Issues with 2nd NodeBB installation
22 2 9.5k 1
  • @cagatay You’d need to delete these manually or reinstall with a blank database.
    #21
    @phenomlab may i use iframely for 2 domains also in the one machine?
    answer- yes worked 🙂 thank you
  • @phenomlab may i use iframely for 2 domains also in the one machine?
    @cagatay yes, that will be fine. Just watch for potential caching conflicts as you will have two sites writing to the one instance of iframely.
  • TNG + Nodebb
    General tng genealogy nodebb plugin
    @Madchatthew said in TNG + Nodebb: you have to try and use duck tape and super glue to change something to make it do what you want it to do I couldn’t have put that better myself.
  • Nodebb design
    Solved General nodebb
  • Welcome to NodeBB V3!
    Pinned Moved General v3-prod code changes
  • Fresher in Nodebb install
    General nodebb
    @Hari I’ve been reading a lot about APO. Looks impressive.
  • NodeBB v2.4.0
    Solved General nodebb version error
    @phenomlab As always…Thank you. Worked for me.
  • Nodebb as blogging platform
    General blog
    @qwinter I’ve extensive experience with Ghost, so let me know if you need any help.
    @qwinter this particular site uses the code I wrote if you want to see it in action. It’s a information and intelligence gatherer I designed for collecting various information security articles from around the globe and consolidating them in one place. Essentially, each “post” is in fact generated by the script, and the NodeBB API. https://hostrisk.com/
  • NodeBB vs Flarum for a non developer
    @marusaky That’s really easily done. I think the docs need updating for the latest release. Did you land up on the 18.x train ?
