@Sala the only way you can achieve this is to use a robots.txt file and disallow access to those links.
navigation menu panel on mobile
Hi @phenomlab ,
I am trying to make this menu panel longer… What is the easiest way to do this?
Well, I figured it out and leaving the codes here in case others are interested…
.bottombar-nav .navigation-dropdown, .bottombar-nav .user-dropdown { max-height: 80vh !important; }
max height is coded to be 60vh, I changed it to 80vh…
@phenomlab I have just realized that you are already using this as 80vh in this forum… very smart move
You are on your way to becoming a coder.
hi @phenomlab , it is hard to browse the sudonix categories on mobile, fyi… I believe there is a bug on ios, but it is not fixed since it is not acting the same on android…
@crazycells I’ve disabled the auto hiding of the bottom bar here. Does this resolve the issue?
@phenomlab much better… thanks…
Additionally, somehow bottom menu bar of the sudonix looks smaller than the original? I would even suggest using slightly higher icons for people with sausage fingers lol
@crazycells hmm. That’s odd. I haven’t made any changes from recollection but I could be wrong. I’ll need to check.
EDIT - very strange. I honestly don’t recall adding the below CSS block to alter the bottom bar, but you’re right…
.bottombar-nav { padding: 0px !important; }
I’ve removed this so it reflects stock Harmony.
