Upgrade Problem from 2.8.3 to 2.8.4
@phenomlab not fixed yet.
@phenomlab as user.
as a root i dont want to use for Nodebb.
on the other hand the forum is working normally. it is happening just when i m upgrading. -
@phenomlab as user.
@cagatay I’m not able to replicate this issue within my test environment. What permissions are set for the file and folders on this specific plugin?
@phenomlab its not problem as for the this moment. lets forget about it.
we should focus on v3
phenomlab has marked this topic as solved on
Users can not use emoji from now
how i can fix it? -
yes installed but not working.
no just now working emojies
KAYITLAR
started
2023-03-23T05:40:58.276Z [4567/190807] - [32minfo[39m: [build] Building in series mode
2023-03-23T05:40:58.277Z [4567/190807] - [32minfo[39m: [build] plugin static dirs build started
2023-03-23T05:40:58.283Z [4567/190807] - [32minfo[39m: [build] plugin static dirs build completed in 0.006sec
2023-03-23T05:40:58.284Z [4567/190807] - [32minfo[39m: [build] requirejs modules build started
2023-03-23T05:40:58.386Z [4567/190807] - [32minfo[39m: [build] requirejs modules build completed in 0.102sec
2023-03-23T05:40:58.386Z [4567/190807] - [32minfo[39m: [build] client js bundle build started
2023-03-23T05:40:58.389Z [4567/190807] - [32minfo[39m: [build] client js bundle build completed in 0.003sec
2023-03-23T05:40:58.389Z [4567/190807] - [32minfo[39m: [build] admin js bundle build started
2023-03-23T05:40:58.390Z [4567/190807] - [32minfo[39m: [build] admin js bundle build completed in 0.001sec
2023-03-23T05:40:58.390Z [4567/190807] - [32minfo[39m: [build] client side styles build started
2023-03-23T05:41:02.501Z [4567/190807] - [32minfo[39m: [build] client side styles build completed in 4.111sec
2023-03-23T05:41:02.501Z [4567/190807] - [32minfo[39m: [build] admin control panel styles build started
2023-03-23T05:41:05.371Z [4567/190807] - [32minfo[39m: [build] admin control panel styles build completed in 2.87sec
2023-03-23T05:41:05.372Z [4567/190807] - [32minfo[39m: [build] templates build started
2023-03-23T05:41:05.654Z [4567/190807] - [33mwarn[39m: [meta/templates] Partial not loaded: admin/partials/save_button.tpl
2023-03-23T05:41:06.061Z [4567/190807] - [32minfo[39m: [build] templates build completed in 0.689sec
2023-03-23T05:41:06.061Z [4567/190807] - [32minfo[39m: [build] languages build started
2023-03-23T05:41:08.012Z [4567/190807] - [32minfo[39m: [build] languages build completed in 1.951sec
2023-03-23T05:41:08.013Z [4567/190807] - [32minfo[39m: [build] Bundling with Webpack.[2K[1A[2K[G[1%] setup (before run)
[2K[1A[2K[G[1%] setup (before run NodeEnvironmentPlugin)
[2K[1A[2K[G[2%] setup (run)
[2K[1A[2K[G[4%] setup (normal module factory)
[2K[1A[2K[G[5%] setup (context module factory)
[2K[1A[2K[G[6%] setup (before compile)
[2K[1A[2K[G[6%] setup (before compile ProgressPlugin)
[2K[1A[2K[G[7%] setup (compile)
[2K[1A[2K[G[7%] setup (compile ExternalsPlugin)
[2K[1A[2K[G[8%] setup (compilation)
[2K[1A[2K[G[8%] setup (compilation ArrayPushCallbackChunkFormatPlugin)
[2K[1A[2K[G[8%] setup (compilation JsonpChunkLoadingPlugin)
[2K[1A[2K[G[8%] setup (compilation StartupChunkDependenciesPlugin)
[2K[1A[2K[G[8%] setup (compilation ImportScriptsChunkLoadingPlugin)
[2K[1A[2K[G[8%] setup (compilation FetchCompileWasmPlugin)
[2K[1A[2K[G[8%] setup (compilation FetchCompileAsyncWasmPlugin)
[2K[1A[2K[G[8%] setup (compilation WorkerPlugin)
[2K[1A[2K[G[8%] setup (compilation SplitChunksPlugin)
[2K[1A[2K[G[8%] setup (compilation ResolverCachePlugin)
[2K[1A[2K[G[9%] setup (compilation)
[2K[1A[2K[G[9%] setup (compilation ProgressPlugin)
[2K[1A[2K[G[9%] setup (compilation ChunkPrefetchPreloadPlugin)
[2K[1A[2K[G[9%] setup (compilation JavascriptModulesPlugin)
[2K[1A[2K[G[9%] setup (compilation JsonModulesPlugin)
[2K[1A[2K[G[9%] setup (compilation AssetModulesPlugin)
[2K[1A[2K[G[9%] setup (compilation EntryPlugin)
[2K[1A[2K[G[9%] setup (compilation RuntimePlugin)
[2K[1A[2K[G[9%] setup (compilation InferAsyncModulesPlugin)
[2K[1A[2K[G[9%] setup (compilation DataUriPlugin)
[2K[1A[2K[G[9%] setup (compilation FileUriPlugin)
[2K[1A[2K[G[9%] setup (compilation CompatibilityPlugin)
[2K[1A[2K[G[9%] setup (compilation HarmonyModulesPlugin)
[2K[1A[2K[G[9%] setup (compilation AMDPlugin)
[2K[1A[2K[G[9%] setup (compilation RequireJsStuffPlugin)
[2K[1A[2K[G[9%] setup (compilation CommonJsPlugin)
[2K[1A[2K[G[9%] setup (compilation LoaderPlugin)
[2K[1A[2K[G[9%] setup (compilation NodeStuffPlugin)
[2K[1A[2K[G[9%] setup (compilation APIPlugin)
[2K[1A[2K[G[9%] setup (compilation ExportsInfoApiPlugin)
[2K[1A[2K[G[9%] setup (compilation WebpackIsIncludedPlugin)
[2K[1A[2K[G[9%] setup (compilation ConstPlugin)
[2K[1A[2K[G[9%] setup (compilation UseStrictPlugin)
[2K[1A[2K[G[9%] setup (compilation RequireIncludePlugin)
[2K[1A[2K[G[9%] setup (compilation RequireEnsurePlugin)
[2K[1A[2K[G[9%] setup (compilation RequireContextPlugin)
[2K[1A[2K[G[9%] setup (compilation ImportPlugin)
[2K[1A[2K[G[9%] setup (compilation SystemPlugin)
[2K[1A[2K[G[9%] setup (compilation ImportMetaPlugin)
[2K[1A[2K[G[9%] setup (compilation URLPlugin)
[2K[1A[2K[G[9%] setup (compilation DefaultStatsFactoryPlugin)
[2K[1A[2K[G[9%] setup (compilation DefaultStatsPresetPlugin)
[2K[1A[2K[G[9%] setup (compilation DefaultStatsPrinterPlugin)
[2K[1A[2K[G[9%] setup (compilation JavascriptMetaInfoPlugin)
[2K[1A[2K[G[9%] setup (compilation EnsureChunkConditionsPlugin)
[2K[1A[2K[G[9%] setup (compilation RemoveEmptyChunksPlugin)
[2K[1A[2K[G[9%] setup (compilation MergeDuplicateChunksPlugin)
[2K[1A[2K[G[9%] setup (compilation FlagIncludedChunksPlugin)
[2K[1A[2K[G[9%] setup (compilation SideEffectsFlagPlugin)
[2K[1A[2K[G[9%] setup (compilation FlagDependencyExportsPlugin)
[2K[1A[2K[G[9%] setup (compilation FlagDependencyUsagePlugin)
[2K[1A[2K[G[9%] setup (compilation InnerGraphPlugin)
[2K[1A[2K[G[9%] setup (compilation MangleExportsPlugin)
[2K[1A[2K[G[9%] setup (compilation ModuleConcatenationPlugin)
[2K[1A[2K[G[9%] setup (compilation NoEmitOnErrorsPlugin)
[2K[1A[2K[G[9%] setup (compilation RealContentHashPlugin)
[2K[1A[2K[G[9%] setup (compilation WasmFinalizeExportsPlugin)
[2K[1A[2K[G[9%] setup (compilation DeterministicModuleIdsPlugin)
[2K[1A[2K[G[9%] setup (compilation DeterministicChunkIdsPlugin)
[2K[1A[2K[G[9%] setup (compilation DefinePlugin)
[2K[1A[2K[G[9%] setup (compilation TerserPlugin)
[2K[1A[2K[G[9%] setup (compilation TemplatedPathPlugin)
[2K[1A[2K[G[9%] setup (compilation RecordIdsPlugin)
[2K[1A[2K[G[9%] setup (compilation WarnCaseSensitiveModulesPlugin)
[2K[1A[2K[G[10%] building
[2K[1A[2K[G[10%] building (0/0 modules)
[2K[1A[2K[G[10%] building (0/15 modules)
[2K[1A[2K[G[10%] building (10/221 modules)
[2K[1A[2K[G[10%] building (60/270 modules)
[2K[1A[2K[G[10%] building (import loader file-loader/dist/cjs.js)
[2K[1A[2K[G[10%] building (131/299 modules)
[2K[1A[2K[G[10%] building (234/427 modules)
[2K[1A[2K[G[10%] building (368/429 modules)
[2K[1A[2K[G[10%] building (577/658 modules)
[2K[1A[2K[G[38%] building (870/871 modules)
[2K[1A[2K[G[65%] building (871/871 modules)
[2K[1A[2K[G[69%] building (finish)
[2K[1A[2K[G[70%] sealing (finish module graph)
[2K[1A[2K[G[70%] sealing (finish module graph ResolverCachePlugin)
[2K[1A[2K[G[70%] sealing (finish module graph InferAsyncModulesPlugin)
[2K[1A[2K[G[70%] sealing (finish module graph FlagDependencyExportsPlugin)
[2K[1A[2K[G[70%] sealing (finish module graph InnerGraphPlugin)
[2K[1A[2K[G[70%] sealing (finish module graph WasmFinalizeExportsPlugin)
[2K[1A[2K[G[71%] sealing (plugins)
[2K[1A[2K[G[71%] sealing (plugins WarnCaseSensitiveModulesPlugin)
[2K[1A[2K[G[71%] sealing (dependencies optimization)
[2K[1A[2K[G[71%] sealing (dependencies optimization SideEffectsFlagPlugin)
[2K[1A[2K[G[71%] sealing (dependencies optimization FlagDependencyUsagePlugin)
[2K[1A[2K[G[72%] sealing (after dependencies optimization)
[2K[1A[2K[G[73%] sealing (chunk graph)
[2K[1A[2K[G[73%] sealing (after chunk graph)
[2K[1A[2K[G[74%] sealing (optimizing)
[2K[1A[2K[G[74%] sealing (module optimization)
[2K[1A[2K[G[75%] sealing (after module optimization)
[2K[1A[2K[G[76%] sealing (chunk optimization)
[2K[1A[2K[G[76%] sealing (chunk optimization EnsureChunkConditionsPlugin)
[2K[1A[2K[G[76%] sealing (chunk optimization RemoveEmptyChunksPlugin)
[2K[1A[2K[G[76%] sealing (chunk optimization MergeDuplicateChunksPlugin)
[2K[1A[2K[G[76%] sealing (chunk optimization SplitChunksPlugin)
[2K[1A[2K[G[76%] sealing (after chunk optimization)
[2K[1A[2K[G[77%] sealing (module and chunk tree optimization)
[2K[1A[2K[G[78%] sealing (after module and chunk tree optimization)
[2K[1A[2K[G[78%] sealing (chunk modules optimization)
[2K[1A[2K[G[78%] sealing (chunk modules optimization ModuleConcatenationPlugin)
[2K[1A[2K[G[79%] sealing (after chunk modules optimization)
[2K[1A[2K[G[80%] sealing (module reviving)
[2K[1A[2K[G[80%] sealing (module reviving RecordIdsPlugin)
[2K[1A[2K[G[80%] sealing (before module ids)
[2K[1A[2K[G[81%] sealing (module ids)
[2K[1A[2K[G[81%] sealing (module ids DeterministicModuleIdsPlugin)
[2K[1A[2K[G[82%] sealing (module id optimization)
[2K[1A[2K[G[83%] sealing (chunk reviving)
[2K[1A[2K[G[83%] sealing (chunk reviving RecordIdsPlugin)
[2K[1A[2K[G[83%] sealing (before chunk ids)
[2K[1A[2K[G[84%] sealing (chunk ids)
[2K[1A[2K[G[84%] sealing (chunk ids DeterministicChunkIdsPlugin)
[2K[1A[2K[G[85%] sealing (chunk id optimization)
[2K[1A[2K[G[85%] sealing (chunk id optimization FlagIncludedChunksPlugin)
[2K[1A[2K[G[85%] sealing (after chunk id optimization)
[2K[1A[2K[G[86%] sealing (record modules)
[2K[1A[2K[G[86%] sealing (record modules RecordIdsPlugin)
[2K[1A[2K[G[87%] sealing (record chunks)
[2K[1A[2K[G[87%] sealing (record chunks RecordIdsPlugin)
[2K[1A[2K[G[87%] sealing (module hashing)
[2K[1A[2K[G[88%] sealing (code generation)
[2K[1A[2K[G[89%] sealing (runtime requirements)
[2K[1A[2K[G[89%] sealing (hashing)
[2K[1A[2K[G[90%] sealing (after hashing)
[2K[1A[2K[G[91%] sealing (record hash)
[2K[1A[2K[G[91%] sealing (module assets processing)
[2K[1A[2K[G[92%] sealing (chunk assets processing)
[2K[1A[2K[G[92%] sealing (asset processing)
[2K[1A[2K[G[92%] sealing (asset processing TerserPlugin)
[2K[1A[2K[G[92%] sealing (asset processing RealContentHashPlugin)
[2K[1A[2K[G[93%] sealing (after asset optimization)
[2K[1A[2K[G[94%] sealing (recording)
[2K[1A[2K[G[94%] sealing (after seal)
[2K[1A[2K[G[95%] emitting (emit)
[2K[1A[2K[G[95%] emitting (emit CleanPlugin)
[2K[1A[2K[G[98%] emitting (after emit)
[2K[1A[2K[G[98%] emitting (after emit SizeLimitsPlugin)
[2K[1A[2K[GBuild finished at 05:41:16 by 0.000s
[2K[1A[2K[G330 assets
897 modulesWARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
This can impact web performance.
Assets:
6aa13e92b5cf7d479e73acdc7c05abf3.js (502 KiB)
nodebb.min.js (445 KiB)
admin.min.js (395 KiB)
4793.dcf82000e95f412bc916.min.js (565 KiB)
8522.0f42740e78005fe716a3.min.js (501 KiB)
1083.65b10fecdfacafc29c2c.min.js (800 KiB)WARNING in entrypoint size limit: The following entrypoint(s) combined asset size exceeds the recommended limit (244 KiB). This can impact web performance.
Entrypoints:
nodebb (445 KiB)
nodebb.min.js
admin (395 KiB)
admin.min.jswebpack 5.75.0 compiled with 2 warnings in 8293 ms
2023-03-23T05:41:16.774Z [4567/190807] - [32minfo[39m: [build] Asset compilation successful. Completed in 18.495sec.
[cluster] Restarting…
2023-03-23T05:41:16.786Z [4567/190807] - [32minfo[39m: [app] Shutdown (SIGTERM/SIGINT) Initialised.
Clustering enabled: Spinning up 1 process(es).2023-03-23T05:41:16.791Z [4567/190807] - [32minfo[39m: [app] Web server closed to connections.
2023-03-23T05:41:16.794Z [4567/190807] - [32minfo[39m: [app] Live analytics saved.
2023-03-23T05:41:16.798Z [4567/190807] - [32minfo[39m: [app] Database connection closed.
2023-03-23T05:41:16.798Z [4567/190807] - [32minfo[39m: [app] Shutdown complete.
[cluster] Child Process (190807) has exited (code: 0, signal: null)
2023-03-23T05:41:17.044Z [4567/194647] - [32minfo[39m: Initializing NodeBB v2.8.9 https://efelsefe.com
2023-03-23T05:41:18.464Z [4567/194647] - [32minfo[39m: [socket.io] Restricting access to origin: https://efelsefe.com
(node:194647) [LRU_CACHE_UNBOUNDED] UnboundedCacheWarning: TTL caching without ttlAutopurge, max, or maxSize can result in unbounded memory consumption.
(Usenode --trace-warnings ...to show where the warning was created)2023-03-23T05:41:18.688Z [4567/194647] - [33mwarn[39m: [plugins/load] The following plugins may not be compatible with your version of NodeBB. This may cause unintended behaviour or crashing. In the event of an unresponsive NodeBB caused by this plugin, run
./nodebb reset -p PLUGINNAMEto disable it.- nodebb-plugin-google-analytics
- nodebb-rewards-essentials
- nodebb-plugin-custom-pages
- nodebb-plugin-poll
- nodebb-plugin-recent-cards
- nodebb-plugin-question-and-answer
- nodebb-plugin-iframely
- nodebb-plugin-browsing-users
- @nodebb/nodebb-plugin-user-level
- nodebb-plugin-dbsearch
2023-03-23T05:41:18.707Z [4567/194647] - [33mwarn[39m: [helpers.setupAdminPageRoute(/admin/plugins/custom-pages)] passing
middlewareas the third param is deprecated, it can now be safely removed
2023-03-23T05:41:18.728Z [4567/194647] - [33mwarn[39m: [helpers.setupAdminPageRoute(/admin/plugins/browsing-users)] passingmiddlewareas the third param is deprecated, it can now be safely removed
2023-03-23T05:41:18.728Z [4567/194647] - [33mwarn[39m: [helpers.setupPageRoute(/user-levels)] passingmiddlewareas the third param is deprecated, it can now be safely removed
2023-03-23T05:41:18.728Z [4567/194647] - [33mwarn[39m: [helpers.setupAdminPageRoute(/admin/plugins/user-level)] passingmiddlewareas the third param is deprecated, it can now be safely removed
2023-03-23T05:41:18.747Z [4567/194647] - [32minfo[39m: [api] Adding 1 route(s) toapi/v3/plugins
2023-03-23T05:41:18.759Z [4567/194647] - [32minfo[39m: [router] Routes added
2023-03-23T05:41:23.760Z [4567/194647] - [33mwarn[39m: [plugins] Callback timed out, hook ‘static:privileges.categories.init’ in plugin ‘nodebb-plugin-poll’
2023-03-23T05:41:23.767Z [4567/194647] - [33mwarn[39m: [meta/blacklist] 1 invalid blacklist rule(s) were ignored.
2023-03-23T05:41:23.769Z [4567/194647] - [32minfo[39m:
NodeBB Ready
2023-03-23T05:41:23.771Z [4567/194647] - [32minfo[39m:
Enabling ‘trust proxy’
2023-03-23T05:41:23.773Z [4567/194647] - [32minfo[39m:
NodeBB is now listening on: …
Canonical URL: https://… -
KAYITLAR
started
Assets:
Entrypoints:
nodebb (445 KiB)
nodebb.min.js
admin (395 KiB)
NodeBB Ready
@phenomlab yes its works now, i think my server has chache problem or something like that. Because i m doind some changes, but web site effected after 2-3 hours or maybe more.
By the way is it problem below one?WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB). This can impact web performance. Assets: 6aa13e92b5cf7d479e73acdc7c05abf3.js (502 KiB) nodebb.min.js (445 KiB) admin.min.js (395 KiB) 4793.dcf82000e95f412bc916.min.js (565 KiB) 8522.0f42740e78005fe716a3.min.js (501 KiB) 1083.65b10fecdfacafc29c2c.min.js (800 KiB) -
Nodebb and emails
Solved Configure -
NodeBB metadata
Solved Configure -
