Discourse can turn posts into wiki posts. Can nodeBB?
I’m looking for something similar to this:
https://meta.discourse.org/t/what-is-a-wiki-post/30801 -
https://meta.discourse.org/t/what-is-a-wiki-post/30801@qwinter Yep - see
https://github.com/julianlam/nodebb-plugin-knowledge-base/Not tried it myself though - although I think I should given the nature of Sudonix
EDIT: Installed, and looks like it needs some refactor for it to work (despite claiming to work, and is supported).
EDIT2 - this plugin seems to not actually do that much in fairness - see
https://community.nodebb.org/topic/13490/bounty-of-500-wiki-plugin/21?_=1651598609240The response from NodeBB themselves is to create a category, and allow users to edit posts in that. I’m not sure that this entirely how a Wiki is supposed to work though
@qwinter Yep - see
@phenomlab Amazing, thank you for actually trying the plugin!
One the nodebb forum solution: letting people edit pots on one category is fine, but then only the author can edit the post he made, that is, no collaboration possible right?
EDIT: ah, no, I get it, the privs are such that anyone can edit any post. Well. that’s something. I wonder if the edit history (versions) keep who edited what. This is not a bad solution I think. -
Register LoginRelated Topics
Nodebb design
Solved General -
Nodebb Hashtag plugin
Solved General -
