Embeds
What is being used to embed links? We use the bundled link preview with NODEBB and some links will not embed with card info.
This link will just say denied on the card.
@OT Hi - Sudonix uses
OGProxy
which is a client side service written by mehttps://sudonix.org/topic/498/setup-ogproxy-for-use-in-nodebb
@OT Are you testing embeds, or did you insert this link for another purpose? For clarity, this isn’t a testing category
Sidebar Widget is no longer on the side!
Moved Solved General -
Embedding external URLs
Solved General -
