Did you find the suggested solution useful? Why not buy me a coffee? It's a nice gesture, and a great way to show your appreciation 💗
  • Page control arrows for PWA
    25 Votes
    @crazycells it is, yes - I think I’ll leave it as there is no specific PWA CSS classes I know of. Well, you could use something like the below, but this means multiple CSS files for different operating systems.
    /** * Determine the mobile operating system. * This function returns one of 'iOS', 'Android', 'Windows Phone', or 'unknown'. * * @returns {String} */ function getMobileOperatingSystem() { var userAgent = navigator.userAgent || navigator.vendor || window.opera; // Windows Phone must come first because its UA also contains "Android" if (/windows phone/i.test(userAgent)) { return "Windows Phone"; } if (/android/i.test(userAgent)) { return "Android"; } if (/iPad|iPhone|iPod/.test(userAgent) && !window.MSStream) { return "iOS"; } return "unknown"; // return “Android” - one should either handle the unknown or fallback to a specific platform, let’s say Android }
    Once you’re in that rabbit hole, it’s impossible to get out of it.
    @phenomlab yes, it is 🙂 thanks a lot…
    @Panda said in Interesting Widget code, but can’t fetch API:
    How did you drop that widget into the post there?
    I hadnt seen this BSgenerator anywhere on sudonix site, do you use it somewhere already?
    Yes, here
    https://sudonix.org/topic/414/corporate-bullshit-generator?_=1687774393044
    It’s not a “post” or “topic” in the common sense. It is actually a page in it’s own right and leverages nodebb-plugin-custom-pages. This in turn creates a new “route” which behaves like a page, meaning it is then exposed for widgets.
    Also can you explain more what you mean by calling the code externally. In my API call example, how would I go about doing that?
    By this, I mean create all the required code in an external JS file that is reachable by the NodeBB instance - so, in “public” for example - or in my case /public/js. The widget then “calls” that file and because it runs outside of the scope of NodeBB, you just need to return the values to the widget.
    Hope this makes sense?
  • 6 Votes
    @phenomlab said in Q&A Plugin Changes NodeBB:
    float: right;
    left: 10px;
    worked thank you 🙂
  • 7 Votes
    @phenomlab thank you very much 🙂
    is there any way to see whose reputation is changed by this plugin?
    @downpw I’m inclined to agree with this. There isn’t much else you can do, and provided it works with no odd looking artefacts in other browsers, then ok. The :before and :after are pseudo classes and very well supported across all browsers (except perhaps Internet Exploder, but who uses that these days ?)
  • [NodeBB] username cards
    Aha…nice to know. As always thank you for the reply and information.
