setting up Matomo
48 2 18.5k 1
    @phenomlab Thanks Mark,
    I’ll go and locate this now.
    @jac done 🙂
    @jac done 🙂
    @jac Yes, this probably helps
    @jac done 🙂
    @jac Now re-add the subdomain
    @jac done 🙂
    @jac “Requesting a certificate for stats.stockportcounty.fans, www.stats.stockportcounty.fans from Let’s Encrypt …”
    that will be interesting… 👀
    @jac Should be fine. It may bomb on the www request - let me know if that’s the case.
  • @jac Should be fine. It may bomb on the www request - let me know if that’s the case.
    #26
    @phenomlab said in setting up Matomo:
    Requesting a certificate for stats.stockportcounty.fans, www.stats.stockportcounty.fans from Let's Encrypt ..
    .. request failed : Web-based validation failed :
    Saving debug log to /var/log/letsencrypt/letsencrypt.log
    Plugins selected: Authenticator webroot, Installer None
    Obtaining a new certificate
    Performing the following challenges:
    http-01 challenge for stats.stockportcounty.fans
    http-01 challenge for www.stats.stockportcounty.fans
    Using the webroot path /home/stockportcounty/domains/stats.stockportcounty.fans/public_html for all unmatched domains.
    Waiting for verification...
    Challenge failed for domain www.stats.stockportcounty.fans
    Cleaning up challenges
    Some challenges have failed.
    IMPORTANT NOTES:
     - The following errors were reported by the server:
       Domain: www.stats.stockportcounty.fans
       Type:   dns
       Detail: DNS problem: NXDOMAIN looking up A for
       www.stats.stockportcounty.fans - check that a DNS record exists for
       this domain
       DNS-based validation failed :
    Plugins selected: Authenticator manual, Installer None
    dns-01 challenge for www.stats.stockportcounty.fans
    Running manual-auth-hook command: /etc/webmin/webmin/letsencrypt-dns.pl
    Running manual-cleanup-hook command: /etc/webmin/webmin/letsencrypt-cleanup.pl
    IMPORTANT NOTES:
       Type:   dns
       Detail: DNS problem: NXDOMAIN looking up TXT for
       _acme-challenge.www.stats.stockportcounty.fans - check that a DNS
       record exists for this domain
    IMPORTANT NOTES:
       Type:   dns
       this domain
    IMPORTANT NOTES:
       Type:   dns
    #27
    @jac Unsurprising. There are two ways to do this
    • Create a CNAME record called WWW and have it point to the subdomain in DNS
    • Create a custom request for LE so that it ignores the www value, and only processes the actual domain you want
    VirtualMin -> Server Configuration -> SSL Certificate
    Let’s Encrypt
    Set as per the example, so you only request the domain you want. Ensure that “Automatically renew certificate” is selected, then “Request Certificate”
  • @jac Unsurprising. There are two ways to do this
    Let’s Encrypt
    Let’s Encrypt
    Thanks,
    which is the best solution?
    Let’s Encrypt
    Thanks,
    @jac Well, depending on configuration, they are as simple as each other. If you choose the first, then you need to add DNS records, and ensure your server is capable of handling them on arrival (it should be by default).
    If you choose the second, it’s the easiest (and probably laziest 🙂 ), but it will work. We just then need to set a redirect so that all traffic lands up at https://site.domain.com even if we try with or without the www prefix.
  • @jac Well, depending on configuration, they are as simple as each other. If you choose the first, then you need to add DNS records, and ensure your server is capable of handling them on arrival (it should be by default).
    If you choose the second, it’s the easiest (and probably laziest ), but it will work. We just then need to set a redirect so that all traffic lands up at https://site.domain.com even if we try with or without the www prefix.
    Will try this now mate 🙂
    @jac As per PM, this has been completed.
  • @jac As per PM, this has been completed.
    Can’t thank you enough for that Mark! - Superb yet again! 🙂
    @jac I have a feeling the real-time map isn’t working correctly?
    Screenshot 2021-12-09 at 18-05-20 Stockport County Fans - Web Analytics Reports - Matomo.png
    “NO Data”.
    “NO Data”.
    @jac You need to wait for 24 hours ⏲
  • @jac You need to wait for 24 hours ⏲
    Thanks mate 🙂 was wondering if it should work real-time when someone visits. I do remember this being the case last time I used it.
    VPN connected to Holland… Stats site shows UK. Oh dear… 😳😑.
    @jac said in setting up Matomo:
    This now makes me think, is the VPN really reliable or is the Matomo stats really good at showing the IP of where you really are 🤔
    @jac Matomo should only record what is being presented by the browser. Is the VPN actually enabled in the browser session ?
    Typically, this is via an add on or extension, or have you enabled it at system level via an application ?
  • @jac Matomo should only record what is being presented by the browser. Is the VPN actually enabled in the browser session ?
    This was connected to express VPN via mobile phone app. I also tried the same with Nord & repeated both on the Nvidia Shield yielding the same result (showing UK) despite being connected to Germany, France etc.
    @jac Another example…
    I’ve just connected to Finland and it shows I’m viewing the site from USA? I know this is an issue you can’t fix, I’m just bringing to your attention that possibly it’s not as reliable as we thought?
    I wonder if GA is any better? or am I getting too ahead of myself? 😛
