Loading Image Problem
Bugs
24 2 11.3k 1
  • wrote on last edited by cagatay
    #21
    no without problem i upgraded.
    just that problem wich faced.
    your proxy and css/js everything working without problem.
  • no without problem i upgraded.
    @cagatay Strange. Well, it’s fixed now, so hopefully shouldn’t be an issue going forward.
    @cagatay said in Loading Image Problem:
    Yes, I updated also yesterday to test that 🙂
    Thank you Mark.
  • Layout Issues/Transparency
  • Getting Eror When Started NodeBB
    Solved Configure bug
    @phenomlab yes i did. i deleted one of plugin then it started to work normally.
  • Is NTFY working properly on iOS?
    Bugs
    @phenomlab thx, the same for us. It sees 1.7.3 as the last version although it is updated to 1.7.4… i will report this to @barisusakli
  • Bug Report
    Solved Bugs nodebb bugs
    Solved Bugs
    49
    20 Votes
  • Nodebb 3.2.2
    Bugs nodebb 3.2.2
    @crazycells yes, I’ve just seen that and modified the post. It seems to only happen if you have a space between the “greater than” symbol and the actual text. Clearly a markdown thing.
  • Issues with Imgur images in Fancybox chat module
    Bugs fancybox chat
    @DownPW looks good to me.
