Post Style View
Did you find the suggested solution useful? Why not buy me a coffee? It's a nice gesture, and a great way to show your appreciation 💗
  • SEO and Nodebb
    Performance
    @Panda It’s the best it’s ever been to be honest. I’ve used a myriad of systems in the past - most notably, WordPress, and then Flarum (which for SEO, was absolutely dire - they never even had SEO out of the box, and relied on a third party extension to do it), and NodeBB easily fares the best - see below example
    https://www.google.com/search?q=site%3Asudonix.org&oq=site%3Asudonix.org&aqs=chrome..69i57j69i60j69i58j69i60l2.9039j0j3&sourceid=chrome&ie=UTF-8#ip=1
    However, this was not without significant effort on my part once I’d migrated from COM to ORG - see below posts
    https://community.nodebb.org/topic/17286/google-crawl-error-after-site-migration/17?_=1688461250365
    And also
    https://support.google.com/webmasters/thread/221027803?hl=en&msgid=221464164
    It was painful to say the least - as it turns out, there was an issue in NodeBB core that prevented spiders from getting to content, which as far as I understand, is now fixed. SEO in itself is a dark art - a black box that nobody really fully understands, and it’s essentially going to boil down to one thing - “content”.
    Google’s algorithm for indexing has also changed dramatically over the years. They only now crawl content that has value, so if it believes that your site has nothing to offer, it will simply skip it.
    @Panda as, yes, now I understand and that makes 100% sense. It means those who get down voted can still have an opinion and use common services.
    And yes, you’re right. Rather than down vote, just ignore if you don’t agree.
  • 6 Votes
    @phenomlab said in Q&A Plugin Changes NodeBB:
    float: right;
    left: 10px;
    worked thank you 🙂
  • Rotating homepage icons, gifs?
    @eveh It’s not a GIF, no. It’s actually a webp file so made much smaller, and uses keyframes to control the rotation on hover. You can easily make your own though 🙂
    The CSS for that is as below
    @keyframes rotate180 { from { transform: rotate(0deg); } to { transform: rotate(180deg); } } @keyframes rotate0 { from { transform: rotate(180deg); } to { transform: rotate(0deg); } }
    Your milage may vary on the CSS below, as it’s custom for Sudonix, but this is the class that is used to control the rotate
    .header .forum-logo, img.forum-logo.head { max-height: 50px; width: auto; height: 30px; margin-top: 9px; max-width: 150px; min-width: 32px; display: inline-block; animation-name: rotate180, rotate0; animation-duration: 1000ms; animation-delay: 0s, 1000ms; animation-iteration-count: 1; animation-timing-function: linear; transition: transform 1000ms ease-in-out; }
  • 13 Votes
    @pobojmoks that’s easily done by modifying the code provided here so that it targets background rather than border
    In essence, the below should work
    $(document).ready(function() { $(window).on('action:ajaxify.end', function(data) { $('.recent-card-container').each(function(i) { var dataId = $(this).attr("data-cid"); var color = $('[role="presentation"]', this).css("background-color"); console.log("data-cid " + dataId + " is " + color); $('[data-cid="' + dataId + '"] .recent-card').attr("style", "background-color: " + color); }); }); });
  • Fontawesome 5
    Unsolved Customisation
    @phenomlab thanks 🙏
