Virtualmin SQL problem
Solved Performance
39 2 17.6k 1
  • @DownPW the thing that concerns me here is that I’ve never seen an issue like this occur with no cause or action taken by someone else.
    Do you know if anyone else who has access to the server has made any changes ?
    #21
    @phenomlab said in Virtualmin SQL problem:
    hmm no or nothing special. we don’t touch mySQL but it seems to be a known problem
    We manage our nodebb/virtualmin/wiki backup, manage iframely or nodebb, update package but nothing more…
    –> Could you take a look at it when you have time?
  • @phenomlab said in Virtualmin SQL problem:
    @DownPW yes, of course. I’ll see what I can do with this over the weekend.
  • @DownPW yes, of course. I’ll see what I can do with this over the weekend.
    @phenomlab That’s great, Thanks Mark 👍
    Are you sure for my.cnf file because it is located on /etc/alternatives/my.cnf
    And here is the file:
    like this ?:
    if i see into webmin the mySQL servers, it’s already activated:
    @DownPW I’ve just re read this post and apologies - this command
    SET GLOBAL innodb_undo_log_truncate=ON;
    Has to be entered within the mySQL console then the service stopped and restarted.
    Can you try this first before we do anything else?
  • @DownPW I’ve just re read this post and apologies - this command
    #25
    Hello 😊
    Can yo read this post and the screen at the end (mySQL variable already activate) :
    https://sudonix.com/user/downpw
    Hello 😊
    #26
    @DownPW can you post the output from the mySQL console
    SELECT NAME, SPACE_TYPE, STATE FROM INFORMATION_SCHEMA.INNODB_TABLESPACES WHERE SPACE_TYPE = 'Undo' ORDER BY NAME;
    I’m interested to see exactly which tables are causing this. It’s absolutely an artefact of a transaction that has not been completed. The question here is exactly what has caused this. I considered the possibility that this could be a bug in the virtualmin version you are running, although mine is the same, and I’m not experiencing this issue at all.
    To be completely sure, I build another instance on my local network at home and couldn’t replicate this either.
    Can you check with anyone else who has access to this server to see if any installations or upgrades have been attempted that night have failed? Understanding the origin is important at this stage in order to prevent recurrence.
    The below SQL statement should produce a list of running transactions
    SELECT trx.trx_id,
           trx.trx_started,
           trx.trx_mysql_thread_id
    FROM INFORMATION_SCHEMA.INNODB_TRX trx
    JOIN INFORMATION_SCHEMA.PROCESSLIST ps ON trx.trx_mysql_thread_id = ps.id
    WHERE trx.trx_started < CURRENT_TIMESTAMP - INTERVAL 1 SECOND
      AND ps.user != 'system_user';
    Finally, you should be able to identify the process itself, and kill it by using the below SQL
    SELECT *
    FROM performance_schema.threads
    WHERE processlist_id = thread_id;
    Ideally, once the rogue process has been killed, the rollback attempt should be terminated and disk space reclaimed (after a few hours)
    Let me know how you get on.
    You should also perhaps review this article as it will likely be very useful
    https://stackoverflow.com/questions/62740079/mysql-undo-log-keep-growing
  • @DownPW can you post the output from the mySQL console
    SELECT trx.trx_id,
           trx.trx_started,
    SELECT *
    Yep Mister. I will do this tonight after work 😉
    Thanks
    Thanks
    @DownPW Great. Keep me updated. Interested to know the outcome.
  • @DownPW Great. Keep me updated. Interested to know the outcome.
    #29
    Since I manually deleted these 2 big files: undo_001 & undo_002, these 2 files have been regenerated and have not changed in size for 2 days (16Mb)
    Only the mysql.ibd file (15,6 Go) is still big but it doesn’t change in size for the moment.
    We have no other information to our knowledge but I see an update of kernel which was not yet done because it required a reboot at that time.
    – Here is the output of :
    mysql> SELECT NAME, SPACE_TYPE, STATE FROM INFORMATION_SCHEMA.INNODB_TABLESPACES WHERE SPACE_TYPE = 'Undo' ORDER BY NAME;
    | NAME            | SPACE_TYPE | STATE  |
    | innodb_undo_001 | Undo       | active |
    | innodb_undo_002 | Undo       | active |
    2 rows in set (0.05 sec)
    SELECT trx.trx_id,
           trx.trx_started,
    I don’t know if I write it correctly in SQL console ?
    mysql> SELECT trx.trx_id,
        ->        trx.trx_started,
        ->        trx.trx_mysql_thread_id
        -> FROM INFORMATION_SCHEMA.INNODB_TRX trx
        -> JOIN INFORMATION_SCHEMA.PROCESSLIST ps ON trx.trx_mysql_thread_id = ps.id
        -> WHERE trx.trx_started < CURRENT_TIMESTAMP - INTERVAL 1 SECOND
        ->   AND ps.user != 'system_user';
    Empty set (0.00 sec)
    Well that doesn’t tell me why the mysql.ibd file is 15.6 GB 😒
    SELECT trx.trx_id,
           trx.trx_started,
        ->        trx.trx_started,
    #30
    Here is the result of another mySQL query to see the size of all my databases
    but it gave the following result :
    mysql> SELECT table_schema AS "Database",
        -> ROUND(SUM(data_length + index_length) / 1024 / 1024, 2) AS "Size (MB)"
        -> FROM information_schema.TABLES
        -> GROUP BY table_schema;
    | Database           | Size (MB) |
    | information_schema |      0.00 |
    | mysql              |      2.59 |
    | performance_schema |      0.00 |
    | sys                |      0.02 |
    4 rows in set (0.41 sec)
    –> None of these results come close to the size of the mysql.ibd file.
    BTW following is the result of other query i found for check the unused space of tablespace :
    mysql> select table_name, SUM(data_length+index_length), MAX(data_free)
        -> from information_schema.tables
        -> where table_schema='mysql'
        -> group by table_name
        -> with rollup;
    | TABLE_NAME                                           | SUM(data_length+index_length) | MAX(data_free) |
    | columns_priv                                         |                         16384 |    16326328320 |
    | component                                            |                         16384 |    16326328320 |
    | db                                                   |                         32768 |    16326328320 |
    | default_roles                                        |                         16384 |    16326328320 |
    | engine_cost                                          |                         16384 |    16326328320 |
    | func                                                 |                         16384 |    16326328320 |
    | general_log                                          |                             0 |              0 |
    | global_grants                                        |                         49152 |    16326328320 |
    | gtid_executed                                        |                         16384 |    16326328320 |
    | help_category                                        |                         32768 |    16326328320 |
    | help_keyword                                         |                        262144 |    16326328320 |
    | help_relation                                        |                         98304 |    16326328320 |
    | help_topic                                           |                       1687552 |    16326328320 |
    | innodb_index_stats                                   |                         16384 |    16326328320 |
    | innodb_table_stats                                   |                         16384 |    16326328320 |
    | password_history                                     |                         16384 |    16326328320 |
    | plugin                                               |                         16384 |    16326328320 |
    | procs_priv                                           |                         32768 |    16326328320 |
    | proxies_priv                                         |                         32768 |    16326328320 |
    | replication_asynchronous_connection_failover         |                         32768 |    16326328320 |
    | replication_asynchronous_connection_failover_managed |                         16384 |    16326328320 |
    | replication_group_configuration_version              |                         16384 |    16326328320 |
    | replication_group_member_actions                     |                         32768 |    16326328320 |
    | role_edges                                           |                         16384 |    16326328320 |
    | server_cost                                          |                         16384 |    16326328320 |
    | servers                                              |                         16384 |    16326328320 |
    | slave_master_info                                    |                         16384 |    16326328320 |
    | slave_relay_log_info                                 |                         16384 |    16326328320 |
    | slave_worker_info                                    |                         16384 |    16326328320 |
    | slow_log                                             |                             0 |              0 |
    | tables_priv                                          |                         32768 |    16326328320 |
    | time_zone                                            |                         16384 |    16326328320 |
    | time_zone_leap_second                                |                         16384 |    16326328320 |
    | time_zone_name                                       |                         16384 |    16326328320 |
    | time_zone_transition                                 |                         16384 |    16326328320 |
    | time_zone_transition_type                            |                         16384 |    16326328320 |
    | user                                                 |                         16384 |    16326328320 |
    | NULL                                                 |                       2719744 |    16326328320 |
    38 rows in set (0.00 sec)
    Another Query for search transation, I don’t see any lock transaction on database :
    part of the result :
    TRANSACTIONS
    Trx id counter 11707713
    Purge done for trx's n:o < 11707713 undo n:o < 0 state: running but idle
    History list length 0
    LIST OF TRANSACTIONS FOR EACH SESSION:
    ---TRANSACTION 421688359443672, not started
    0 lock struct(s), heap size 1128, 0 row lock(s)
    ---TRANSACTION 421688359442864, not started
    ---TRANSACTION 421688359442056, not started
    All the result :
    show engine innodb status\G
    *************************** 1. row ***************************
      Type: InnoDB
      Name:
    Status:
    2022-11-07 21:13:43 140213236291328 INNODB MONITOR OUTPUT
    Per second averages calculated from the last 35 seconds
    BACKGROUND THREAD
    srv_master_thread loops: 31 srv_active, 0 srv_shutdown, 257609 srv_idle
    srv_master_thread log flush and writes: 0
    SEMAPHORES
    OS WAIT ARRAY INFO: reservation count 24
    OS WAIT ARRAY INFO: signal count 21
    RW-shared spins 0, rounds 0, OS waits 0
    RW-excl spins 0, rounds 0, OS waits 0
    RW-sx spins 0, rounds 0, OS waits 0
    Spin rounds per wait: 0.00 RW-shared, 0.00 RW-excl, 0.00 RW-sx
    TRANSACTIONS
    FILE I/O
    I/O thread 0 state: waiting for completed aio requests (insert buffer thread)
    I/O thread 1 state: waiting for completed aio requests (log thread)
    I/O thread 2 state: waiting for completed aio requests (read thread)
    I/O thread 3 state: waiting for completed aio requests (read thread)
    I/O thread 4 state: waiting for completed aio requests (read thread)
    I/O thread 5 state: waiting for completed aio requests (read thread)
    I/O thread 6 state: waiting for completed aio requests (write thread)
    I/O thread 7 state: waiting for completed aio requests (write thread)
    I/O thread 8 state: waiting for completed aio requests (write thread)
    I/O thread 9 state: waiting for completed aio requests (write thread)
    Pending normal aio reads: [0, 0, 0, 0] , aio writes: [0, 0, 0, 0] ,
     ibuf aio reads:, log i/o's:
    Pending flushes (fsync) log: 0; buffer pool: 0
    472 OS file reads, 2095 OS file writes, 963 OS fsyncs
    0.00 reads/s, 0 avg bytes/read, 0.00 writes/s, 0.00 fsyncs/s
    INSERT BUFFER AND ADAPTIVE HASH INDEX
    Ibuf: size 1, free list len 0, seg size 2, 0 merges
    merged operations:
     insert 0, delete mark 0, delete 0
    discarded operations:
    Hash table size 34679, node heap has 2 buffer(s)
    Hash table size 34679, node heap has 0 buffer(s)
    Hash table size 34679, node heap has 7 buffer(s)
    Hash table size 34679, node heap has 1 buffer(s)
    0.00 hash searches/s, 0.00 non-hash searches/s
    LOG
    Log sequence number          72770518572
    Log buffer assigned up to    72770518572
    Log buffer completed up to   72770518572
    Log written up to            72770518572
    Log flushed up to            72770518572
    Added dirty pages up to      72770518572
    Pages flushed up to          72770518572
    Last checkpoint at           72770518572
    Log minimum file id is       22221
    Log maximum file id is       22221
    694 log i/o's done, 0.00 log i/o's/second
    BUFFER POOL AND MEMORY
    Total large memory allocated 0
    Dictionary memory allocated 582286
    Buffer pool size   8192
    Free buffers       7161
    Database pages     1015
    Old database pages 354
    Modified db pages  0
    Pending reads      0
    Pending writes: LRU 0, flush list 0, single page 0
    Pages made young 750, not young 5674
    0.00 youngs/s, 0.00 non-youngs/s
    Pages read 450, created 565, written 1087
    0.00 reads/s, 0.00 creates/s, 0.00 writes/s
    No buffer pool page gets since the last printout
    Pages read ahead 0.00/s, evicted without access 0.00/s, Random read ahead 0.00/s
    LRU len: 1015, unzip_LRU len: 0
    I/O sum[0]:cur[0], unzip sum[0]:cur[0]
    ROW OPERATIONS
    0 queries inside InnoDB, 0 queries in queue
    0 read views open inside InnoDB
    Process ID=679488, Main thread ID=140212411815680 , state=sleeping
    Number of rows inserted 0, updated 0, deleted 0, read 0
    0.00 inserts/s, 0.00 updates/s, 0.00 deletes/s, 0.00 reads/s
    Number of system rows inserted 46, updated 459, deleted 8, read 37463
    END OF INNODB MONITOR OUTPUT
    1 row in set (0.01 sec)
    | mysql              |      2.59 |
    | sys                |      0.02 |
        -> with rollup;
    | slow_log                                             |                             0 |              0 |
    TRANSACTIONS
    All the result :
      Type: InnoDB
      Name:
    Status:
    BACKGROUND THREAD
    SEMAPHORES
    TRANSACTIONS
    FILE I/O
    merged operations:
    LOG
    Free buffers       7161
    Database pages     1015
    Modified db pages  0
    Pending reads      0
    ROW OPERATIONS
    @DownPW thanks for this. Let me review and I’ll get back to you.
    | mysql              |      2.59 |
    | sys                |      0.02 |
        -> with rollup;
    | slow_log                                             |                             0 |              0 |
    TRANSACTIONS
    All the result :
      Type: InnoDB
      Name:
    Status:
    BACKGROUND THREAD
    SEMAPHORES
    TRANSACTIONS
    FILE I/O
    merged operations:
    LOG
    Free buffers       7161
    Database pages     1015
    Modified db pages  0
    Pending reads      0
    ROW OPERATIONS
    @DownPW on checking, it seems that *.idb files by default never shrink - only grow. However, it should be possible to reclaim the disk space via optimize table <db.tablename>. I also found this
    https://dba.stackexchange.com/questions/39125/ibdata1-grows-exponentially-when-innodb-file-per-table-is-configured/39160#39160
  • @DownPW on checking, it seems that *.idb files by default never shrink - only grow. However, it should be possible to reclaim the disk space via optimize table <db.tablename>. I also found this
    #33
    Ok for test this
    but I hope it’s not dangerous… And what <db.tablename> put in this case ?
    Exemple
    optimize table XXXX.XXX
    Ok for test this
    Exemple
    @DownPW it’s perfectly safe. However, the hard part is identifying the actual table causing the bloat.
    Ok for test this
    Exemple
    @DownPW this is an interesting read
    https://bugs.mysql.com/bug.php?id=96466
    It seems that this is potentially a bug in some circumstances, but it’s the first thing I’ve come across it Out of curiosity, what do you use MySQL for, if at all ?
    One other option would be to use phpMyAdmin which has a decent GUI interface to perform the analysis and hopefully resolve the issue. Not only will it allow you to locate the offending table, but run maintenance against it to hopefully shrink it.
  • @DownPW this is an interesting read
    #36
    That’s the problem, I don’t use mySQL for anything at all.
    The only database management systems I use are mongoDB for NodeBB and postgreSQL for wiki.js.
    I think MySQL was installed when you have installing Virtualmin/Webmin on the server.
    Anyway I thought it was. Anyway I thought it was. If not, I can simply uninstall mySQL and delete files
    @DownPW you’ll need to go though the virtualmin way of removing the module itself, which is essentially the same as an apt remove mysql-server but with added dependency removal.
    Up to you at this point. I can have a look at resolving (hopefully) this tomorrow, or you can proceed with the removal?
    Let me know.
  • @DownPW you’ll need to go though the virtualmin way of removing the module itself, which is essentially the same as an apt remove mysql-server but with added dependency removal.
    Let me know.
    #38
    I have delete the webmin modules like this :
    https://sudonix.com/assets/uploads/files/1668193237472-fea622b7-2f4c-4bab-89d4-5293bb85e352-image.png
    But it wasn’t enough because the mySQL service was still present.
    So I have uninstall completely mysql like this:
    • First make sure that MySQL service is stopped :
    sudo systemctl stop mysql
    • Remove MySQL related all packages completely :
    sudo apt-get purge mysql-server mysql-client mysql-common mysql-server-core-* mysql-client-core-*
    • Remove MySQL configuration and data :
    sudo rm -rf /etc/mysql /var/lib/mysql /var/log/mysql
    • (Optional) Remove unnecessary packages.
    sudo apt autoremove
    • (Optional) Remove apt cache.
    sudo apt autoclean
    No issues noted so far
    Finally problem solved simply but I still don’t understand why this service was installed.
    I thought Webmin or Virtualmin was using it when it’s not at all after confirming this by @phenomlab
    Thanks dude. Always
  • DownPW DownPW has marked this topic as solved on
    sudo apt autoremove
    sudo apt autoclean
    Thanks dude. Always
    #39
    @DownPW said in Virtualmin SQL problem:
    Glad to hear (and see) that this issue is now resolved. Virtualmin and Webmin are both derived from the origin of LAMP (Linux, Apache, MySQL, and PHP) - the earliest form would have been a project which was a fork of the original concept called “WAMP” (Windows, Apache, MySQL, and PHP)
    https://www.wampserver.com/en/
    Scroll to the bottom, and you’ll see the packages it comes with
    Over time, activity on this project dropped somewhat due to the rise of Virtualmin and Webmin - acting as “full blown” platforms designed to manage an entire web server from start to finish, and providing an easy way to do so with a GUI interface. Over time, the LAMP bundle became LEMP (Linux, NGINX [actually pronounced “engine X”], MySQL, and PHP). The issue with Apache is that it had limits, and compared to NGINX, was in fact much slower.
    Virtualmin and Webmin do not actually use MySQL for their core operation - they don’t even use Apache or NGINX for the core web services, which is why the admin port is set to a default of 10000 when you first complete the setup.
    Essentially, you can think of Virtualmin and Webmin as a central pane of glass to manage the underlying components that are required to run a website. MySQL doesn’t need to be installed if you are not actually using it, but is there as PHP typically is paired with either MySQL or MariaDB, so it makes sense to offer the installation of this itself, as well as support for managing it.
    Solved. Tuto here and here
  • error with v3 in browser console
    Solved Performance socket error csrf
    @DownPW it’s in relation to the response I provided above
  • Coding question: fetch vs $.ajax call from Shopify
    Solved Performance javascript
    @Panda You should be able to use {% javscript %} as shown in this video - it’s quite the watch, but very educational, and provides insight as to how this works - see below screenshot for an example [image: cdb160e9-d955-498c-b921-982db2986e2b-image.png]
  • SEO and Nodebb
    Performance nodebb seo
  • NodeBB v3 Chat Very Slow
    Moved Performance nodebb v3 nodebb chat
    21k Views
    @DownPW Seems fine.
    'use strict'; const winston = require('winston'); const user = require('../user'); const notifications = require('../notifications'); const sockets = require('../socket.io'); const plugins = require('../plugins'); const meta = require('../meta'); module.exports = function (Messaging) { Messaging.notifyQueue = {}; // Only used to notify a user of a new chat message, see Messaging.notifyUser Messaging.notifyUsersInRoom = async (fromUid, roomId, messageObj) => { let uids = await Messaging.getUidsInRoom(roomId, 0, -1); uids = await user.blocks.filterUids(fromUid, uids); let data = { roomId: roomId, fromUid: fromUid, message: messageObj, uids: uids, }; data = await plugins.hooks.fire('filter:messaging.notify', data); if (!data || !data.uids || !data.uids.length) { return; } uids = data.uids; uids.forEach((uid) => { data.self = parseInt(uid, 10) === parseInt(fromUid, 10) ? 1 : 0; Messaging.pushUnreadCount(uid); sockets.in(`uid_${uid}`).emit('event:chats.receive', data); }); if (messageObj.system) { return; } // Delayed notifications let queueObj = Messaging.notifyQueue[`${fromUid}:${roomId}`]; if (queueObj) { queueObj.message.content += `\n${messageObj.content}`; clearTimeout(queueObj.timeout); } else { queueObj = { message: messageObj, }; Messaging.notifyQueue[`${fromUid}:${roomId}`] = queueObj; } queueObj.timeout = setTimeout(async () => { try { await sendNotifications(fromUid, uids, roomId, queueObj.message); } catch (err) { winston.error(`[messaging/notifications] Unabled to send notification\n${err.stack}`); } }, meta.config.notificationSendDelay * 1000); }; async function sendNotifications(fromuid, uids, roomId, messageObj) { const isOnline = await user.isOnline(uids); uids = uids.filter((uid, index) => !isOnline[index] && parseInt(fromuid, 10) !== parseInt(uid, 10)); if (!uids.length) { return; } if (roomId != 11) { // 5 Is the ID of the ID of the global chat room. Messaging.getUidsInRoom(roomId, 0, -1); // Proceed as normal. } else { user.getUidsFromSet('users:online', 0, -1); // Only notify online users. } const { displayname } = messageObj.fromUser; const isGroupChat = await Messaging.isGroupChat(roomId); const notification = await notifications.create({ type: isGroupChat ? 'new-group-chat' : 'new-chat', subject: `[[email:notif.chat.subject, ${displayname}]]`, bodyShort: `[[notifications:new_message_from, ${displayname}]]`, bodyLong: messageObj.content, nid: `chat_${fromuid}_${roomId}`, from: fromuid, path: `/chats/${messageObj.roomId}`, }); delete Messaging.notifyQueue[`${fromuid}:${roomId}`]; notifications.push(notification, uids); } };
