NodeBB v3 Chat Very Slow
Moved Performance
47 3 22.3k 1
    Absolutely 🙂
    Weeding, mower, vegetable garden, sowing, tiller, etc.
    I’ve been on it for 2 whole weekends but the weather is nice and it’s good for the mind to take a little nature break 🙂
  • Absolutely 🙂
    @DownPW two weekends? Do you have a garden, or a field? 🤔
    #23
    1000m2 of garden including 35m2 of vegetable garden. we had to turn over, beaker, weed the vegetable garden with grelinette then plant everything: potatoes, green beans, tomatoes, cherry tomatoes, salads, cucumber, zucchini… and mulch everything
    Then I weeded all my flower beds and then mowed the lawn. I mow once a week at the moment or maximum every 2 weeks.
    I also planter 2 beds tulip land (2x 5m)
    In short, a lot of work casually and with the 2 children at home, including a 2-year-old to watch, it’s not easy.
  • 1000m2 of garden including 35m2 of vegetable garden. we had to turn over, beaker, weed the vegetable garden with grelinette then plant everything: potatoes, green beans, tomatoes, cherry tomatoes, salads, cucumber, zucchini… and mulch everything
    @DownPW that’s a huge garden, and great that you’re growing your own produce too. A lot of work though… Impressive 👍
    After upgrading 3.2.0, the typing field is narrowed.
  • After upgrading 3.2.0, the typing field is narrowed.
    @cagatay In where, and what ?
    Here I think
    That’s a regression bug I think. You now have to press ALT + ENTER to get an extra line appear
  • Here I think
    @DownPW said in NodeBB v3 Chat Very Slow:
    Here I think
    yes you are right @DownPW
    @phenomlab how can i expand it?
    Odd, node like that on nodebb communauty
  • Odd, node like that on nodebb communauty
    @DownPW as I said previously, likely a regression introduced by 3.2.0
    But nodebb forum communauty is on 3.2.0 no ?
    If yes, they don’t have this problem
    They deactivate background and box shadow on nodebb communauty :
  • They deactivate background and box shadow on nodebb communauty :
    @DownPW None of those will impact the box size. Let me have a look.
    yep not box size but we don’t see the bug
  • yep not box size but we don’t see the bug
    @DownPW what exactly is the bug? I’ve tested it, and it behaves normally from what I see (unless I completely missed something)?
    Size is good, is just the focus when we type text it has changed
    on 3.1.7 :
    On 3.2.0 here :
  • Size is good, is just the focus when we type text it has changed
    on 3.1.7 :
    On 3.2.0 here :
    @DownPW Yes, that’s input:focus - it’s used to style much larger boxes on focus, but I’ll need to create an exemption here.
    Nodebb communauty :
  • Nodebb communauty :
    #40
    @DownPW @cagatay Thanks for reporting. Should match now.
    Performance nodebb script die
    15k Views
    Solved. Tuto here and here
  • error with v3 in browser console
    Solved Performance socket error csrf
    @DownPW it’s in relation to the response I provided above
  • Optimum config for NodeBB under NGINX
    Performance nginx performance
    @crazycells hi - no security reason, or anything specific in this case. However, the nginx.conf I posted was from my Dev environment which uses this port as a way of not interfering with production. And yes, I use clustering on this site with three instances.
  • Chevron up before & after
    @crazycells you are right thank you.
  • NodeBB 1.19.3
    Solved Performance nodebb 1.19.3 performance
    33
    @phenomlab I find the problem Mark The error message indicated this path : http://localhost:4567/assets/plugins/nodebb-plugin-emoji/emoji/styles.css?v=6983dobg16u I change the path url on config.json [image: 47bacc80-f141-41e4-a261-3f8d650cc6f6-image.png] And all it’s good Weird, I didn’t have to change that path before 1.19.3 But this does not prevent the problem from a clean install with Emoji Plugin EDIT: After test, that resolv the problem installation for 1.18.x but not for 1.19.x (I have other error message when I run ./nodebb Setup For resume: NodeJS 16_x with 1.18.x is ok
  • [NodeBB] username cards
    @phenomlab Aha…nice to know. As always thank you for the reply and information.
