Forum not loading
Before we go down this route, I’m going to wait an hour to see if I can renew the LE cert.
@phenomlab Absolutely no problem pal
@jac As you do not have a Cloudflare account, we will need to create one - or, I can tack your domain onto my account meaning I will be responsible for it.
Up to you.
@phenomlab said in NodeBB - Created pages not found?:
Up to you.Having read the last message sent, if you do go down this route I am more than happy for it to be added to your account, but only if you are, or I can create my own.
@jac said in NodeBB - Created pages not found?:
Ok, no issues. I’ll add it to my account - but only if the LE renewal fails
I just managed to renew the cert You’re back in the game…
Brilliant!
Many thanks Mark, how did you manage that?
Brilliant!
@jac I noticed that the
.well-knowndirectories for LE had been deleted from your default web server path, so I recreated them and forced a renew -
phenomlab has marked this topic as solved on
Spam spam spam
Solved Configure -
Nodebb and emails
Solved Configure -
Test of youtube embeds
Solved Configure -
MogoDB v6 to v7 upgrade
Solved Configure -
Forum registration email goes to spam
Moved Solved Configure
