timeout was ignored.
    Diagnostic path (for reference)
    We instrumented the process with a /debug/mem endpoint exposing
    process.memoryUsage() + cache size, plus a 30-second sampling trace. This let
    us correlate memory spikes with nginx access logs. The trace showed
    arrayBuffers jumping from 0 → 457 → 3669 MB in ~5 minutes, correlated via
    nginx log to a single GET on a 1fichier link. The cache, EventEmitter
    listeners, and image links were all ruled out as primary causes (cache stayed
    at <30 entries during the spike; heapUsed stayed low; only arrayBuffers
    leaked).
    A representative slice of the trace at the moment of the spike:
    11:24:39  arrayBuffers=0     rss=161
    11:25:09  arrayBuffers=457   rss=427   <- jump in one 30s sample
    11:25:39  arrayBuffers=884
    11:26:09  arrayBuffers=1437
    11:30:09  arrayBuffers=3669
    No OGProxy fail log line appeared during the spike window, the offending
    request neither failed nor completed; it was an in-progress, never-ending
    download. The nginx access log for that minute pointed at the 1fichier GET.
    Root cause
    open-graph-scraper (ogs) performs its own internal fetch, and for these URLs:
    • The downloadLimit option does not reliably abort the body download on
      streamed / chunked responses or on hosts that serve large
      application/octet-stream payloads.
    • An AbortController passed via fetchOptions.signal does not propagate
      to the underlying stream read in a way that stops the transfer in time.
    Result: a single large file-host link could pull multiple GB into
    arrayBuffers before anything intervened.
    The fix: bounded streaming fetch
    The structural problem is that ogs() controls the fetch and we don’t control
    body consumption. The fix moves the fetch into our own code so we control every
    byte read:
    • boundedFetch(url, maxBytes, timeoutMs) performs the HTTP fetch itself,
      then:
      • Re-checks the final host for SSRF after redirects.
      • Rejects any non-text/html / application/xhtml Content-Type
        before reading the body (aborts immediately).
      • Reads the body chunk-by-chunk via resp.body.getReader(), tracking total
        bytes, and hard-aborts at 5 MB regardless of what the server claims.
    • The retrieved HTML is then handed to ogs for parsing only: ogs({ html }).
    This makes the protection structural rather than cooperative: no file host
    can leak memory regardless of whether it honors HEAD, serves chunked, or
    misreports headers.
    Important ogs constraint
    You must call ogs({ html }) alone. Passing { html, url } together
    throws:
    Must specify either `url` or `html`, not both
    Because url is omitted, ogs cannot resolve relative og:image paths. This is
    fine here: the ACP client already resolves relative image paths itself
    (isFullPath() + host + imageUrl), so no client-side change was required.
    Other hardening applied in the same pass
    • Cache: replaced memory-cache (which creates a per-entry setTimeout
      that retains the cached object, a secondary leak) with a plain Map using
      lazy expiry + a single sweep interval. Stored value is slimmed via
      slimResult(): only error + result + HTML truncated at </head>
      (preserves <title>, drops the multi-MB body and the undici response
      object). Cap 300 entries, 30 min TTL, 10 min negative-cache TTL.
    • Negative cache: failed/rejected URLs are cached to prevent re-scrape
      hammering from the client.
    • SSRF guards (three layers): static host/IP blocklist (private ranges,
      loopback, link-local, CGNAT, IPv6 ULA/link-local), DNS resolution check, and
      post-redirect re-validation of the final host. (Also backed at the OS level
      by systemd IPAddressDeny on the unit.)
    • AbortController + clearTimeout in finally to stop the earlier
      MaxListenersExceededWarning listener leak on timed-out requests.
    • nginx rate limit: limit_req_zone (10 r/s, burst 50, nodelay, returns
      429) on the /ogproxy location. The API key is necessarily exposed
      client-side (it ships in the ACP JS), so it provides no real protection on its
      own; the rate limit is the actual abuse mitigation.
    • systemd guard rail: MemoryMax=512M / MemoryHigh=400M so OGProxy can
      never take the whole box down again, this was the silent hero that kept the
      server alive throughout diagnosis.
    Validation
    Test URL Expected Result
    https://1fichier.com/?xxxx (20.6 GB) reject, no body read 415, arrayBuffers stays 0
    Direct image (pbs.twimg.com/...jpg) reject on content-type 415
    https://github.com full preview 200, OG title/image/description, HTML truncated at </head>
    Process idles at ~100 MB RSS; under load heapUsed oscillates and returns to
    baseline (no step-up accumulation).
    Reproduction of the bounded fetch against the 20.6 GB link, confirming zero
    body is pulled:
    arrayBuffers AVANT: 0 MB
      pendant: 0 MB
    Resultat 1fichier: REJETE: non-HTML content-type: application/octet-stream
    arrayBuffers APRES: 0 MB
    Note on dependencies
    Reproduced on open-graph-scraper 6.1.0 / undici 5.22.1 / Node 24. The
    unreliable downloadLimit behavior may be version-specific; a newer undici
    might handle aborts on large streams better. The bounded-fetch approach is
    robust regardless of the underlying library version, so it is the recommended
    long-term fix.
    Appendix A: Full server.js
    const port = 2000;
    const apiKey = process.env.OGPROXY_API_KEY || '<API_KEY>';
    const REQUEST_TIMEOUT = 12000;
    const MAX_CONTENT_BYTES = 5 * 1024 * 1024;    // 5 MB hard cap on body
    const CACHE_TTL_MS = 30 * 60 * 1000;
    const CACHE_MAX_ENTRIES = 300;
    // --- Map cache (lazy expiry, no per-entry timers) ---
    const cacheStore = new Map();
    function cacheGet(key) {
      const e = cacheStore.get(key);
      if (!e) return null;
      if (Date.now() > e.expires) { cacheStore.delete(key); return null; }
      return e.value;
    function cacheSet(key, value, ttl) {
      if (cacheStore.size >= CACHE_MAX_ENTRIES) {
        cacheStore.delete(cacheStore.keys().next().value);
      cacheStore.set(key, { value, expires: Date.now() + ttl });
    setInterval(() => {
      const now = Date.now();
      for (const [k, e] of cacheStore) if (now > e.expires) cacheStore.delete(k);
    }, 60 * 1000).unref();
    function slimResult(results) {
      if (!results || typeof results !== 'object') return results;
      let slimHtml = '';
      if (typeof results.html === 'string') {
        const headEnd = results.html.search(/<\/head>/i);
        slimHtml = headEnd !== -1 ? results.html.slice(0, headEnd + 7) : results.html.slice(0, 8192);
      return { error: results.error, result: results.result, html: slimHtml };
        return false;
        return false;
      return true;
      return (
        h === 'localhost' || h.endsWith('.localhost') ||
        h.endsWith('.internal') || h.endsWith('.local') ||
      try {
      } catch (e) {
        return false;
    // Bounded streaming fetch: reads the body chunk by chunk and aborts hard at maxBytes.
    // Rejects non-HTML content-types before reading any body. Structural protection
    // against file hosts (1fichier, etc.) - independent of what the server claims.
    async function boundedFetch(url, maxBytes, timeoutMs) {
      const timer = setTimeout(() => controller.abort(), timeoutMs);
      try {
        const resp = await fetch(url, {
          redirect: 'follow',
          headers: {
        // Re-check final host after redirects (anti-SSRF)
        try {
          const finalHost = new URL(resp.url || url).hostname;
          if (isBlockedHost(finalHost) || !(await resolvesToPublicIp(finalHost))) {
            controller.abort();
            return { ok: false, reason: 'redirect to forbidden host' };
        } catch (e) { /* ignore */ }
        const ctype = (resp.headers.get('content-type') || '').toLowerCase();
        if (ctype && !ctype.includes('text/html') && !ctype.includes('application/xhtml')) {
          controller.abort(); // not HTML: read nothing
          return { ok: false, reason: `non-HTML content-type: ${ctype.split(';')[0]}` };
        if (!resp.body) {
          return { ok: false, reason: 'no response body' };
        const reader = resp.body.getReader();
        const chunks = [];
        let total = 0;
        while (true) {
          const { done, value } = await reader.read();
          if (done) break;
          total += value.length;
          if (total > maxBytes) {
            controller.abort(); // hard cap reached: stop downloading
            return { ok: false, reason: `body exceeded ${maxBytes} bytes` };
          chunks.push(value);
        const html = Buffer.concat(chunks).toString('utf8');
        return { ok: true, html };
      } catch (e) {
        return { ok: false, reason: (e && e.name === 'AbortError') ? 'timeout/abort' : (e && e.message) || 'fetch error' };
      } finally {
    app.use(cors({ origin: 'https://YOUR_DOMAIN.EXT' }));
    app.get('/debug/mem', (req, res) => {
      const m = process.memoryUsage();
      res.json({
        rss_mb: Math.round(m.rss / 1048576),
        heapUsed_mb: Math.round(m.heapUsed / 1048576),
        external_mb: Math.round(m.external / 1048576),
        arrayBuffers_mb: Math.round(m.arrayBuffers / 1048576),
        cache_entries: cacheStore.size,
      if (requestApiKey !== apiKey) return res.status(401).send('Unauthorized');
      if (!url || typeof url !== 'string') return res.status(400).send('Missing URL parameter');
        try { url = new URL(url, `${req.protocol}://${req.get('host')}`).href; }
        catch (e) { return res.status(400).send('Invalid URL'); }
      let parsedUrl;
      try { parsedUrl = new URL(url); }
      catch (e) { console.warn(`OGProxy reject [${url}]: invalid URL`); return res.status(400).send('Invalid URL'); }
      const cached = cacheGet(url);
      if (cached) {
        if (cached.__ogproxyFail === true) return res.status(500).send('Error scraping Open Graph data (cached)');
        return res.json(cached);
        console.warn(`OGProxy reject [${url}]: resolves to private IP / DNS fail (SSRF)`);
        cacheSet(url, { __ogproxyFail: true }, FAIL_CACHE_TTL_MS);
      // Bounded fetch: download the body ourselves, capped at 5 MB, HTML-only.
      const fetched = await boundedFetch(url, MAX_CONTENT_BYTES, REQUEST_TIMEOUT);
      if (!fetched.ok) {
        console.error(`OGProxy reject [${url}]: ${fetched.reason}`);
        const code = (fetched.reason.startsWith('non-HTML') || fetched.reason.startsWith('body exceeded')) ? 415 : 500;
        return res.status(code).send('Unable to preview this URL');
      try {
        // Parse the already-fetched HTML (no second fetch). Client resolves relative image paths itself.
        const results = await ogs({ html: fetched.html });
        const slim = slimResult(results);
        cacheSet(url, slim, CACHE_TTL_MS);
        return res.json(slim);
      } catch (error) {
        const reason = (error && error.result && error.result.error) || (error && error.message) || 'unknown';
        console.error(`OGProxy fail [${url}]: ${reason}`);
    Note: /debug/mem is a temporary diagnostic endpoint. Remove it once the
    deployment is confirmed stable in production.
    Appendix B: nginx rate limit
    Zone definition, placed in /etc/nginx/conf.d/ogproxy-ratelimit.conf (included
    at the http level; survives vhost regeneration by the panel):
    # Rate limit zone for OGProxy - 10 MB shared memory (~160k IPs tracked)
    # 10 requests/second sustained per IP
    limit_req_zone $binary_remote_addr zone=ogproxy_limit:10m rate=10r/s;
    Application, inside the reverse-proxy location / of the OGProxy vhost:
    location / {
        limit_req zone=ogproxy_limit burst=50 nodelay;
        limit_req_status 429;
        proxy_set_header Host $host;
        proxy_pass http://127.0.0.1:2000;
        proxy_redirect off;
        proxy_set_header X-Api-Key $http_x_api_key;
    burst=50 absorbs the legitimate burst when a user opens a link-heavy topic
    (the client fires many preview requests at once); sustained hammering beyond
    that is rejected with 429.
    Appendix C : systemd unit guard rails
    Key directives on ogproxy.service:
    [Service]
    MemoryHigh=400M
    MemoryMax=512M
    Restart=always
    RestartSec=3
    # SSRF egress guard (OS-level backstop to the in-app checks)
    127.0.0.1 must stay allowed because nginx reverse-proxies to OGProxy over
    loopback; blocking all loopback breaks the nginx -> ogproxy hop (504s).
  • ANNOUNCEMENT: Social Login Changes
    Announcements openid oauth
    @DownPW Always looking for ways to improve the overall experience.
  • ANNOUCEMENT: New NTFY Server
    Announcements ntfy push alerts
    @crazycells that’s as good a test as any
  • Clustering for NodeBB enabled
    Announcements cluster
    @Madchatthew True. I think this is the reason as to why most Open Source projects are abandoned because they are not sustainable in the long-term.
  • Link Not Working
    Solved Customisation link
    @cagatay Good question, but one that’s likely best answered by the devs themselves. Could easily be done with a simple jQuery regex but that would really just be painting over rotten wood.
  • Testing out Webdock.io
    Moved Announcements webdock recovery speed
    Just coming back to this thread for review (as I often do), and it looks like Webdock have increased their available offerings - some are extremely powerful, yet very competitive from the pricing perspective. [image: 1692559685163-7cf9a928-ac21-44fe-99c6-90439030d631-image.png] 10 CPU cores, plus 20Gb RAM? Well worth a look (and the asking price) - there’s also a fixed IP which is hugely beneficial. Clearly, this is well beyond what most people will want to spend - it’s more of an example (but interestingly, Sudonix runs on something not too different from the above). However, not all that glitters is gold - just have a walk through the benchmark report I found below and you’ll see a huge difference between Heztner and Webdock https://www.vpsbenchmarks.com/compare/hetzner_vs_webdock That being said, the amount of HTTP requests that Webdock handles in relation to Hetzner is superior - @DownPW you might want to have a look at this - there’s a free 24 hour trial… [image: 1692560710486-5203639b-2f62-47e6-b87b-37580ce5deae-image.png]
    Announcements fancybox
