CPU usage higher than expected for nodeBB (on clients)
Chitchat
7 2 2.1k 1
    I’m looking at the task manager on firefox and nodebb forum takes a lot of CPU even at rest. I can imagine this is because it uses websockets. Do you have a similar experience? This is on linux,with a beefy CPU and GPU. It triggers the fans. I’ve noticed this with other similar apps (I suspect websocket heavy) like circle.so.
    If this is an inevitable consequence of ‘modern web’, I guess we’d all have to move to ARM or get used to spinning fans in the background.
    Is my experience an outlier?
  • I’m looking at the task manager on firefox and nodebb forum takes a lot of CPU even at rest. I can imagine this is because it uses websockets. Do you have a similar experience? This is on linux,with a beefy CPU and GPU. It triggers the fans. I’ve noticed this with other similar apps (I suspect websocket heavy) like circle.so.
    @qwinter said in CPU usage higher than expected for nodeBB (on clients):
    It might well be I think. I’m not seeing high CPU usage here (KDE Neon user)
    @qwinter Can you give me an idea of what your Firefox Task Manager looks like ? Here’s mine. Also much the same with Brave, Google Chrome, and Chromium
  • @qwinter Can you give me an idea of what your Firefox Task Manager looks like ? Here’s mine. Also much the same with Brave, Google Chrome, and Chromium
    That top entry is a circle.so ‘forum’ that eats CPU for breakfast too.
    @qwinter Yes, twice that of Sudonix. I know with Chrome there is an old issue where the GPU processes are actually responsible for huge memory usage, and you can stop that by disabling hardware acceleration.
    I wouldn’t class NodeBB CPU usage as that high though in my opinion.
    Interestly, if you compare this usage to Flarum, it is higher than expected, although my connection to Flarum isn’t logged in - just a guest. As a test, I fired up an incognito session of my site as a guest, and here’s the result
  • @qwinter Yes, twice that of Sudonix. I know with Chrome there is an old issue where the GPU processes are actually responsible for huge memory usage, and you can stop that by disabling hardware acceleration.
    @phenomlab I think in my case I could see it go down to ‘static website’ levels. Then when I log in, with no other tabs in firefox, task manager says ‘medium’…
    Which leads me to think its some websocket hackery keeping the connection alive for the logged in user in the background!
  • @phenomlab I think in my case I could see it go down to ‘static website’ levels. Then when I log in, with no other tabs in firefox, task manager says ‘medium’…
    @qwinter Yes, although the experience would be very much degraded without websockets.
  • Fedora Server + Virtualmin
  • Claude Mythos in cyber security
    Chitchat security artificial intelligence
  • Happy New Year!
    Chitchat new year
    Happy New Year !!
  • Arch Server Progress
    64
    31 Votes
    29k Views
    Chitchat themes nodebb
    80
    34 Votes
    31k Views
    omg thank you Mark.
  • Humour
    Chitchat humour
    53 Votes
    [image: 1608635114226.jpg]
  • NodeBB templates
  • NodeBB vs Discourse
    Chitchat nodebb discourse board
    RiekMedia
    @phenomlab said in NodeBB vs Discourse: Hetzner eh ? I use them also. In fact, Sudonix is hosted in Nuremberg yes i’m also at hetzner, i have been a customer there for years with a reseller account for domains. My VPS that I host there are also in Nuremberg
