Digitalocean step by step guide to nginx configuration
36 2 14.3k 1
  • configure ghost and wordpress combo
    Moved Solved WordPress ghost wordpress nginx
    @Hari Really? Can you elaborate a bit more here?
  • Is nginx necessary to use?
    Moved Solved Hosting nginx web
    @Panda said in Cloudflare bot fight mode and Google search: Basic question again, is nginx necessary to use? No, but you’d need something at least to handle the inbound requests, so you could use Apache, NGINX, Caddy… (there are plenty of them, but I tend to prefer NGINX) @Panda said in Cloudflare bot fight mode and Google search: Do these two sites need to be attached to different ports, and the ports put in the DNS record? No. They will both use ports 80 (HTTP) and 443 (HTTPS) by default. @Panda said in Cloudflare bot fight mode and Google search: Its not currently working, but how would the domain name know which of the two sites to resolve to without more info? Currently it only says the IP of the whole server. Yes, that’s correct. Domain routing is handled (for example) at the NGINX level, so whatever you have in DNS will be presented as the hostname, and NGINX will expect a match which once received, will then be forwarded onto the relevant destination. As an example, in your NGINX config, you could have (at a basic level used in reverse proxy mode - obviously, the IP addresses here are redacted and replaced with fakes). We assume you have created an A record in your DNS called “proxy” which resolves to 192.206.28.1, so fully qualified, will be proxy.sudonix.org in this case. The web browser requests this site, which is in turn received by NGINX and matches the below config server { server_name proxy.sudonix.org; listen 192.206.28.1; root /home/sudonix.org/domains/proxy.sudonix.org/ogproxy; index index.php index.htm index.html; access_log /var/log/virtualmin/proxy.sudonix.org_access_log; error_log /var/log/virtualmin/proxy.sudonix.org_error_log; location / { proxy_set_header Access-Control-Allow-Origin *; proxy_set_header Host $host; proxy_pass http://localhost:2000; proxy_redirect off; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Api-Key $http_x_api_key; } location /images { index index.php index.htm index.html; root /home/sudonix.org/domains/proxy.sudonix.org/ogproxy; } fastcgi_split_path_info "^(.+\.php)(/.+)$"; listen 192.206.28.1:443 ssl http2; ssl_certificate /home/sudonix.org/domains/proxy.sudonix.org/ssl.combined; ssl_certificate_key /home/sudonix.org/ssl.key; } The important part here is server_name proxy.sudonix.org; as this is used to “map” the request to the actual domain name, which you can see in the root section as root /home/sudonix.org/domains/proxy.sudonix.org/ogproxy; As the DNS record you specified matches this hostname, NGINX then knows what to do with the request when it receives it.
    60k Views
  • Virtualmin Setup DigitalOcean
    Solved Customisation virtualmin digitalocean
    26
    @Hari said in Virtualmin Setup DigitalOcean: i have felt it is very hard to manage Virtualmin the settings are confusing It’s a bit of a learning curve, admittedly, but very powerful and easy to use provided you understand the implications of what you are doing. For example, moving a VirtualMin server to subserver and then back again without changing underlying components that rely on the correct placement of the server, of course it will no longer work.
  • how to configure DNS records virtualmin?
    Solved Linux digitalocean dns
    26
    i think we can mark this discussion as solved learned how to install virtualmin with NGINX We can easily point the DNS by mentioning server IP at CF a name record learned how to install SSL
  • nginx can't start again
    Moved Solved Configure nginx server error
    @elhana-fine Yes that will happen of course if you still choose to restart the NGINX service after making a change and the test fails. The test on it’s own will state the error and the line number allowing you to fix that first
  • help me configuring cron job for fof/sitemap - flarum
    18 Votes
    you are too fast
