help me configuring cron job for fof/sitemap - flarum
36 3 13.2k 1
  • 6 Votes
    15k Views
    @justoverclock said in Digitalocean step by step guide to nginx configuration: i’m learning And that’s the whole point of this site If you don’t learn anything, you gain nothing.
  • iFramely self host help
    Solved Configure iframely hosting
    @DownPW https://sudonix.com/topic/331/how-to-install-a-self-hosted-instance-of-iframely-for-use-with-nodebb
  • Configure SMTP for Nodebb
  • installing flarum with plesk
    Solved Configure flarum
    78
    39k Views
    @phenomlab thanks a lot, have a nice day
  • how to change flarum configuration from apache to nginx?
    See https://sudonix.com/topic/226/issues-getting-flarum-to-work-on-new-host/28?_=1645013723672
  • Issues getting Flarum to work on new host
    Solved Configure virtualmin
    65
    14 Votes
    30k Views
    @crazycells huh. Thanks. Will need to check that as well.
  • moving flarum from sub directory to subdomain
    @phenomlab yes, created different app and moved files and DB now everything is working thanks
  • is my DMARC configured correctly?
    @phenomlab said in is my DMARC configured correctly?: you’ll get one from every domain that receives email from yours. Today I have received another mail from outlook DMARC, i was referring to your reply again and found it very helpful/informative. thanks again. I wish sudonix 100 more great years ahead!
