No no, I said that in the sense that he told me it was simple ^^
I was able to see that this was not the case by targeting the elements he had advised me.
[NodeBB] First post customization
Hi @phenomlab , how are you?
I would like to separate the first post from the rest (NodeBB v1.18.6) … I see that you have a border and background customization enabled at the dark mode. How can I target the first post only?
I just could not find the correct CSS change for the first post.
I am trying to do something like this:
.posts .timeline li[data-index="0"] { border-bottom: 1px solid #eee; }
But, unfortunately it does not work Any help is appreciated…
@crazycells hi. Hope you’re well. Does it work if you set
!important
after the class ? -
@phenomlab said in [NodeBB] First post customization:
!important
after the class ?Thanks for the suggestion. With the code above it did not work but I later found the correct codes:
li[data-index="0"] .post-footer { border-bottom: 1px solid #eee; }
@crazycells good to hear ! I’ll mark this resolved.
@phenomlab thanks
