Very good like always 😉
Switch between list and card view function
Here’s a stable version based on stock Harmony
Note that there are a lot of changes here, so if you have previously deployed this code, you need to update it. Also note that the CSS is based on stock harmony - if you have any customised theme, you’ll need to add this yourself (obviously, I cannot possibly factor in custom styles).
@phenomlab said in Switch between list and card view function:
If you have a pinned topic with the pinned label, the line is visible behind the label
I decided to leave this as is. It’s transparent in the stock harmony CSS, so if you want to change it to suit your needs, then feel free. The categories and tags have been moved to the right anyway in this modified version of code, therefore, the “bug” (it’s not really, but…) is no longer present.
Great
I put the code on prod.
I see this bug on a few topics but impossible to know why -
@DownPW does it resolve itself if you click the home button again? I’ve seen this in dev but can’t reproduce it in prod.
nope, the bug persist.
it seem problem with
.category-card .lastpost a img
but what’s strange is that it doesn’t do it for all topics -
@DownPW yes, it seems to be an issue with the
ajax
callback but not sure where currently it originates from.Does it happen on page load also?
ajax
can you be more specific?
If I refresh the page while keeping Card View activated it’s the same.
Same if I deactivate/reactivate Card ViewHere, we see, we have not
add to class -
@DownPW the class you’re referring to in the screenshot isn’t supposed to be applied to that specific element, as there is no
to be applied against.What I meant about the
ajax
callback is that not all of the styles seem to be applied. It’s almost as though they are being added to the DOM when they aren’t loaded yet. -
Arf Ok sorry.
For information, I have the same things on my test server (actually, it’s a clone of prod) if you want to see in details or play -
@DownPW thanks. The really odd thing here is that I can’t reproduce this issue at all in prod - where I developed it originally in fact.
I think I’m missing something somewhere, but unsure as to where it is currently.
no problem dude. I’m not sure I’ll be much help on this one.
@DownPW no problems. Your review and findings are a great help already.
@DownPW I found the bug. It’s CloudFlare
Setting the cache to bypass resolves the issue. This explains why I cannot replicate it in PROD (for me) as I only use CF for DNS resolution.
I have modified the CSS file slightly also, so you’ll need to pick up the latest code.
https://github.com/phenomlab/harmony-card-view/blob/main/card.css
Not entirely sure why CF seems to think this file never changes - it’s different on each page load and suffixed with a random string! The setting in CF should also respect that - but doesn’t. So much for that
Ok @phenomlab Thanks to you for find the solution for this problem
so what is the good parameters in CF for this script ?
Maybe include this on your github ? -
@DownPW yes, absolutely, although I’m not entirely sure why CF behaves in this manner as in most cases, a present query string that changes frequently (on each page load) should not present itself as an issue.
Still checking.
It’s a shame to do without the CF cache in my opinion.
Do you just have to activate development mode in CF?
@DownPW yes, in my testing, just enable development mode and then reload the site a few times and you’ll notice it works as intended.
hmm I think they was other thing.
I have not update the css file, I have just :
- activated development mode in CF,
- purge everything cache in CF,
- and test in new incognito windows on firefox
and I have the bug.
Edit : Same with the CSS updated
@DownPW is this in your dev environment? I checked that earlier and the bug wasn’t present.
yes the bug is in my dev environment
chat list navbar
Solved Customisation -
