Issues with Progress Bar on v3
yop Mark
I see this on progress bar :
On small screen resolutions, the space between the arrows and the background div (progress bar) is not fixed.
It wouldn’t hurt to add fixed spaces no matter the resolution
OMG. Why on earth did I use percentages???
.pageUp { font-size: 1.25rem !important; left: 6%; line-height: 1.5; position: absolute; z-index: 10; } .pageDown { font-size: 1.25rem !important; line-height: 1.5; position: absolute; right: 6%; z-index: 10; }Change the
leftandrightvalues shown above to be1rem(or whatever value you’d prefer) and not6%
So
.pageUp { font-size: 1.25rem!important; left: 1rem; line-height: 1.5; position: absolute; z-index: 10; } .pageDown { font-size: 1.25rem!important; line-height: 1.5; position: absolute; right: 1rem; z-index: 10; } -
So
I often use my mobile landscape, and then this progress bar takes up a lot of the screen.
Id rather remove it entirely.
How can I do that, another CSS fix? -
@phenomlab ok how could I do that please?
I have an old flarum forum I had given up with, but I have to say its looking nicer than nodebb on mobile now. I prefer minimalistic and uncluttered look.
navbar
Solved Customisation -
