How to install a self-hosted instance of iFramely for use with NodeBB
@cagatay is the
iframelyservice started ? That error message would indicate it’s not running@phenomlab as a result of ps -x i cant see iframely service pid id so i think its not working automaticly when i rebooted the server. How can i start it?
@cagatay try
pm2 start pm2.jsonwhich needs to be executed from the directory of the iFramely domain where it is installed. See previous documentation I provided after the installation.A quicker route would be to reboot your VPS to see if that resolves the issue.
@cagatay try
hope everything is ok from now.
@cagatay try
@phenomlab when i reboot the vps nodebb and iframely not working auto
but manually everything is working fine right now. -
I like your iframe :
Can you please provide your CSS code with me for Iframely Iframe ?
Thanks in advance dude
@DownPW this was actually stolen from @crazycells (
) and slightly modified, so I can’t really take the credit.His original response to the iFramely guide I posted contains the CSS he’s using is here
phenomlab referenced this topic on
yeap, unfortunately, the original unpaid version of iframely takes up a huge space on the screen. These CSS codes make it better than normal. But of course, it is not as good as the original paid version of iframely
@DownPW it is the second post of this thread.
Register LoginRelated Topics
Nodebb and emails
Solved Configure -
Gettin Erors NodeBB
Solved Configure -
iFramely self host help
Solved Configure -
NodeBB metadata
Solved Configure -
Iframely (Nodebb)
