Ethernet speed VERY slow
Solved Networks
67 3 27.6k 1
    @phenomlab I believe the newer models allow 1 Gig, which looks to be my model.
    https://www.nvidia.com/en-us/shield/shield-tv-pro/
    @JAC Yes, that does seem to be the case.
    Did you recently upgrade?
  • @JAC Yes, that does seem to be the case.
    @phenomlab No, this is the product I got a few years ago. Plus I have got over 100mbps on the WiFi so it must allow that. .
    Strangely though when I used the Ethernet adapters it didn’t seem to work, probably 20mbps at best.
    Maybe I got a dud one 😉.
    @JAC the apater could be hard coded to 100Mbps in the settings. Check and see if this is the case. In any event, it should be set to auto.
  • @JAC the apater could be hard coded to 100Mbps in the settings. Check and see if this is the case. In any event, it should be set to auto.
    @phenomlab Thanks Mark,
    I’ll check this out tomorrow.
    @JAC this specific adapter is capable of 600Mbps, so should be fine - but won’t give you 1Gbps on the shield because the speed is being capped.
    Did you check the interface speed on the device itself?
  • @JAC this specific adapter is capable of 600Mbps, so should be fine - but won’t give you 1Gbps on the shield because the speed is being capped.
    wrote on last edited by JAC
    #47
    @phenomlab I’ve not checked but I do remember the 100mbps adapters that I have being better so you’re probably right, although what I would say is it was only showing speeds of about 20mpbs last time. Would this depend on where the WiFi box is located? 🥺.
    @JAC Yes, it would, but I thought that we had them wired last time because of this?
  • @JAC Yes, it would, but I thought that we had them wired last time because of this?
    @phenomlab I did mate you’re right but still only got a speed of 20mbps.
    @JAC what we need to do is eliminate the power line adapters. Can you bring the unit downstairs and plug it directly into the back of the hub and a what connection speed you get?
  • @JAC what we need to do is eliminate the power line adapters. Can you bring the unit downstairs and plug it directly into the back of the hub and a what connection speed you get?
    @phenomlab yes pal, I’ll do this tomorrow and take some pictures.
    @JAC Thanks
    Apologies for the huge delay Mark, I’ll look to do this later and update the thread.
    @JAC No problems.
    #55
    Ok, so the results are in…
    160mbps with WiFi (close to router) very slow speeds in my opinion?
    And 111mbps with ethernet cable direct from router. 😲
    @JAC what speed do you currently have in terms of package? I’d expect a wired connection to be faster than that.
  • @JAC what speed do you currently have in terms of package? I’d expect a wired connection to be faster than that.
    @phenomlab 1gbps package with Virgin.
    @phenomlab said in Ethernet speed VERY slow:
    Me too, something wrong somewhere.
    @JAC is the device in question connected directly to the hub or is there anything in between such as power line adapters etc?
    If there is anything in between, you should remove this and connect it directly. As previously discussed, it might involve bringing that device to the router.
  • @JAC is the device in question connected directly to the hub or is there anything in between such as power line adapters etc?
    #60
    Not at all pal, pure WiFi connection.
    We have some WiFi adapters (pods) from virgin media, if unplugged naturally speed gets worse.
  • Infrared the new WiFi?
    General wifi infrared
    @JAC those speeds are indeed possible over light as a transport medium (if you consider the speed) but I can’t comprehend the distance quoted. If you happen to encounter a solid obstacle, the beam is either absorbed, or deflected meaning the data never arrives.
  • New Router
    Networks router tp-link axe75 home network networking
    @phenomlab Yes, I updated it right away after I created the password when first setting it up. Then I made my configurations.
  • Linksys EA6400
    Solved Networks router linksys firmware
    @phenomlab That is very awesome!
  • Issues with routing
    Solved Networks network
    @mathourthy Glad to hear it’s sorted. Let me know if you get any more issues.
  • Virgin router replacement
    Networks virgin virgin media hub router
    192
    43 Votes
    101k Views
    @phenomlab Yeah I will have to check that out. I don’t remember when the last time it was updated. That was a good article too by the way.
  • Nvidia Shield connection speed
    Solved Networks nvidia shield
    @phenomlab said in Nvidia Shield connection speed: @jac no. You would be looking for settings in relation to the network port itself as I defined earlier. In addition, the port speed of the power line adapters you have is 10/100, so the max speed available will be capped at 100mbps. That’s great, thanks for all the help and advice during this thread Mark, you’ve been a great help!
