setting up Matomo
@jac Another example…
I’ve just connected to Finland and it shows I’m viewing the site from USA? I know this is an issue you can’t fix, I’m just bringing to your attention that possibly it’s not as reliable as we thought?
I wonder if GA is any better? or am I getting too ahead of myself?
@jac said in setting up Matomo:
You’re getting ahead of yourself. Don’t forget that Matomo is fully GDPR compliant, and will take into account the privacy side of things, and (possibly) anonymises information before it is presented to you. Another reason could be the IP GEO settings, which I’ll have a look at now.
@phenomlab said in setting up Matomo:
@jac yep - as I suspected
You’re using the default, so we need to change this. I’ll do this now
Understood
Thanks pal, many thanks for that
The aim is for this to portray accurate data? so going off the VPN location rather than just IP?
@jac Essentially, yes - if a VPN is active, this will be the chosen address as it’s what you are connecting with. Also, browsers these days have the ability to opt out of tracking, so if it does work, then the results might not be what you expected either.
Neither Matomo or GA is going to be the holy grail I’m afraid because of privacy constraints.
Geo IP2 is now active
Many thanks mate, makes perfect sense!
Thanks for the explanation
@jac No problems. The Real-Time map is also working now
Many thanks for that mate, I do keep logging in to check it.
I need some more members
Register Login
