Create a self-hosted instance of NTFY
Moved Guides
63 4 34.8k 1
  • We got this working. I’m not sure if it was on my buddys end.
    Here the steps:
    1. Add new sub in ntfy app with the private ID and using another server (ntfy.mydomain.com)
    2. In settings also use the ntfy url as default Server
    3. add the upstream-base-url: “https://ntfy.sh” property in server.yaml and restart ntfy
    @dave1904 said in Create a self-hosted instance of NTFY:
    Here the steps:
    thanks for the update! 👍
    Here the steps:
    @dave1904
    Hi
    Thanks for your explanations.
    I tried this settings but still doesn’t work. I always have to slide down to see new messages.
    Does anybody have the same trouble or a solution ?
    Thank you
  • @dave1904
    Hi
    Thank you
    @sebmegag hi. Welcome aboard! I’ve tried this on both iPhone and Android and it works fine. Did you double check the config you have?
